8th October 2016, 14:12 | #24981 | Link |
I'm not sure there's anything that can be done. All indicators point to a problem specific to your system, not BD Rebuilder. Sorry.
Something is killing TSMUXER, and there aren't a lot of probabilities beyond disc. Have you run CHKDSK on the working drive? Last edited by jdobbs; 8th October 2016 at 15:10. |
10th October 2016, 01:46 | #24987 | Link |
try here
http://forum.doom9.org/showthread.ph...33#post1663033 or here http://www.videohelp.com/software/tsMuxeR Last edited by gonca; 10th October 2016 at 01:51. Reason: alternate link |
10th October 2016, 03:41 | #24988 | Link |
Just a quickie... (as usual...)
For some odd reason it seems that my last several encodes have come out smaller than usual. I'm using the current version of BDRB and the x264_64.exe from 5012 like JD suggested. Just about ALWAYS before it seemed like all my BD-25 encodes came out to around 22.9 or pretty close. And, as I commented recently, when a movie only is just a tad too big for that, I have set the custom size to about 23.7 which has usually come out on disc about 23.3 or so. BUT... lately all of my encodes are coming out a little smaller. It's not the end of the world or anything, but like the one I just did I was doing a movie only with an original size of about 26 Gigs and this time I left it on BD-25. But, it came out to 21.1 Gigs, which is almost 2 full Gigs short. And, BTW, this is always with 2 Pass encodes. Any ideas as to what might be causing this. I'm using the LAV encoder as I always do. Here are the pertinent parts of the logs to show the sizing, etc: Code:
VERSION=v0.50.18 SOURCE_SIZE=33911894016 SOURCE_VIDEO_SIZE=33911894016 TARGET_SIZE=24641536000 REDUCTION=.726634023696048 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=0 FORCED_SUB_LANG=eng COMPLETED=3 REBUILD_COMPLETE=1 [00600] AUDIO=110000001 PGS=11000000000000000000100000000 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=669406979 RATE=17736 SPLITS=1 NSIZE=0 FLINK=-1 MLINK=0 [00601] APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=42898799 RATE=19465 SPLITS=1 - Input BD size: 31.58 GB - Approximate total content: [01:59:44.176] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Good (Very Fast), Two Pass - X264 Tweak(s) enabled - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [16:46:03] PHASE ONE, Encoding - [16:46:03] Processing: VID_00600 (1 of 3) - [16:46:03] Extracting A/V streams [VID_00600] - [16:51:40] Reencoding video [VID_00600] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 4,778 frames - Bitrate: 17,736 Kbs - [16:51:40] Reencoding: VID_00600, Pass 1 of 2 - [16:53:16] Reencoding: VID_00600, Pass 2 of 2 - [16:54:48] Video Encode complete - [16:54:48] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4360 (eng): Keeping original audio - [16:54:48] Processing: VID_00601 (2 of 3) - [16:54:48] Extracting A/V streams [VID_00601] - [16:54:54] Reencoding video [VID_00601] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 279 frames - Bitrate: 19,465 Kbs - [16:54:54] Reencoding: VID_00601, Pass 1 of 2 - [16:55:00] Reencoding: VID_00601, Pass 2 of 2 - [16:55:06] Video Encode complete - [16:55:06] Processing: VID_00603 (3 of 3) - [16:55:06] Extracting A/V streams [VID_00603] - [17:00:37] Reencoding video [VID_00603] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 167,191 frames - Bitrate: 18,119 Kbs - [17:00:37] Reencoding: VID_00603, Pass 1 of 2 - [17:55:52] Reencoding: VID_00603, Pass 2 of 2 - [18:52:26] Video Encode complete [18:52:26]PHASE ONE complete [18:52:26]PHASE TWO - Rebuild Started - [18:52:26] Rebuilding BD file Structure [18:54:48] - Encode and Rebuild complete Weird... maybe that's why the size was off here, I don't know... Thanks! Last edited by jdobbs; 10th October 2016 at 16:13. Reason: More stuff... |
10th October 2016, 21:17 | #24989 | Link | |
[10/10/16] BD Rebuilder v0.50.17 [08:24:15] Source: X-MEN_APOCALYPSE_00800 - Input BD size: 33.39 GB - Approximate total content: [02:23:56.294] - Target BD size: 7.84 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [08:24:15] PHASE ONE, Encoding - [08:24:15] Processing: VID_02577 (1 of 1) - [08:24:15] Extracting A/V streams [VID_02577] - [09:16:41] Reencoding video [VID_02577] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 207,064 frames - Bitrate: 6,451 Kbs - [09:16:41] Reencoding: VID_02577, Pass 1 of 1 - [14:19:49] Video Encode complete - [14:19:49] Processing audio tracks - Track 4352 (eng): Reencoding audio to AC3... - ERROR preparing intermediate audio. [14:40:57] - Failed to reencode audio, aborted [10/10/16] Checking System Settings - BD-Rebuilder v0.50.17 - Windows Version: 6.2 [9200] - Working Path Free Space: 111.30GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [10/10/16] Systems Settings Check complete |
11th October 2016, 01:02 | #24990 | Link | |
11th October 2016, 02:12 | #24991 | Link |
@ raisingcanex: RE: It's a DTS sound track and trying to reencode it to AC3. In the setup option box. The Do not convert DTS to AC3 box is checked and the Do not reencode the AC3 is also checked. Why is trying to convert and reencode the audio?
