Old 9th March 2009, 23:48   #1941  |  Link
Furiousflea
Originally Posted by deank View Post
Just ask if user is playing NTSC content on PAL SAP or PAL content on NTSC-only stand-alone-player. I'd suggest further bug-reportst to include region version of the player... and in such strange cases I'd doubt complainer has an original disc to "test" with.
I don't think there is a difference between PAL\NTSC in HD world? Only so far as some discs being region coded but that's not going to have a bearing here?
(note the ? marks as I don't know either but that was my understanding(?))
Furiousflea is offline   Reply With Quote
Old 9th March 2009, 23:48   #1942  |  Link
jdobbs
Originally Posted by Furiousflea View Post
Or, just take your grubby mitts off the audio and leave us with 7.1 untouched, only as a temporary workaround of couse
No.
Website: www.jdobbs.net
Old 9th March 2009, 23:51   #1943  |  Link
jdobbs
Originally Posted by Chefkoch_ico View Post
As the author you know that of course. I just add some proof to this.
"Baader Meinhof Komplex", a german made movie has 23.976 fps and 25 fps on the extras and the main movie is 24 fps
The Mux Meta files look like this, for example:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500
V_MPEG4/ISO/AVC, "D:\_BD_REBUILDER_TEMP\WORKFILES\VID_00014.AVS.264", fps=25, insertSEI, contSPS
A_AC3, "D:\_BD_REBUILDER_TEMP\WORKFILES\00014.track_4352.AC3", lang=deu
Bye
I don't get it. I assume this is one of the extras? It looks fine to me. Can you send me all the CLPI files for that disc (zipped)? dvd-rb@dvd-rb.com
[EDIT] Rereading you post... I guess what you were doing was confirming what I was saying? Right?
Old 10th March 2009, 01:09   #1944  |  Link
smnckl
No. They don't. They reencode and remux at the rate of the original. The example you posted just means that the original on that source was 23.976. If you had used a 24fps source it would have said "fps=24".
The light is slowly coming on for me. My bad!
I had assumed that because all the backups I had done were at 23.976, that BD-RB was set to re-encode all movies to that.
Thanks for clearing up the misconception I had.
Vista SP1 32-bit w/4GB RAM
AMD Athlon 64 X2 4400+ @ 2.23GHz
nVidia GeForce 8400GS w/512MB RAM
smnckl is offline   Reply With Quote
Old 10th March 2009, 01:21   #1945  |  Link
smnckl
I too guess he was trying to confirm what you had stated in response to my posting.
However, Chefkoch_ico's description of his BD contents
and his META contents
don't jive.
Being someone who is just dipping his toes in this deep pool of knowledge, I am confused. I hope I am not muddying the waters.
Old 10th March 2009, 02:36   #1946  |  Link
Chefkoch_ico
OMG, I confused more than wanted to help.
Yes, it was just to confirm what jdobbs already wrote.
So all is great with fps
Just examples:
Main movie
V_MPEG4/ISO/AVC, "D:\_BD_REBUILDER_TEMP\WORKFILES\VID_00006.AVS.264", fps=24, insertSEI, contSPS
A_DTS, "D:\_BD_REBUILDER_TEMP\WORKFILES\00006.track_4352.DTS", lang=deu
A_AC3, "D:\_BD_REBUILDER_TEMP\WORKFILES\00006.track_4353.AC3", lang=deu
A_AC3, "D:\_BD_REBUILDER_TEMP\WORKFILES\00006.track_4354.AC3", lang=deu
S_HDMV/PGS, "D:\_BD_REBUILDER_TEMP\WORKFILES\00006.track_4608.sup", fps=24, lang=deu
Bonus #1
V_MPEG4/ISO/AVC, "D:\_BD_REBUILDER_TEMP\WORKFILES\VID_00004.AVS.264", fps=25, insertSEI, contSPS
A_AC3, "D:\_BD_REBUILDER_TEMP\WORKFILES\00004.track_4352.AC3", lang=deu
Bonus #2
V_MPEG4/ISO/AVC, "D:\_BD_REBUILDER_TEMP\WORKFILES\VID_00018.AVS.264", fps=23.976, insertSEI, contSPS
A_AC3, "D:\_BD_REBUILDER_TEMP\WORKFILES\00018.track_4352.AC3", lang=deu
Although I have not tried the finished disc (yet).
Bye
Chefkoch_ico is offline   Reply With Quote
Old 10th March 2009, 03:10   #1947  |  Link
smnckl
And I was asking for help with Der Rote Baron!
I thought so... but the little on my shoulder made me stir it up more.
Thanks for the clarification. I'll get on topic before I get struck.
Old 10th March 2009, 07:00   #1948  |  Link
rmeyers
easiest way to check fps, is to do a BDInfo scan of your bd folder. it shows the fps of every playlist/stream.
rmeyers is offline   Reply With Quote
Old 10th March 2009, 07:20   #1949  |  Link
pacificdune
How to run multi threaded?
Having a problem with encoding speed. When I originally started using BD rebuilder I was getting 25-30 FPS and all 4 cores on my Q9450 were at 100% load. Now I'm only getting one core at 100% load. Any idea how I can get back to 4 threaded operation?
Probably a simple setting, but I'm stumped.
Thanks!
PD
pacificdune is offline   Reply With Quote
Old 10th March 2009, 10:43   #1950  |  Link
Furiousflea
No.
oooohhhh new smilies
Old 10th March 2009, 12:58   #1951  |  Link
Biffa001
Originally Posted by Biffa001 View Post
Hi - great program for full backups, but I tried to do a shrink of my Tinman BRD and I get a box popup saying "x264.exe stopped working", after closing the box 3 times (I think) it retries 3 times then gives up. Here's the log
The same happened with the latest version of BD_Rebuilder as you supply it and also with an updared x264.exe from their website.
