9th April 2014, 15:25 | #25821 | Link |
Hello everybody, do you think that we can join BlurayDisc "Mastered in 4k" in their full quality? what settings should I set in lav and madvr? That 's the explanation of Sony :
Sony's 4K mastered BD encodes extra color information into BTB (0 to 15) and WTW (236-255) region. So, there is no changes to BD authoring process, format or bitrates (although these BDs typically use highest possible bitrates). To most players, they will simply throw away the BTB and WTW information and display normal encoding of the movie. It will require special BD firmware to read the extra color information in BTB and WTW and reconstruct the x.v.Color copy of the movie. You also need to be outputting in YCbCr and not in RGB, because x.v.Colour will not work if you are sending RGB. FWIW, the back-cover text on my copy of After Earth says that it is "mastered in 4K" and "Expanded color requires xvYCC-compatible TV and Blu-ray player." My projector is a Sony vw200 with xv colour setting, so my problem is only to set the htpc in the right way. Thank you. Last edited by annovif; 9th April 2014 at 15:28. |
9th April 2014, 15:28 | #25822 | Link |
You're misunderstanding then. Our only problem since the beginning was nvidia breaking their drivers, thus making us revert to a relatively older branch to get nnedi3 working. This was our only problem, and was fixed back when qduaty found a fix. These frame drop problems you're talking about are probably due to the new windowed mode path that madshi has been testing lately, which has nothing to do with nvidia (or at least, no one with AMD has said anything yet. Maybe no one with AMD has tried yet. We could use some more nsamples ) In any case, this doesn't seem like the kind of thing that would arise from vendor specific problems. Could be wrong, but whatevs.
9th April 2014, 15:38 | #25823 | Link |
HTPCs cannot output untouched YCbCr, there is generally always a RGB step in between, so its doubtful this is ever going to work.
9th April 2014, 16:12 | #25824 | Link |
I haven't had much time to test, but I think I found a situation where new windowed fullscreen is worse than old windowed fullscreen. It looks like the new version has slightly lower rendering times, but it starts dropping frames "earlier" (at lower frame times) than the old windowed path.
Try cranking up enough features to have average rendering time close to 1/fps. e.g. on 23.976 fps content, around 40 ms. For me, new path drops frames for the same settings that old path doesn't. (With things turned down more reasonably so we're not skirting the 90%+ render times and the GPU barely keeping up with the source, new path works perfectly.) |
9th April 2014, 16:55 | #25825 | Link | |
Kid for Today
Anyway, my 7850 is giving random white dots when its GPU reaches >70°C and I have to let the board cool down for the dots to disappear even if its GPU went back to 45°C. I would guess that some other key component cannot stand the heat, I'm not too keen on kludging its cooler with a giant fan or buying a grossly overpriced rebadged 7870.....l'll more than likely try my luck with the 750Ti....too bad nobody can confirm how this thing does with mVR Last edited by leeperry; 9th April 2014 at 17:24. |
9th April 2014, 18:27 | #25826 | Link | |
9th April 2014, 18:40 | #25827 | Link |
Kid for Today
Mine is o/c to 1Ghz, and it reaches >70°C when I cap its fans to 20%.......capped to 22% it reaches 67°C and all is well, but within a few weeks it'll be crazy hot in here. Anything faster than 22% is a major deal breaker.
I see 750Ti's selling for as low as 118€ shipped(their power consumption is very impressive and CUVID deinterlacing is so handy), I can sell my o/c 7850 for 80€.....sounds like we have a deal, I'll more than likely order one this evening and will happily report back regarding its results in mVR Last edited by leeperry; 9th April 2014 at 18:42. |
9th April 2014, 18:53 | #25828 | Link | |
So: +100% green −100% red −100% blue (i.e. −100% magenta, being the opposite of green) Would be equal to 200% green. Which should be possible to represent in RGB if you are doing the appropriate color management and have a display capable of displaying that range of saturation. Displays calibrated to Adobe RGB are common with photo editing for example. |
9th April 2014, 20:26 | #25829 | Link |
Troubleshooter
The frame drops when attempting to do image doubling with NNEDI3 have nothing to do with the new windowed mode. The frames dropped doing doubling occurred before madshi put out the windowed test patches.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
9th April 2014, 21:18 | #25830 | Link | |
That sounds like GPU memory overheating or overclocked too high. |
9th April 2014, 21:27 | #25831 | Link |
Kid for Today
Yep, well I just pulled the trigger on this thing: Maxwell shocking debut GTX750Ti/750
Direct-GPU Contact heatpipe & 60W TDP for 118€ shipped sound full of win, time to see how much the AMD interop lag really matters...but either way, sucking up +200W to watch movies is questionnable. OCD has its limits and hopefully its very high power efficiency will make me plenty happy, whatever from a cooling or electricity bill point of view Last edited by leeperry; 9th April 2014 at 21:37. |
9th April 2014, 23:21 | #25834 | Link |
Yes, windowed overlay doesn't work on AMD, Intel and Nvidia only. I think that message says it pretty well. AMD doesn't do overlay, it is not a bug in madVR or AMD's drivers because it is working as intended. Not really a feature either, at least I am not sure the lack of a feature is a feature.
9th April 2014, 23:49 | #25836 | Link | ||
Troubleshooter
