13th April 2013, 19:43 | #18361 | Link | |
People that either want to calibrate or have already calibrated their monitors already have the values needed for madVR to work. madVR cetainly doesnīt need to offer another calibration solution, because itīs a renderer, but because of that it needs to be able to make use of the calibration results as best as possible for it to work correctly/accurately. Yes, I know that yCMS is supposed to do it, but I donīt like the workflow at all. I already have a calibration package that does itīs job, madVR should only offer something that actually has an added value rather than doing the same things again. I for one would have had (or would have as I am still unsure of my results within madVR) an easier time if madVR allowed either sRGB or offer controls where I could input my calibration resultīs 0% luminance (like 0.10cd/mē) and 100% luminance (80cd/mē) and use that as a base to let madVR calculate from. I am right now completely unsure if my results are accurate. They certainly donīt look accurate. I suspect an error somewhere, but I`m not sure, where exactly and where to search. If I am currently using the black bars/APL clipping test from AVS HD, I donīt have very good transitions between the lower and higher values within madVR (I gave the calibration package the LUT values to work with, which were measured with a Konica Minolta spectrophotometer at the factory to accurately correct the monitors ~2.20 native response to resemble an ideal 2.20 gamma curve), that is by using BT.709 and a 2.20 pure power curve in madVR like suggested. I have a rapid fall-off to black rather than a smooth transition. However, if I am calibrating to a Rec.709 profile with the LUT values I get a somehow brighter response in the darker areas and then going with a BT.709 curve in madVR and 2.20 gamma I am overwriting it with madVRīs gamma correction to a pure power curve between 2.20-2.60 and I suddenly have way better transitions in the 16 (reference black) and 25 values in that pattern, which I can also see in the films/content I watch. Everything just suddenly has a lot more depth to it. More shadow details that werenīt there before. Also, as an added bonus, because of the higher gamma, while I have more detail in the dark areas of the actual film, the black bars are WAY blacker then before. IPS panels have an edge-glow effect that reduce the visible contrast a bit. Even though I have a very good panel with extremely even brightness (max. deviation is like 1,5% in the corners) this offers a better experience in the end, because the corners are darker now. I am not sure why that is. What makes this even more confusing is that outside of madVR (since I calibrated to 0-255 and not 16-235) I have perfect transitions within the dark values. I even decided to buy me a new i1 Display Pro to manually measure again, since it apparently offers more gamma precision than the DTP94B, but that should normally not be needed. But currently I donīt really have any explanation for the results Iīm getting. Last edited by iSunrise; 13th April 2013 at 20:25. |
13th April 2013, 21:00 | #18363 | Link |
Can someone clear something up regarding MadVR and rendering times. When a movie is encoded at say 23.976 fps, and the display device has a refresh of 60hz, and the vsync interval is 16.67ms and the movie frame rate interval is 41.71ms....
What does my rendering times under the Average Stats need to be under? Should I maintain always under the vsync of 16.67ms or the movie frame rate of 41.71ms to not have any problems? Also should I ignore the max stats (5s) since this is usually very high for me. I'm wondering because in order for me to get very low rendering times, I need to usually run DXVA-CB. If I run software decoding, my rendering times are usually much higher depending on the content.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
13th April 2013, 21:35 | #18364 | Link |
Rendering time has to be below frame rate (quite a bit below ideally). Max stats can be ignored if you don't get frame drops/repeats once the video has "settled down" after a start/seek (after a second or so usually).
Obviously if you can render at ~25 ms then you're fine for 24p stuff but not for 25i/30i/50p/60p stuff.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
13th April 2013, 21:44 | #18365 | Link |
So below the frame rate interval correct? So in my example, as long as I'm below 41.71ms (this is the movie frame rate interval) then I'm fine? I don't think you meant if the movie is 24fps, then the rendering time has to be below 24ms?
Edit: thanks DragonQ, I checked some other sources and indeed the higher the file framerate (29.97, 30, etc) then the lower the movie frame rate interval is... So indeed as long as you are lower than the frame rate interval for a particular source, then you are fine. The lower the better.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S Last edited by fairchild; 13th April 2013 at 21:49. |
13th April 2013, 23:30 | #18366 | Link | ||||
It appears that VLC, WMP, WMC use hardware overlays by default and the thumbnails work fine they also allow screenshots and multiple instances. Perhaps the problem is hardware overlays are single output and madvr is it in this case. Seems there are ways to split the output, see http://stackoverflow.com/questions/8...ot-from-my-app
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
14th April 2013, 01:08 | #18367 | Link |
Yes. x64 is not really in madshi priorities right now AFAIK. He already has a "to-do" list so if we're getting a x64 version, it won't be soon. I mean, madVR has been around for years and people don't even talk about x64 right?
