1st November 2006, 20:43 | #381 | Link |
Question for multi-monitor users. Does AvsP appropriately remember the program's position when it starts up, or does it always start up on the primary monitor? I guess it depends on how your multi-monitor desktop is setup, to either use a single large desktop across monitors or separate desktop units. The reason I need to know is because I want to make sure the separate external preview window shows up on the correct monitor, I may need to dig into more details to get it to work properly.
1st November 2006, 21:36 | #383 | Link |
Just to clarify, you're saying that when you move AvsP to the secondary monitor and close it, the next time it incorrectly starts up on the primary monitor? Another question - does the maximized setting get remembered correctly? I'm not sure how it's supposed to work, for a single large desktop it seems like a maximized program would take up all monitors, but that sounds strange. Regardless, does AvsP show up maximized properly on startup, or does it only maximize on the primary monitor?
1st November 2006, 21:57 | #384 | Link | ||
(!sig) |
2nd November 2006, 16:03 | #385 | Link |
great program, very useful.
But, is there any way of making the user slider move using values of 2 ? For example, ChromaShift(C=-2), and I need to adjust to -4/-6/-8, as you can only use even numbers, would be soo handy to see in a real-time window, as opposed to opening and closing vdub and notepad. |
2nd November 2006, 20:08 | #387 | Link | ||
2nd November 2006, 21:33 | #388 | Link |
Angel of Night
Oh, I just meant doubling everything is one way to make it always even (like [<"c", -8, -4, -6>]*2) but modulo is definitely better, especially when it's built right in. Neato, I missed that feature entirely.
2nd November 2006, 23:50 | #389 | Link | |
New version 1.3.2, download from here or use a mirror from the first post. Here's the changelog:
Another important change is added options to back up the current session. These options are useful if you use filters that tend to hard-crash Avisynth, which in turn closes AvsP abruptly, causing you to lose all your unsaved script changes. You can either backup the current session with the menu command "File -> Backup current session" (default shortcut Alt-B), or use "paranoia mode", which backups the current session every time a new script is previewed (activate under "Options -> Enable paranoia mode"). The session is backed up into the file "_last_session_.ses" in the program directory. This file is automatically loaded when you start up AvsP with no command line arguments - in other words, it won't autoload if you have .avs files associated with AvsP and you double-click an avs file. You can force AvsP to load the last session no matter what in "Options -> Program settings..." under the "Misc" tab. Another change is improved multi-monitor support - this means if you start AvsP in a secondary monitor and close it, it should open in the appropriate monitor, instead of always opening in the primary monitor, etc. However, I don't have a multi-monitor setup, so I don't know if it works as smoothly as I think (or if it even works at all). So any multi-monitor users out there be sure to report any strange behavior and I'll try and fix it. One other bit of news - I released the source for AvsP, it's under the GPL license. I have no real reasons for doing this, I just thought it was only fair since Avisynth is under the GPL license, and without Avisynth there would be no AvsP. The source is included in the zip file, in the "src" directory. You can read the "notes.txt" if you're interested in running or compiling the program. Any questions regarding problems with the source should be in a separate thread or by pm - again, keep in mind I'm not really interested in supporting these types of issues, nor do I believe the source is in a maintainable or even readable form, I'm just releasing it for posterity's sake. Last edited by qwerpoi; 2nd November 2006 at 23:56. |
3rd November 2006, 00:26 | #390 | Link |
Very impressive work qwerpoi . I will check it tomorrow on dual monitor setup.
Is it possilble for you to give a choice where panel with sliders should be (script window or video window)?
(!sig) Last edited by krisq; 3rd November 2006 at 11:05. |
3rd November 2006, 01:36 | #391 | Link | |
Oh, and thanks for the new version, works a treat. |
3rd November 2006, 02:05 | #392 | Link |
FR translation updated
Very nice work again! The separate video window works well, the refresh not focusing on the video is a very good idea Thank you for your hard work qwerpoi, it really pays off I think! Hope you'll have some time to dig through the rest your todolist ^^ btw I don't have 2 monitors, so no comments on this from me |
3rd November 2006, 13:01 | #393 | Link |
AviSynth plugger
qwerpoi,
I will test new version. Thanks for your decision to release a source unde GPL. In my opinion, we now can declare your editor at least as semi-official AviSynth editor I shall update Avisynth documentation to add the info (link).
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 3rd November 2006 at 16:05. |
3rd November 2006, 14:08 | #394 | Link |
@qwerpoi
German translation updated Question Points (behind Instructions (Example :save as...) = an action is not immediately executed ..Is this also so at AvsP ?
Henrikx Last edited by Henrikx; 3rd November 2006 at 15:36. |
3rd November 2006, 18:20 | #396 | Link | |
Bug?
I have copied the exe to the previous version's dir 1.3.1 (where were already the *.dat files) and the slider row + status row was very big and unresizable ... Solution: delete all the *.dat files Can you add an "associate with *.avs extension" switch in the Options? Quote:
Thanks |
3rd November 2006, 19:57 | #397 | Link | ||||||
You are indeed correct, I know about that bug, it's basically a byproduct of programatically sizing windows which don't yet exist coupled with positions from the old options.dat which may not make sense for the new version. I'm still trying to bulletproof the layout code to prevent this type of occurence, but in the meantime, you *should* be able to solve the problem simply by closing and reopening AvsP. If this doesn't work, you can do as chros suggests, you only need to delete the options.dat file, though. Last edited by qwerpoi; 3rd November 2006 at 20:00. |
4th November 2006, 07:04 | #399 | Link |
Angel of Night
You could always start a new project on sourceforge for this. I think it would be really cool, and an svn would make it easy to make patches and stay in sync. btw, I didn't have any problems recompiling following your directions, though I haven't made any changes yet.
4th November 2006, 08:03 | #400 | Link | |
Thanks for the update!
And out of curiosity, did you try compiling using python 2.4 or python 2.5? I never tested with 2.5 so I just wanted to know if there were no problems. Also, how's v1.3.2 with respect to multi-monitor stuff (ie, does AvsP properly remember monitor positions for the main and separate video window)? |
