25th January 2013, 19:58 | #201 | Link |
Something in recent builds of MPC-HC has broken the advanced subs handling in LAV splitter. If I have an mkv with eng main audio and eng subs (both flagged default, none forced, subs are srt format) and a lav advanced string of "eng:eng|f;eng:off;*:eng;*:*|f" then MPC will still show eng subs if subs are enabled in MPC. I reverted back to build 1.6.6.6464 and that reverses it so that it works as it used to. something between that and current version changed so that the eng : off match no longer works as it did to turn the subs off even when mpc subs are enabled. using evr-cp and dxva.
25th January 2013, 20:09 | #202 | Link |
Here is the callstack (from 1.6.6.6538) where it happens, if anyone wants to look into it:
LAVSplitter.ax!CLAVSplitter::Enable(long lIndex, unsigned long dwFlags) Line 1250 + 0x5d bytes C++ mpc-hc.exe!CMainFrame::UpdateSubtitle(bool fDisplayMessage, bool fApplyDefStyle) Line 13772 C++ mpc-hc.exe!CMainFrame::OpenMediaPrivate(ATL::CAutoPtr<OpenMediaData> pOMD) Line 12016 C++ mpc-hc.exe!CGraphThread::OnOpen(unsigned int wParam, long lParam) Line 82 C++ Underground78 said he wants to look into it on the weekend.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th January 2013 at 20:15. |
25th January 2013, 22:16 | #203 | Link |
4:2:0 hater
After a long time I upgraded today from r3946 to r6366, and inmediately noticed an issue with the autofit option (once again). I always have a fixed window size and position, remembered with the "Remember last window position" and "Remember last window size" options. I also use ffdshow to resize everything to screen resolution, so input video to MPC-HC is always 1680x1050. Thanks to the autofit option, each time I opened a video it was resized to fit that fixed window without issues. However in r6366 when the autofit option is enabled it doesn't matter what window size I choose, as long as I open a video MPC resizes the window(!!!) it to an apparent arbitrary size (it's always the same) and even moves(!!!) the window instead of leaving it alone.
I've tried to find the rev that caused this and it was between r4360 and r4902. I can't find any builds between these, anybody got links so I can point to the exact revision that is causing this? Thanks in advance! Last edited by STaRGaZeR; 25th January 2013 at 22:20. |
25th January 2013, 22:32 | #204 | Link | |
25th January 2013, 22:38 | #205 | Link |
MPC-HC Developer
For now we can use mpc-hc builds older then r6518 (7035e41). Selection of subtitle track through lav splitter menu or navigate menu in mpc-hc doesn't work too, I've reported this to Underground78 some time ago. We need to wait for the fix. It's funny that everyone discover this bug after new LAVF release ;p while the bug is present for some time. Nightly build can be broken once in a while...
25th January 2013, 23:09 | #206 | Link |
Well, I think this subtitle selection bug was discovered some time ago:
http://forum.doom9.org/showthread.ph...26#post1610326 http://forum.doom9.org/showthread.ph...12#post1610712 It was just rediscovered now Last edited by Qotscha; 26th January 2013 at 10:33. |
26th January 2013, 04:42 | #207 | Link | |
4:2:0 hater
26th January 2013, 14:42 | #208 | Link | |
About the subtitles selection thing, this is a work in progress that it will be fixed one way or another in the next stable. Note that nightly builds can't be expected to be stable! While we are happy that users test them since it helps us fixing bugs we aren't aware of before a stable version is released, you have to keep in mind that those versions are and always will be considered experimental. |
26th January 2013, 17:10 | #209 | Link |
http://www.sendspace.com/file/lc1w3a
MPC-HCs Real Video decoder causes a crash, LAV Video decoder is fine. PS: Tested on MPC-HC.1.6.6.6659 x86 Last edited by wanezhiling; 26th January 2013 at 17:30. |
26th January 2013, 17:32 | #210 | Link | |
MPC-HC Helper xD
Do you have dump file by any chance ? |
26th January 2013, 17:37 | #211 | Link |
26th January 2013, 18:02 | #212 | Link | |
MPC-HC Helper xD
It will be fixed in our next nightly by updating ffmpeg ofc. Thanks for the report. |
27th January 2013, 00:19 | #214 | Link |
RedDwarf Fan
For anything but 100%, MPC 6.4.9.1 gives a sharper image than MPC-HC 1.5.2.3456 for me.
Using VMR-9 renderless and Bicubic A=-1.0 rendered as a 3D surface. It's quite noticeable. Has anyone noticed this? Can anyone explain why? Last edited by RedDwarf1; 27th January 2013 at 00:53. Reason: update |
27th January 2013, 04:03 | #215 | Link |
Member of a Library
About file associations on windows 7: I have eliminated the OS's annoyances by elevating, UACing, taking permissions on HKEY_CLASSES_ROOT (both per machine and per user) and whatnot and I want to use the "old" direct method of file association, for example:
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.avi] @=mplayerc64.AVI [HKEY_LOCAL_MACHINE\SOFTWARE\Classes\mplayerc64.avi] blah blah... (whatever MPC puts there) In order to further reduce clutter, would MPC-HC mind if I put all associations in one class (the second part, HKEY_LOCAL_MACHINE\SOFTWARE\Classes\mplayerc64.avi or whatever I call it) and have different dot-extensions (the first part) point to it? I thought I'd ask before I do it... Edit: in other words, will it be surprised/crash if, for example, MKV arrives through registry extension for .AVI? As far as I can see, all shell entries look the same, and of course, I will preserve mime types and other things in the first part for other programs. Is the grouping in options/file associations done just for convenience? Last edited by GrofLuigi; 27th January 2013 at 04:12. |
27th January 2013, 15:20 | #216 | Link | |
MPC-HC Developer
27th January 2013, 18:30 | #217 | Link |
Attention!
Versions from 6644 to 6666 and have a bug mixer. For example, when mixing from 5.1 to stereo not mixed center channel (and possibly others). This can result to the fact that when watching a movie you will not hear the characters voices. In the 6667 version of the bug fixed. Been used patch by Aleksoid. |
27th January 2013, 19:15 | #218 | Link |
There is a bug in this commit:
https://github.com/mpc-hc/mpc-hc/commit/b69c83f4e586068dace96ef7bdadf433891ab73c "File > Open DVD/BD" gives error To fix it Code:
sl.AddTail(CString(Path + _T("BDMV\\index.bdmv"))); Code:
sl.AddTail(CString(Path + _T("\\BDMV\\index.bdmv")));
MPC-HC 2.2.1 |
27th January 2013, 21:53 | #219 | Link | |
MPC-HC Helper xD
27th January 2013, 21:55 | #220 | Link | |
MPC-HC Developer
dxva, media player classic, mpc, mpc-hc |