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack |
14th April 2013, 07:43 | #18368 | Link | ||
Kid for Today
BTW, I did quite a few changes and the new rendering path would appear to work fine on my 8800GS/306.81/XPSP3 setup after all..I'll now upgrade to the latest WHQL's to be on the safe side.
I'm just extremely annoyed by how hiccupy 24p@24Hz looks on a 10ms(real world measured figure) LCD, when OTOH it looks butter-smooth on a 96Hz CRT(thanks to the sample/hold effect I'd guess?) or a 48Hz DLP(due to MDA's I presume?). I get to see the "naked" individual frames and that's not smooth.....IIRC the 24p cadence was chosen to be the bare minimum off a 48Hz analog projector, not a fairly responsive LCD And sure, this Sammy TV has a 200Hz BFI but the darn thing seems to be living a life of its own and that would not appear to be a 24Hz multiple...I've read ppl complaining about that on their TOTL 800Hz TV's and apparently even their 200Hz models would suffer from the same issue. Just to clear things up, as long as the "dropped/delayed frames" & "presentation glitches" counters remain null, are these the absolute warranty that my PC is outputting a dead-smooth video signal? It's just that 24p judder tests tend to ever so slightly hiccup randomly apparently, and what you call a "presentation glitch" seems to occur rather often with the old rendering path.....I've only seen it once with the new one. I'm just not sure whether I'm seeing the regular 24p judder, my PC is not outputting spot-on jitter or my TV(even in low latency "game" mode) is playing tricks on me There's a price to pay for responsive LCD's, my caveman 46" 48Hz CCFL Hitachi had a slow LCD panel and that nicely blurred 24p I think.. OK, great! And will you also provide a way to set different scalers for SD & HD? The more I think about it, the more it seems videophool to me to splash out on a new graphic card just for 720p J3AR when it's actually the most needed for SD@1080p and that pretty much any graphic card can do that. It's just that constantly rolling scalers is a plain annoyance I also presume that scaling using the CPU would be out of the question? Quote:
This test pattern looks fine on my 2.4 calibrated flat screen LG F900P: This one does not, as <8 levels are just crushed to death: so that means that dark scenes look great of course(you can't beat the blacks of a 20K:1 CRT), but if someone wears a black coat in a bright scene then it's just plain black with no detail whatsoever.....I'm just not sure if the poor thing is busted or if that's by design. Last edited by leeperry; 14th April 2013 at 12:29. |
14th April 2013, 08:32 | #18369 | Link |
I know what you mean with black coats and itīs irritating me every time. I always think thereīs something wrong. I guess that the problem is that coats or other dark clothing behave somewhat strange, even when the surroundings are well lit. Some of them are made out of cloth that just doesnīt reflect much light at all and that looks extremely strange when a person moves. Itīs like a hole in your screen that moves, because you cannot make out any details. Itīs not only coats, though, in Aliens there are also various metal elements that stay almost black (dead) no matter what. It can of course also be related to really bad encodes where theyīve crushed all the blacks. Last edited by iSunrise; 14th April 2013 at 08:49. |
14th April 2013, 08:53 | #18370 | Link | |
But I'm also gonna throw my vote in for a x64 version. It may sound silly, but I don't like running software on an emulation layer by principle, even if it's an excellent one. Filters and resizers for example (used to use ffdshow) are much faster when you can use 64bit and all instruction sets. |
14th April 2013, 11:23 | #18371 | Link | |
14th April 2013, 16:18 | #18373 | Link | |
I want to ask a question for those who knows about calibration and stuff. I'm using an LG Flatron E2260 that has some horrible colors when using the fabric calibration. The only preset that actually makes it more or less acceptable is sRGB (with white balance enabled). My question would be, is this sRGB the best option when available for all monitors or did it just happen to be the more optimal one here?
14th April 2013, 16:23 | #18374 | Link |
Yes, assuming it really is calibrating to sRGB, it is the best setting. sRGB has the same primaries and white point as Rec. 709, which makes it very close to the ideal target for video. The only thing that's (slightly) different is the gamma. sRGB is the standard for computer monitors and in an ideal world all monitors would be calibrated that way from the start.
14th April 2013, 16:54 | #18375 | Link |
Kid for Today
BTW, what are the "present." average/max stats exactly? Jitter that should ideally be null? They don't reset when pressing CTRL+R so that doesn't really help if that's the case
14th April 2013, 17:00 | #18376 | Link | ||
14th April 2013, 17:04 | #18377 | Link | |
QB the Slayer
QB
14th April 2013, 17:44 | #18380 | Link | ||||||
Display the debug OSD (Ctrl+J) and check which queues have which fill state. If you don't know what to look for, just make a screenshot in the moment when frame drops occur, with the OSD on. Quote:
This has been asked and answered multiple times already. |