You must be trying to do a BD9 to burn to a DVD+DL, if you are using this Target BD size: 7.84 GB. *** Per the Audio Switches in BD_Rebuilder 1. Default (all audio options unchecked) ---- All audio is converted to DD AC3. Bitrate is 640Kbs for 5.1 and 224Kbs for 2.0. ---- All 7.1 sources are down-converted to 5.1 1.1 448Kbs selected -- 5.1 = 448Kbs, 2.0 = 224Kbs 1.2 192Kbs selected, all sources down-converted to 2.0 @ 192Kbs 2. "Do not convert DTS" checked and full-backup, or movie-only and "Strict AVCHD" is not checked: When the source is DTS, the DTS core is extracted and used intact (bit-for-bit). 3. "Do not reencode AC3" checked and full-backup, or movie-only and "Strict AVCHD" is not checked: When the source is Dolby, the Dolby core is extracted and used intact. 4. LPCM is always converted to AC3. 5. Keep HD is always ignored. 6. Setting "OVERRIDE_AVCHD_AUDIO_LIMIT=1" in the INI will allow strict AVCHD to also use DTS. Important note: Choosing to keep DTS on AVCHD output violates the AVCHD standard and can result in a disc that will not play on some players. It is highly recommended that DTS is converted to AC3 for BD-5/9 movie-only encodes. |
11th October 2016, 04:09 | #24992 | Link | |
The only consideration that I would mention, which I have come across in the past is that if your source is SUPER big and complex, you might have some issues with the quality of the picture if you are compressing to a BD5 or BD9 AND trying to keep the full HD audio, or even just the core @ 1500 which can usually take up around 1 - 1 1/2 Gigs. BTW... with disc limitations pretty much irrelevant now, does it REALLY matter to choose a BD5 or BD9 format any more...??? I mean, I can understand and I myself compress Blu-rays down to like 7-10 Gigs many times just to save size for archive purposes, but are the PRECISE 'disc' sizes really that important anymore...? I know that it has been YEARS since I purchased DVD9s or Dual Layer DVDs. And, about the ONLY time I absolutely HAVE to use one (that I can see anyway) is specifically to burn a DVD Audio disc or an SACD disc, because I can't get Blu-ray discs to work in that case. Otherwise, I don't really have a use for them. If I have say 2 or 3 films backed up at crf-18, I can generally fit them on one Blu-ray and use BDRB to create a menu, etc. There ARE many times where I use regular DVD5s for like Xtras only or if I have an encoded DVDrip or something like that, but otherwise in my lowly and wretched opinion I just can't see much reason to use the BD9 sizing, really... |
11th October 2016, 14:15 | #24993 | Link | |
As to your second point -- with the price of BD-Rs as cheap as they are, there's not a lot of reason to stick with DVD-R. I haven't found the need to create an AVCHD disc in a long time. Last edited by jdobbs; 11th October 2016 at 14:17. |
12th October 2016, 06:37 | #24994 | Link |
There are three discs I want to author that will only have one item. How do I get a menu created for these discs? I looked at the various setting GUIs and the INI and HIDDEN text files. Nothing stood out.
I know that it seems silly to have a menu when there is only one item, but I do not want the discs to start playing when inserted. The program on the disc should be started when the user is ready and when to do that is done via the menu. |
12th October 2016, 07:04 | #24995 | Link | |
13th October 2016, 07:24 | #24999 | Link |
Well, that didn't work. I finally got a chance to test it. Mode is full backup. I import the single file and BD-RB immediately went into fetching the file. No menu editing was presented. Changed the mode to Quick-Play Backup and there is no means in which to import anything. No idea what this mode allows anyone to do.
Here is the configuration: Code:
[Options] VERSION=0.50.0.18 ENCODER=0 MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=23500 AUTO_BURN=2 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=0 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AUDIO_DRC=0 DECODER=2 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 MENU_BACKGROUND=H:\LOTR-Fellowship\Fellowshio-Blu-ray-title-bkg.jpg MENU_AUDIO=H:\LOTR-Fellowship\FELLOWSHIP_OF_THE_RING_EXT.ac3 IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=1 MENU_FORCE_QUICK=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 FORCE_NOENCODE=1 MENU_FONT=Aniron Bold MENU_FONT_BOLD=1 MENU_VERTICAL=900 MENU_HORIZONTAL=644 MENU_CUSTOM_COLOR=0x3C97D0 MENU_ACTIVE_COLOR=0x6BC6FF MENU_INACTIVE_COLOR=0x3C97D0 MENU_BACKDROP_OPACITY=255 MENU_ROLLOVER=1 [Paths] WORKING_PATH=G:\BD-REBUILDER\WORKING\ SOURCE_PATH=G:\BD-REBUILDER\WORKING\IMPORTS\LOTR-FELLOWSHIP\ [Batch] MAIN_MPLS=00002.MPLS MAIN_MPLS_ANGLE=0 FORCED_SUB=0 FORCED_AUD=0 AUDIO=111 SUBS=1 |
13th October 2016, 09:18 | #25000 | Link | |
I did some thread searching and found the following:
I'm beginning to get the impression that I can't do this with build-my-own Blu-ray from selected files. |
