12th September 2009, 21:32 | #9681 | Link |
I'm having a very strange bug.
Until yesterday, I was using MPC-HC on windows xp (don't remember which version), and it was working great. However, then I decided to upgrade to windows 7. I downloaded the latest MPC-HC from the website, and now I am having a really strange problem. I have a few 1080p x264 videos sitting here, and whenever I get to a point after about 1 hour and 32 minutes, in any of them, they just stop working! If I am using a DXVA decoder, then it crashes. If I use ffdshow, then it simply goes black and audio stops. These videos all play fine in VLC. It's odd, but they all stop working right around the same timecode. Not at the exact same spot, but within a few minutes of each other. When it crashes, there is no error message. It just says the application has stopped working. |
12th September 2009, 21:43 | #9683 | Link | |
12th September 2009, 21:44 | #9684 | Link |
MPC-HC Project Manager
Troubleshooting and bug report
i don't have access to the WIKI.
Here is the new version of the troubleshooting and bug reporting checklist. The idea is that anyone who has a problem goes through the steps from A to I, stopping at the point where the problem is fixed. If someone Reaches I and the problem is still there, then that person posts the checklist on the forum and or tracker. I'm also looking for feedback and additions To find out the cause of your problem, and to make sure the staff is able to reproduce, please follow the following script, fill in the results of each step. Often you will have solved the problem along the way. Only submit a bugreport if you have reached the end, still have the problem and have supplied all the information, screenshots and samples Please fill in the following form, use this as your bug report. Each step is explained in detail below A: Update your system (link here) Windows version: (fill in here) 64bit or 32bit: (fill in here) DirectX version: (fill in here) .NET version: (fill in here) Videocard: (fill in here) Videocard driver version: (fill in here) VC2005 version: (fill in here) VC2008 version: (fill in here) B: Get the lastest SVN build (link here) MPC-HC version: (fill in here) 64bit or 32bit: (fill in here) Last working build: (fill in here) C: Clean the registry and .ini file (link here) Registry cleaned (yes/no) Ini file cleaned (yes/no) D: Make sure you have tested with the internal splitters and filters (link here) Internal splitter behaviour: (fill in here) External filter behaviour: (fill in here) Internal filter behaviour: (fill in here) External splitter behaviour: (fill in here) (Add as many as need to list all being used) Link to splitters/filters screenshot: (link here) E: When using DXVA, report the DXVA caps and file's media info (link here) (you can skip this part if you do not use DXVA) Link to DXVA caps screenshot: (link here) Media info: (paste here) F: Post a screenshot of the internal statistics (link here) Link to CTRL+J overlay screenshot: (link here) G: Provide an overview of settings used (link here) (these settings are not revealed though the previous screenshots) Internal subtitle renderer: (on/off) Subtitle animation: (on/off) Subtitle buffering: (fill in, 0 is off) EVR buffers: (fill in) (only if EVR is used) Shaders enabled: (list here) Resizer used: (fill in here) H: Provide Samples and debug logs (link here) Link to sample(s): (link here) Link to minidump(s) and Debug log(s): (link here) I: Explain in as much detail as possible, the steps we have to take to reproduce the problem: (your explanation here) Detailed explanation A: Update your system Here are the default recommended updates for any windows version (even Windows 7): ---- 1. All available updates on [http://update.microsoft.com/windowsupdate/ Windows Update] 2. [http://www.microsoft.com/Downloads/d...displaylang=en x86 Microsoft Visual C++ 2005 SP1 Redistributable Package] or [http://www.microsoft.com/Downloads/d...displaylang=en x64 Microsoft Visual C++ 2005 SP1 Redistributable Package] 3. [http://www.microsoft.com/Downloads/d...displaylang=en x86 Microsoft Visual C++ 2008 SP1 Redistributable Package] or [http://www.microsoft.com/Downloads/d...displaylang=en x64 Microsoft Visual C++ 2008 SP1 Redistributable Package] NOTE 64bit users have to install both versions 4. [http://www.microsoft.com/downloads/d...displaylang=en Microsoft .NET Framework 3.5 Service Pack 1] 5. http://www.microsoft.com/downloads/d...1-442d8712d553 DirectX End-User Runtimes (August 2009)] 6. Finally update to the latest available drivers for your videocard: ATI - [http://support.amd.com/us/gpudownload/Pages/index.aspx Driver Download]<br> NVIDIA - [http://www.nvidia.com/Download/index.aspx?lang=en-us Driver Download]<br> INTEL - [http://downloadcenter.intel.com/ Download Center] B: Get the lastest SVN build: '''- Download the newest build [http://www.xvidvideo.ru/content/category/1/1/2/ HERE]''' ''(You can also find older builds here for regression testing)'' because the problem might have been fixed in a newer version than the one you are using ''('' '''''[http://mpc-hc.svn.sourceforge.net/vi...c-hc/?view=log Changelog]''''' '')'' - '''MPC-HC build version''', when reporting regressions please name the last working build, also comparisons to other players (even MPC regular) are very welcome C: Clean