Old 25th November 2017, 17:58   #14521  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by pstn View Post
I just tried it on a DTS HD file made with DTS Master Suite:
File ........: C:\Users\pstn\Desktop\track2_eng.dts
You need use a .dtshd just encoded with DTS Master Suite, after mixed in a container the global header DTSHDHDR disapear.
EDIT:
MkvMerge and tsMuxer remove the global header (and end Extrachunks) of a .dtshd just created with DTS Master Suite, but don't apply the delay.
You can't know if you need apply the -21ms or not.
Old 25th November 2017, 19:23   #14522  |  Link
pstn
EDIT:
I see, thank you
pstn is offline   Reply With Quote
Old 26th November 2017, 14:19   #14523  |  Link
tormento
Acid fr0g
tormento's Avatar
Your example seems corrupted.
As FFMPEG seems more resilient, a flag to ignore corrupted frames would be ok.
@turment on Telegram
Old 30th November 2017, 22:21   #14524  |  Link
hubblec4
Matroska Dev-Helper
Hi madshi
eac3to don't find the correct mpls for the Bluray Spider Man Homecoming
mpls 00420 with 16 chapters is missing.
eac3to v3.33
command line: "D:\eac3to.exe" "K:\" -log="E:\Spider Man - Homecoming\title.txt"
1) 00421.mpls, 00001.m2ts, 2:13:28
   - Chapters, 83 chapters
   - h264/AVC, 1080p24 /1.001 (16:9)
   - DTS Master Audio, English, multi-channel, 48kHz
   - DTS Master Audio, German, multi-channel, 48kHz
   - AC3, Turkish, multi-channel, 48kHz
2) 00422.mpls, 0:32:00
   [334+342+343+344+345+346+347+348+349+350+351+352+353+354+355+356+357+335+338].m2ts
   - Chapters, 17 chapters
   - AC3, English, stereo, 48kHz
3) 00353.mpls, 0:16:17
   [342+343+344+345+346+347+348+349+350+351+352].m2ts
   - Chapters, 10 chapters
hubblec4 is offline   Reply With Quote
Old 1st December 2017, 00:54   #14525  |  Link
mtamimi
I have a problem with a movie, the movie plays well w/o issues...However when I tried to convert the audio track I've had some issues...
eac3to v3.34
command line: eac3to.exe L:\Movie.REMUX.BluRay.AVC.DD.2.0.mkv -progressnumbers -log=log.1.txt
MKV, 1 video track, 1 audio track, 1:38:49, 24p /1.001
1: h264/AVC, English, 1080p24 /1.001 (16:9)
2: AC3, English, 2.0 channels, 192kbps, 48kHz
"Stereo"
As you see, it is AC3 2.0 and its 1:38:49...This is correct...Now, extracting...
eac3to v3.34
command line: eac3to.exe L:\Movie.REMUX.BluRay.AVC.DD.2.0.mkv 2:Audio.ac3 -progressnumbers -log=log.2.txt
"Stereo"
[a02] Extracting audio track number 2...
[a02] Creating file "Audio.ac3"...
Video track 1 contains 284321 frames.
eac3to processing took 3 minutes, 48 seconds.
Done.
Now, check this
eac3to v3.34
command line: eac3to.exe Audio.ac3 -progressnumbers -log=log.3.txt
AC3, 2.0 channels, 3:50:24, 192kbps, 48kHz
it reports the file as 3:50:24. If I converted the file to anything, I will have a 3:50:24 long audio track, and it sounds as if it was slowed down...
Can you guys investiate this?
The extracted audio track is here
https://mega.nz/#!9uYFmQJb!Mk3i3QY0G...EQGnNjA8GFv8Sw
mtamimi is offline   Reply With Quote
Old 1st December 2017, 03:47   #14526  |  Link
tebasuna51
tebasuna51's Avatar
The first 8 seconds are 2.0 the rest is:
AC3, 5.1 channels, 1:38:41, 448kbps, 48kHz
Old 1st December 2017, 07:35   #14527  |  Link
XadoX
XadoX's Avatar
@madshi Thx for the Update now I can use PowerShell without probs.
