Old 10th July 2009, 16:10   #1  |  Link
nitinpushpan
Order of filters in AviSynth.
Is there any specific order for using the filters in Avisynth? I'm not sure whether to use UnDot() filter before or after the spatial temporal smoothers like FluxSmoothST() and Deblock() filter? Please suggest a good ordering for the filters. Also somebody please suggest a better filter that performs the same operation than Undot()?
nitinpushpan is offline   Reply With Quote
Old 10th July 2009, 17:13   #2  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Sure order matters, but it depends on what you want to do with your source. Remember (usually) each filter will filter the output of the line before it.
For example:
#Filter 1
#Filter 2
#Filter 3
Filter 1 filters the video first. Filter 2 filters the results produced from Filter 1.
Filter 3 filters the results from Filter 2, which are produced from the output of Filter 1, etc...
For an alternative to undot(), many people use RemoveGrain(2).
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 10th July 2009, 17:33   #3  |  Link
nitinpushpan
So what do you suggest? Should I use it before or after FluxSmoothST()?
Old 10th July 2009, 20:46   #4  |  Link
Adub
Adub's Avatar
The rule of thumb is always: "Do what looks good to you."
But if you want my professional opinion, UnDot() is usually just used to smooth out the irregular "hot" pixels, so I would usually put it first, or at least high up on the filter list.
The reason is that it doesn't destroy a whole lot of detail, and can it's output can allow for better motion compensation down the line.
Site:Adubvideo
Old 10th July 2009, 21:25   #5  |  Link
BigDid
Actually in reserve
Hmmm, is'nt mode1 the equivalent to undot (but quicker)...?
http://forum.doom9.org/showthread.php?t=106413
http://videoprocessing.11.forumer.co...423cc6a950#148
As for mode2 I find it already more destructive than mode5 but, it is my opinion only...
Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first
Want to exchange on AutoGK? try doom10.org
In reserve (inactive) for an undefined period of time.
BigDid is offline   Reply With Quote
Old 10th July 2009, 21:44   #6  |  Link
Adub
Adub's Avatar
It appears you are correct, however, I have always seen people use RemoveGrain(2), and never mode 1. I'm not saying that it's bad to do so, just that it seems to be the general practice to use mode 2.
Site:Adubvideo
Old 11th July 2009, 07:19   #7  |  Link
nitinpushpan
Thanks guys for the useful advice...
Old 11th July 2009, 07:40   #8  |  Link
m3mbran3
Generally I would do something like
deinterlace
crop
resize
degrain
sharpen
Of course it is all user preference but as some filters don't work well with interlaced content you should deinterlace first (if needed). I also find that sharpening after degraining provides better results too.
m3mbran3 is offline   Reply With Quote
Old 12th July 2009, 02:08   #9  |  Link
10L23r
I would do deblock, undot/removegrain, fluxsmooth.
It's mostly "common sense" and experience. Generally, you will want to let each filter have the best input possible. For example, you will not want to resize and then deinterlace/ivtc because the fields will be destroyed.
Here are some general tips:
Don't crop or resize before deblocking. cropping or resizing will shift or blur the boundaries of the blocks, making deblocking less effective.
Cropping/resizing: use "crop(l,t,w,h).xxxresize(x,y)" to remove black borders. use "xxxresize(x,y,l,t,w,h)" if you want to extract a specific part of an image.
Look here: http://avisynth.org/mediawiki/Resize...al_information for more information
Sharpening (usually) amplifies noise, so putting it before a denoiser is (usually) not a great idea.
10L23r is offline   Reply With Quote
Old 16th July 2009, 23:21   #10  |  Link
n0an
Britain's Finest!
n0an's Avatar
deinterlace
crop
resize
degrain
sharpen
Doesn't sharpening in the end produce some noise? I usually use sharpening just after FFT3D(denoising) or degraining and then use a light smoothener or a denoiser to remove the artifacts of sharpening. Does anyone have any better ways?
n0an is offline   Reply With Quote
filters, order of filters, undot