the registry and .ini file '''- Reset MPC-HC's settings''' ( ''may be incompatible with earlier versions ).'' <br> For the settings stored in the '''registry''' you can manually delete "'''HKEY_CURRENT_USER\Software\Gabest'''" key '''or''' save the following code as ''"'''''clean-registry.reg'''''"'' and run it ''(with admin rights in vista / win7).'' <pre>Windows Registry Editor Version 5.00 [-HKEY_CURRENT_USER\Software\Gabest]</pre> For the settings stored in the '''mplayerc.ini''' or '''mplayerc64.ini''' ''(for the 64-bit edition)'' file created next to the '''mplayerc.exe''' or '''mplayerc64.exe''' ''(for the 64-bit edition)'' open the '''mplayerc.ini''' or '''mplayerc64.ini''' file and delete everything inside except <pre>[Settings]</pre> ''* In both cases MPC-HC will recreate the settings entries on the first run.'' D: Make sure you have tested with the internal splitters and filters '''. <u>''Make sure you're using''</u>''' ''<u>'''only''' (if possible) '''MPC-HC's internal splitters and filters'''</u>'' ''-'' '''TEST''' with GraphEdit or [http://blog.monogram.sk/janos/tools/...m-graphstudio/ GraphStudio] or other Player(s) ( If ) any '''external splitter(s) and / or filter(s)''' (codecs) involved - '''For''' [http://mpc-hc.sourceforge.net/DXVASupport.html DXVA SUPPORT] make sure your '''files''' ''(video stream)'' and '''graphics card''' are '''DXVA compliant''' go to rightmouseclick>filters and make a screenshot by pressing the "print screen" button on the keyboard and opening paint, then paste (CTRL+V) '''- Please upload screenshots to [http://imageshack.us/ ImageShack]''' E: DXVA caps and file's media info Download DXVAchecker and make a screenshot of the main screen '''- A screenshot can be made''' by pressing the "print screen" button on the keyboard and opening paint, then paste '''(CTRL+V)''' '''- Please upload screenshots to [http://imageshack.us/ ImageShack]''' Open the file with mediainfo and copy and paste the information F: Post a screenshot of the internal statistics Load a file, preferably one that has a refresh rate that is a multiple of your screen refresh rate. Open the statistics by pressing CTRL+J, wait about 5 seconds then press CTRL+R, then make a screenshot by pressing the "print screen" button on the keyboard and opening paint, then paste '''(CTRL+V)''' '''- Please upload screenshots to [http://imageshack.us/ ImageShack]''' H: Provide an overview of settings used Internal subtitle renderer option is found at View > Options > Plaback > "auto-load subtitles" Subtitle animation option is found at View > Options > Subtitles > "Disable animation (for slow computers) Subtitle bufferings option found at View > Options > Subtitles > "Sub pictures to buffer" (0=off) EVR buffers option is found at View > Options > Plaback > Output > "EVR Buffers" Shaders are found in Play > Shaders (list all checked shaders) Resizer option is found at View > Options > Plaback > Output > "Resizer" G: Provide Samples and debug logs '''- A sample can be cut with''' - [http://fixounet.free.fr/avidemux avidemux], [http://www.bunkus.org/videotools/mkvtoolnix mkvmerge], [http://www.ffprojects.net/tssplitter/ TSSplitter], or any other ''(Lossless)'' tool. For the "'''HOW TO CUT"''' follow each tool's guide '''- If the bug causes mpc-hc to crash, attach a minidump or upload it it to''' '''[http://www.sharebee.com/ Sharebee]''' '''and post all the mirrors.''' You can make a mini dump by starting mplayerc.exe in a command line ''(with admin rights in vista / win7)'' with the option "mplayerc.exe /minidump". '''- Please upload samples to [http://www.sharebee.com/ Sharebee] and post all the mirrors''' I: Explain in as much detail as possible, the steps we have to take to reproduce the problem:
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
12th September 2009, 21:55 | #9685 | Link | |
Audiophile
13th September 2009, 00:45 | #9686 | Link |
I also have a problem with *.ass subtitles.
By default they are shown in the picture regardless what I do in the configuration. But while playing a file with *.ass subs I can change the position by clicking on subtitles -> styles. There are at least 2 styles with everything but the default set to relative picture position. Changing it only stays changed for the current playback and is lost if I open the file again. I don't know with which version of MPC HC it started as I don't use *.ass that often, but the problem wasn't there several months ago. |
13th September 2009, 01:16 | #9687 | Link | |
the hedgehog
but no problem with .srt subtitles
Athlonx2@2,9Ghz,2G DDRAM2@800Mhz,WinXPSP3 x86,GF8600GTS-256M,Nvidiadrivers 295.73 latest MPC-HC (MVS2010 SP1, GCC 4.7.1) VMR9renderless+VMR9MixerMode+YUVMixing,VSync+AccurateVSync,all GPUflushes on Last edited by gngn; 13th September 2009 at 01:25. Reason: +1 for the post above |
13th September 2009, 01:23 | #9688 | Link |
Mercury, i fixed the wiki access for you.
i have combined all previous documents and updated them These are the new troubleshooting and bug reporting rules: https://sourceforge.net/apps/mediawi...ing_guidelines @Mercury> please help with the formatting again, thanks
13th September 2009, 02:33 | #9689 | Link | ||
13th September 2009, 10:38 | #9690 | Link |
MPC-HC rev.1276 from XvidVideo.RU has a resize bug (VMR9(renderless)) on the system with DirectX Runtime March 2009.
