14th April 2008, 14:19 | #1181 | Link | |
15th April 2008, 12:57 | #1184 | Link | ||
15th April 2008, 23:00 | #1185 | Link | |
Main movie with english subs and best audio. I also would like to see this feature if possible. Thanks, Duramaximus |
16th April 2008, 03:03 | #1186 | Link |
I have ripped a few movies (BD50) down to the main movie and the HD audio (DD true hd , DTS master HD, uncompressed LPCM) and they came out to between 26 and 30 GB. With the price of 1 layer BD-RE dropping fast I think it is only a matter of time that this would be preferred rather than burning to a DVD-R. The BD-RE has arounf 22GB of usable space. If you could include that in the fike size options that would be fantastic. Thanks for your great program
16th April 2008, 05:42 | #1187 | Link |
audio channels not decoded right
i created a mp4 for the iphone using the preset profile for audio of 2.0 96kbs constant. the orginal file had audio in stereo (2 channels) but when ripbot was done it created a 6 channel mutli audio file. which of course does not play on the iphone. ive tried it numerous times with diffrent files (all from the same source thou) and the result is the same.
16th April 2008, 07:00 | #1188 | Link |
6 channels from 2 seems impossible in my app How do you know that you get 6 channels?
16th April 2008, 13:49 | #1190 | Link |
i used the properties window out of media player classsic. (its never failed me before). the orginal file posts this:
"Video: DivX 5 320x240 29.97fps 769Kbps [Video 0] Audio: MPEG Audio Layer 3 44100Hz stereo 159Kbps [Audio 1]" The file made with ripbot reports this: "Video: MPEG4 Video (H264) 320x240 [GPAC ISO Video Handler] Audio: AAC 44100Hz 6ch 157Kbps [GPAC ISO Audio Handler]" again i used the iphone/ipod profile for video and then the 2.0 96kbs constant profile for audio. Its an episode of season 2 good eats. I did 12 episodes all of which play on the computer fine but when you trnasfer them to the iphone you get video no sound because its being reported as a muliti audio source in itunes and a 6 channel source in mpc. I tried rencoding the audio in megui with the faac codec (same file that i put into ripbot) and it came out with the correct channels...2. i muxed the audio into the orginal mp4 container that ripbot made and synced it to my phone an it played fine. SO the problem must be with the encoding codec that ripbot uses. Last edited by dejected_is_me; 16th April 2008 at 20:42. |
16th April 2008, 18:58 | #1192 | Link | |
Aac 5.1
The PS3 supports AAC 5.1 in the MP4 container. In Handbrake, there is an option to to take the AC-3 5.1 track and have it converted to AAC 5.1. That way you can just natively play mp4 with full surround and save some bandwith... Thanks in advance sir |
16th April 2008, 21:59 | #1193 | Link | ||||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 16th April 2008 at 22:04. |
17th April 2008, 12:58 | #1194 | Link |
Doh!
Atak,
Sorry for the oversight there. I must have goofed something on the installation, I reinstalled and I see everything now. Sorry for the intrusion, your doing enough improving this awesome app without guys like me slowing you down |
17th April 2008, 13:35 | #1195 | Link |
samples as requested
here is a sample of the video i was working with. the original file was a avi encoded with xvid and mp3. i split it with virtual dub. and as before i put the split file into ribbot and used iphone profile and 2.0 96kbs constant. It reports 6 ch with media player classic and a "mulit" audio source by itunes.
original file: http://www.filedropper.com/orginalstereo encoded file: http://www.filedropper.com/encodedbyripbotturnedinto6ch -dejected |
17th April 2008, 17:27 | #1196 | Link |
н∂-ƒαиαтι¢
^ there must be a problem/conflict on your system. i just re-encoded the original file and here is the mediainfo:
Audio #0 Codec : AAC LC Codec/Family : AAC Codec/Info : AAC Low Complexity PlayTime : 28s 72ms Bit rate mode : VBR Bit rate : 129 Kbps Maximum bit rate : 139 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 44.1 KHz Resolution : 16 bits StreamSize/String : 441 KiB info from your re-encoded file: Audio #0 Codec : AAC LC Codec/Family : AAC Codec/Info : AAC Low Complexity PlayTime : 28s 72ms Bit rate mode : VBR Bit rate : 158 Kbps Maximum bit rate : 179 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Rear: L R, LFE Sampling rate : 44.1 KHz Resolution : 16 bits StreamSize/String : 540 KiB Last edited by ~bT~; 17th April 2008 at 17:29. |
17th April 2008, 21:12 | #1197 | Link |
I also have no problem with that file You must have huge mess in your system. Good advice. Stop using codec packs, ok?
17th April 2008, 23:30 | #1198 | Link |
admitadly i do have the cccp codec pack. but thats all. and now that i watch when the encoding for ripbot is started ffdshow icons pop up in my taskbar for the decoding. from the looks of it aac encodeing is done by the aacplus codec. So isnt the seleciton of codecs handled internally by the program not by the codecs on my machine. Also ive tried the aacplus encoder in megui with the same file and it came out fine.
17th April 2008, 23:55 | #1199 | Link |
I've been using my app for over a year and I have never seen something like this. Like I said get rid of CCCP. Reinstall AviSynth , FFDshow (also uncheck all options in FFDShow Audio section) , Haali Media Splitter. End of story.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th April 2008 at 23:58. |
18th April 2008, 02:50 | #1200 | Link |
you were right. i dont know what about cccp was causing it but hey good to go now. besides between ffdshow, halie splitter and mpc i already installed everything in cccp... so whatever. problem solved thanks for your help
