Old 23rd February 2023, 18:57   #21  |  Link
Grimsdyke
That is most likely the result of years long experiences since the times of Windows 98 with many, many awkwardly authored DVD releases and knewing it won't get much better with blu-ray !!
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using dual-audio-out.
Grimsdyke is offline   Reply With Quote
Old 23rd February 2023, 19:50   #22  |  Link
Klaus1189
Can you post link of release, i buy and test also this special BD
Old 24th February 2023, 20:35   #23  |  Link
Grimsdyke
It's the Shout Factory release from the USA and that would be way too expensive just for testing.
However, the included BD and UHD are identical in contents and so both are effected by this issue. I could send you the BD only and you could then return it after your tests.
But on the other hand, what for ? Alex confirmed in this thread that the issue exists, he is just not interested in fixing this bug.
What I find so surprising is that he and also NEV seem to be not even curious to, at least, look what VLC does better ! I mean VLC is open source, maybe it's just a few lines of code to port and add ?
Well, I am not a programmer so I can unfortunately only report problems.
Old 24th February 2023, 20:58   #24  |  Link
Klaus1189
I want to test. I send pm
Old 25th February 2023, 15:51   #25  |  Link
Grimsdyke
O.K. will send on Monday or Tuesday. By the way, your PM inbox is full
Old 25th February 2023, 16:38   #26  |  Link
Klaus1189
Ok ... and ... Oh ...
Old 28th February 2023, 20:27   #27  |  Link
Klaus1189
I got today, will do it in the next days. Very tired from work now.
Old 28th February 2023, 23:47   #28  |  Link
nevcairiel
This is not the first disc with this problem, I know exactly what the disc does and how it could be fixed. Its just not really worth the complexity to do so in the current design of Blu-ray support in LAV Splitter.
Old 1st March 2023, 13:18   #29  |  Link
Grimsdyke
Thanks for these infos !! So a complete fix would be way too much work for just a few problematic discs and only me annoyed by it Fair enough.
But how about a workaround ? Let's say, just as a thought, LAV sees that the disc HALLOWEEN with a bdmv folder created on 12.08.2021 22:32 is loaded and knows that 00002.mpls is "bad".
So instead it uses a new mpls with a 0000.m2ts + 0006.m2ts + 0005.m2ts sequence. (I mean, I wouldn't care about any issues after the movie is finished ![)
Or maybe a mpls with only 0000.m2ts ?
Again, just an idea as a starting point because I really do not know how many lines and hours of coding this would take..
Old 3rd March 2023, 23:54   #30  |  Link
Klaus1189
tomorrow I test
Old 12th March 2023, 20:11   #31  |  Link
Grimsdyke
@devs - stumbled over this earlier today.
MPLS2JSON.exe
– converts .mpls playlist, .clpi clip information file or .bdjo BD-J object file into human&machine readable JSON file, or
– converts .json file into binary .mpls, .clpi or .bdjo file. This reverse operation can be used for modification of the content of the .mpls/.clip/.bdjo file.
https://forum.doom9.org/showthread.php?t=174563
Old 12th March 2023, 20:21   #32  |  Link
Klaus1189
I just need one more week, I am going to send it back to you next WE