XvidVideo.RU - rev.1276 (DX SDK August 2009) - bug my build - rev.1276 (DX SDK March 2009) - ok |
13th September 2009, 10:52 | #9691 | Link |
MPC-BE DEV
It is necessary to install DX August 2009, and then everything will work correctly!
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
13th September 2009, 11:02 | #9692 | Link |
I noticed this "bug" but if a certain version of dx is required I think mpc should tell the user that and point them to the Microsoft dx page if their version is too old.
13th September 2009, 14:30 | #9693 | Link |
@Everyone,
I think we have found the cause of most lockup's, hangs, crashes and black screen problems. Except for those cases where DirectX needs to be updated obviously. (It appears that the new DirectX version changes behaviour related to scaling, i'm hoping they fixed the stretchrect bug, fingers crossed) There are basically 2 problems: 1. Several threads reading or even modifying the same data 2. Thread B depending on results from thread A, and being excecuted before these results are ready. We need to fix out exactly which types of threads use and modify which data, and which threads depend on results from others. Please help us find the critical points! Thanks!
13th September 2009, 14:32 | #9694 | Link |
Here a signature for MPC-HC beta testers, you can add this if you want to:
[*URL="http://mpc-hc.sourceforge.net/"]MPC-HC[/URL] [*URL="http://www.xvidvideo.ru/content/category/1/1/2/"]SVN[/URL] [*URL="http://mpc-hc.wiki.sourceforge.net/Troubleshooting+guidelines"]tester[/URL]
13th September 2009, 15:11 | #9695 | Link | |
ffdshow user
DWORD WINAPI CAMThread::InitialThreadProc(__inout LPVOID pv) { HRESULT hrCoInit = CAMThread::CoInitializeHelper();<---HERE if(FAILED(hrCoInit)) { DbgLog((LOG_ERROR, 1, TEXT("CoInitializeEx failed."))); } CAMThread * pThread = (CAMThread *) pv; HRESULT hr = pThread->ThreadProc(); if(SUCCEEDED(hrCoInit)) { CoUninitialize(); } return hr; } |
13th September 2009, 19:16 | #9696 | Link |
Hello,
This is a cosmetic bug, but I thought I should mention it: if the playlist is visible and undocked from the player window, when I close and open the player again the player starts with the top part of the window transparent. After play or any window resize, that part becomes normal again. Latest MPC, XPSP3. screenshot at |
13th September 2009, 21:03 | #9697 | Link |
Video artificating/corruption with DXVA H.264 decoder on Intel G45 chip
I recently upgraded to the latest version version of MPC-HC (1.3.1249) and have enabled the DXVA codecs for my Intel G45 based laptop. My laptop, an Asus U81A, has an Intel 4500MHD and appears to be supported. I can decode 720p and 1080p x264 videos using the DXVA H.264 codec, however I see artifacting every 15-30 minutes. The display is overlayed with a green/red blocky tinge which disappears after a few seconds.
I originally thought the issue was due to file corruption. However, the issue does not arise when using CoreAVC for playback. In addition, I found the issue with several 720p and 1080p L4.1 x264 videos, all of which passed MD5 checks ensuring that the files were not corrupted. I used the EVR Custom output mode and used the latest Haali Media Splitter. I am using the 32 bit version of MPC-HC on Windows 7 Ultimate. DXVA also works on MPC-HC x64, however, I have not used it enough to discover whether the problem occurs there. I will test with the internal matroska splitter to see whether the problem goes away. Thanks again for adding hardware acceleration for Intel G45 based systems. It really helps to keep my system cool, and save battery life. I hope I can get this problem resolved, though. If you need any more info, or if I can be of assistance by testing, please feel free to ask. Jason |
13th September 2009, 21:04 | #9698 | Link |
if you guys had to pick an OS from a full reinstallation of a HTPC. Which is the best to pick (with keeping in mind the best for MPC-HC and no-tearing).
XP Vista or Windows7 (which version is the current one?) |
13th September 2009, 21:06 | #9699 | Link | |
If the problem still happens after doing all that report it on the tracker on sourceforge. Also you want to test this special build : http://www.bahnhofbredband.se/~wb118...mplayercgs.exe Please test only 32bit for now.
13th September 2009, 21:06 | #9700 | Link | |
It has the best media foundation implementation