Hope you can solve this for me!
Noone got a clue why I get the error "x264.exe stopped working" ? Pretty Please?
Biffa001 is offline   Reply With Quote
Old 10th March 2009, 13:04   #1952  |  Link
jdobbs
Have you ever gotten any successful encodes before, or is the first attempt?
Most of the time when X264 fails it is because AVISYNTH cannot decode the video source. Make sure you have all necessary codecs enabled in FFDSHOW.
1. If you have Windows Media Player 11 installed (highly recommended) on your system, disable VC-1 decoding (letting the system default to WMV11), else set it to WMV9.
2. Make sure MPEG2 is set to LIBAVCODEC
3. Make sure H.264/AVC is set to LIBAVCODEC
Old 10th March 2009, 13:53   #1953  |  Link
Chefkoch_ico
Originally Posted by Capsbackup View Post
@jdobbs,
Looks like you may have corrected the problem I was having with Nights In Rodanthe with this "BD-RBV02003" latest release. I just copied over the BD-RB.exe, since I kept the previous workfiles, and rebuild completed successfully this time, no more error " CorrectMPLS() 00009 5".
Thanks for your continued excellent work, efforts and diligence on this program. Just to be certain, I will completely redo the whole movie with this new release, and report back.
EDIT: I guess I spoke too soon and should have tried to play the movie first. Though it did "Rebuild" successfully, the movie does not play after burning to disc. Only intro warning plays, then no other video plays. I will redo the whole project fresh and see how it goes. Sorry for my premature/optimistic report, but hopefully there will still be success!
Hi!
I still get this error "CorrectMPLS() 00009 5" on "The mummy 3" german version with BD-RB 0.20.03.
Should it be already fixed, or is it the same problem than before?
Best regards
Old 10th March 2009, 14:58   #1954  |  Link
mikebzh44
Hello,
I'm using this soft to shrink my MKV to BD5 or BD9.
What I'm doing :
MKV -> tsMuxer -> BD structure -> BD Rebuilder -> BD Structure -> DVD-DL
Everything is OK except that my MKV is in 1280x528 instead of 1280x720.
If I play my DVD on my PS3, the image is at the top of the TV with a big green bar under it. I suppose that the green bar is due to the lake of the borders.
How can I recrop my video ?
I have found the fucntion AddBorders under AviSynth but I don't known how to user it.
I make this script :
DirectShowSource("G:\BLURAYDISC\l age de glace 2.mkv")
AddBorders(0, 96, 0, 96, $000000)
I use MeGUI (input : script / output : MKV file) but the result file was very small (under 500 Mo)
Can you help me ?
Maybe you could add an option in BD Rebuilder to force resolution to 1920x1080 / 1280x720.
mikebzh44 is offline   Reply With Quote
Old 10th March 2009, 15:00   #1955  |  Link
archie_here
Originally Posted by archie_here View Post
[22:13:37] BD Rebuilder v0.20.03 (beta)
- Source: 35990120_FEWGOODMEN
- Input BD size: 36.83 GB
- Approximate total content: [02:18:01.272]
- Target BD size: 4.27 GB
- MOVIE-ONLY mode enabled
- Resuming from previously started job.
[22:13:38] PHASE ONE, Encoding
- [22:13:38] Reencoding: VID_00141 (1 of 1)
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[22:13:41] - Failed video encode, aborted
[Options]
MODE=1
QUICK_EXTRAS=0
PRIORITY_CLASS=1
RESIZE=0
TARGET_SIZE=4369
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
TRELLIS=1
COLOR_BOOST=0
RESIZE_1080=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=0
AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
ENCODER=0
VERBOSE_STATUS=0
[Paths]
SOURCE_PATH=E:\FGM\35990120_FEWGOODMEN\
WORKING_PATH=E:\WORKING\
Any suggestions?
archie_here is offline   Reply With Quote
Old 10th March 2009, 15:02   #1956  |  Link
jdobbs
See post #1952
Old 10th March 2009, 16:56   #1957  |  Link
Furiousflea
Originally Posted by mikebzh44 View Post
Hello,
What I'm doing :
Can you help me ?
BD-Rebuilder isn't for converting mkv videos to bluray, it's for people to backup their bluray collection so they can keep their originals in a safe place.
Old 10th March 2009, 17:14   #1958  |  Link
mikebzh44
Oh yes ??? Sorry !!!
Everybody is doing legal staff here
Old 10th March 2009, 17:24   #1959  |  Link
Furiousflea
It's up to you what you do - lega or otherwise. Reason I said it though is because that is what the author of the software is concentrating on. There are still lots of problems with some unprocessed bluray sources and it would open a whole can of worms to start pandering to anything that isn't a genuine valid bluray rip. no disrespect to yourself. I'm pretty sure this is the official stance from jdobbs.
If you post in one of the other forums you should be able to get help there, but I think this thread is purely for posting bugs for bluray sources.
Someone correct me if I'm wrong though.
Old 10th March 2009, 17:30   #1960  |  Link
Protecus
LIBAVCODEC or LIBMPEG2
First of all thank you, jdobbs, for this great software. I wrote a german tutorial how to make a Blu-ray backup with 'BD Rebuilder'. I always set MPEG2 to LIBMPEG2 and also described this in my tutorial. Now I see that you recommend LIBAVCODEC.
I don't want to tell something wrong in my tutorial, so could you please tell me what the diference between LIBMPEG2 and LIBAVCODEC is? Yet everything went fine with my Blu-ray Backups by using LIBMPEG2.
Greets,
Protecus
Protecus is offline   Reply With Quote
