4th January 2017, 16:41 | #41841 | Link |
Out of those, 23. 23 is actually about 23.976 Hz.
Not MHz, that is a million times faster than the refresh rate.
madVR options explained |
4th January 2017, 16:57 | #41844 | Link |
Necessary? No. If you have frame repeats/drops because of a slight fps mismatch it can fix those. But even without ReClock you may not have any or only very few (e.g. 1 every hour) and you probably wouldn't notice anyways.
4th January 2017, 17:03 | #41845 | Link |
Here ya go. http://forum.doom9.org/showthread.ph...68#post1791968 Last edited by oddball; 4th January 2017 at 17:28. |
4th January 2017, 21:09 | #41849 | Link | |
By the way, was there a update in madvr or dispcal that made 3dlut calibration "cheaper" to run? |
4th January 2017, 21:12 | #41850 | Link |
Debanding on low does very little softening of the image, I use low/low by default on SD material and med/med if there is still banding with low/low. Only high has too much smoothing to use all the time (high is only useful for fades). I usually don't run debanding at a higher strength for fades because fade detection triggers on more often then I would like and I don't have an issue with banding during fades.
Sometimes, the TV will probably report 24p when in both 23Hz and 24Hz modes, but with Windows 24 Hz is usually 24.000 while 23 Hz is 23.976.
4th January 2017, 21:23 | #41851 | Link | |
Personally I see no need to have many many profiles, for common displays size it can all be done with 3 max: SD, HD+FHD, highres+highFPS. As such I use "OR" not "AND" and ">" not "<" or "<=". Also using 1920, 1080 or other specific numbers is a bad idea since many videos are not 1920 but 1916, not 1080 but 1072 or 1200 etc. So I use dimensions that are in between the common resolutions. But if you like managing 10 profiles with the same settings and clicking endlessly for a single change that affects many profiles, have fun and make 20 profiles of which 10 have the same settings most likely. --- NGU... an interesting blend but NNEDI3 seems more efficient even when used with SuperRes and gives less unnatural image. Sure sometimes one looks "better" sometimes the other. NGU decent on quality source but can be a little too "vectorizing" on low resolution low quality source where the sudden vector like edges can look out of place. Nice addition though. Less flexibility with the new GUI options and the scalers to be used after doubling are still not being respected 100% of the time. Try source 4:3 that gets displayed as 16:9, madVR still happily uses Bicubic for scaling one of the luma axis and chroma when everything is set to Jinc and SSIM it simply ignores it as in older versions. The new options only work with sources that have equal AR for the source and display. Don't remove superXBR, it is a decent scaler that runs fast and can be useful especially on the very common machines that do not run an expensive enthusiast class GPU. Quality wise, I guess only waifu2x or similar can do anything better than NNEDI3 but then running waifu2x realtime is a no go XD Last edited by JackCY; 4th January 2017 at 23:44. |
4th January 2017, 21:28 | #41852 | Link | |
Its use is recommended, because banding is noticeable and distracting, and the debanding process is very effective and doesn't have any negative effect on a image without banding. For films : I recommend medium for the default strength and high for the strength during fade in/out. If you want to compare with a source with a lot of banding (off/low/medium/high) : I notice that there is still banding with the low value and the high value is too strong (you lose some details). I don't know the best values for anime (I don't watch anime), but I guess high for both. Last edited by Neo-XP; 4th January 2017 at 21:41. |
4th January 2017, 21:42 | #41853 | Link |
Problem with HEVC 10 bit color
When I use my DVBViewer (or MPC-HC with records) in combination with the latest LAV Decoder and MadVR, HEVC 10 bit UHD channels on Astra 19.2 (HDR and non HDR) get wrong colors, e.g. the skin color is a kind of blue instead of normal. It happens on all HEVC UHD channels.
Is this a known issue? With other renderers (e.g. the EVR custom renderer of the DVBViewer) the colors are fine (but the image isn't as nice as with MadVR beside the color). My GPU is a GTX 960 Here an image (sorry for the content , a sample video I will update later (not at home right now)). I read in the bug tracker about that magenta bug...maybe it's something similar? I guess you can say more when you have my sample, it will come next friday if I don't forget about it. (the image I made a short while ago for explaining someone how to configure MPC-HC (for streaming of a Vu+ and using the hardware decoder eihch VLC didn't do for HEVC) and I told him to use MadVR, but not for UHD yet because of this bug) Kind regards, Clemens Last edited by Clemens; 4th January 2017 at 21:54. |
4th January 2017, 21:50 | #41854 | Link |
Press ctrl+j to see what matrix/transfer/primaries madvr is using and where that info comes from. Press the appropriate hotkeys to adjust if necessary. (Or file name tagging. Not sure if profiles also allow adjusting.)
4th January 2017, 23:10 | #41855 | Link | |
How do you start your rules then? You cannot use "OR" instead when using "<=". I see no reason to use slightly off values for 1920, in fact wouldn't that cause problems? Code:
if (srcWidth > 1024) OR (srcHeight > 576) "720p" else if (srcWidth > 1280) OR (srcHeight > 720) "1080p" else if (srcWidth > 1920) OR (srcHeight > 1088) "UHD" else "SD"
5th January 2017, 01:48 | #41856 | Link |
I've seen a few post on here in regards to profiling. I'll post a copy of my scaling profile auto select rules. Back when I was using NNEDI3 for everything I needed different profiles for 60fps for performance reasons. Many of you who don't have the highest end cards will be in the same boat even with ngu. My profile has 6 scaling settings (I do not have a 4k TV or I would have 8).
Anyone who wants to use this feel free. It works perfectly if (srcHeight <= 711) and (refreshrate < 31) "SD 24fps" else if (srcHeight <= 711) or (fileName = "*.avi") "SD 60fps" else if ((fileName = "*720p*") or (fileName = "*1280x720*")) and (refreshrate < 31) "HD 24fps" else if ((fileName = "*720p*") or (fileName = "*1280x720*")) "HD 60fps" else if ((fileName = "*1080p*") or (fileName = "*1920x1080*")) and(refreshrate < 31) "FullHD 24fps" else if ((fileName = "*1080p*") or (fileName = "*1920x1080*")) "FullHD 60fps" // For release groups that does not tag their files with video resolutions. else if ((fileName = "*[FBI]*") or (fileName = "*[Vivid]*")) "HD 24fps" else "FullHD 24fps" |
5th January 2017, 04:12 | #41857 | Link |
Visual Novel Dev.
Found a free tool that might come in handy for some of us!!!
https://vvvv.org/contribution/windows-system-timer-tool
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
5th January 2017, 04:27 | #41858 | Link |
X Cinema Projectionist NZ
Can you point out something to look at up close in your images please so Im on the right track? |
5th January 2017, 05:31 | #41859 | Link | ||
These images are for all intents and purposes visually identical, the image is being softened throughout the gradients by such a small amount (One of two increments in R,G,B value) That I can confidently say that debanding this accomplishes next to nothing. Last edited by ryrynz; 5th January 2017 at 05:43. |
5th January 2017, 14:07 | #41860 | Link |
Click on the thumbnails on postimg and then you should see the abyssal differences between all of them by just switching from one to another in two tabs, if your screen is correctly calibrated. You don't need any tool or zoom to see this. Of course the RGB values are almost identical, debanding only smooth color gradations so you don't notice them. Last edited by Neo-XP; 5th January 2017 at 14:16. |