XadoX is offline   Reply With Quote
Old 1st December 2017, 12:16   #14528  |  Link
mtamimi
Great, how did you figure this out? And what is the proper/precise way to trim the audio track ?
thnx
*edit*
I tried to use your utility LaaAudBi4, Avira reported a threat and blocked it...
Old 1st December 2017, 13:05   #14529  |  Link
LigH
LigH's Avatar
Heuristic warnings are usually false alarms, report them to your AV company.
Regarding automatic splitting of AC3 related to a changing channel layout, I am not sure what to do these days; I remember that ProjectX was able to detect channel layout changes, but only in SD TS with MPEG-2 video, it can't handle MKV. HeadAC3he was able to extract time ranges from AC3 files frame-wise, but you would have to know the exact timecodes.
New German Gleitz board
Old 1st December 2017, 14:10   #14530  |  Link
mtamimi
He was able to detect when the change started, so perhaps he uses a utility that will help in splitting the 2.0 track from the 5.1...?
Old 1st December 2017, 14:26   #14531  |  Link
sneaker_ger
Too lazy to test now but maybe you can use delay in this simple case. Something like:
eac3to input.ac3 temp.ac3 -8000ms
eac3to temp.ac3 output.ac3 +8000ms
Or with edit function. I'm sure tebasuna51 will post a proper solution(*) if this doesn't work. (If there is sound then maybe recode the first 8 seconds to 5.1)
(* if you want to regard this as a problem to begin with)
Old 1st December 2017, 14:36   #14532  |  Link
tebasuna51
tebasuna51's Avatar
Try SplitAc3 from https://forum.doom9.org/showthread.p...95#post1447695
EDIT: The sneaker_ger solution work fine because the first 8 sec are silence.
Old 1st December 2017, 19:28   #14533  |  Link
mtamimi
a lot
*edit*
Anyone aware of a utility that helps me to trim the 1st 8000ms of the h264 video. If eac3to is capable of doing that, would someone show me an example?!
Old 1st December 2017, 21:59   #14534  |  Link
sneaker_ger
mkvtoolnix can trim video but it is problematic because of the keyframe limitation. Might need better tool like SolveigMM Video Splitter, VideoReDo or similar. Easiest to just leave the 8s.
Old 1st December 2017, 22:06   #14535  |  Link
LigH
LigH's Avatar
Well, the optimal tool to split audio streams is one that doesn't care about video frames because it handles the audio only.
Old 1st December 2017, 22:08   #14536  |  Link
sneaker_ger
He wants to cut the 8s away altogether (video and audio).
Old 1st December 2017, 22:23   #14537  |  Link
mtamimi
I did add +8000ms to the trimmed 5.1 auido track, and remuxed with the original untouched video and everything is in sync w/o issues. This is also good since I don't need to modify the chapters also...
I am only curious if I decided to trim the video by -8000ms instead of adding +8000ms of silence to the audio track...how can I do that easily?
Old 1st December 2017, 22:30   #14538  |  Link
LigH
LigH's Avatar
But Dolby Digital AC-3 has 32 ms frames (at 48 kHz, with 1536 samples). Fortunately, 8000 ms are an integer multiple of its frame duration. But what if not? Will the duration be rounded up or down to the next audio frame border? It may be (generally) more reliable to split audio streams at the frame boundary between different channel layouts, no matter which duration they have written in seconds and milliseconds.
Old 1st December 2017, 22:46   #14539  |  Link
sneaker_ger
Depends on the software. With mkvtoolnix you can just do "--split parts:00:08-" and it will cut all tracks accordingly and also set delays in container to make precision <=1 ms if cuts aren't exactly on frame boundaries (which - like you said - seldomly align). It's not really a problem anyone should lose sleep about.
Old 2nd December 2017, 12:56   #14540  |  Link
tebasuna51
tebasuna51's Avatar
Cut all tracks of a container without recode (VideoReDo or similar can recode only boundaries) at a exact point need:
- The time point is a exact multiple of audio framelength. Here, with AC3 48 Khz, 8000 ms are 250 x 32 ms, then cut the first 250 frames.
- The time point is a exact multiple of video framelength. If video have 25 fps you can cut the first 8000 / 25 = 320 frames, but you need than the 321 frame was a Keyframe.
With other fps or without a Keyframe at exact point you can't cut exactly without recode.
eac3to
