12th February 2009, 17:21 | #1221 | Link | |
VC-1 decoding is enabled in FFDSHOW. Here is the verbose report: ----------------------- [15:01:53] BD Rebuilder v0.18.8 (beta) - Source: GALAPAGOS_UK - Input BD size: 21.67 GB - Approximate total content: [02:26:52.937] - Target BD size: 7.72 GB - MOVIE-ONLY mode enabled [15:01:53] PHASE ONE, Encoding - [16:15:14] Collecting video information [00001] - Error [01:-1] returned from encoder. Retrying. - Error [02:-1] returned from encoder. Retrying. - Error [03:-1] returned from encoder. Retrying. - Reached retry limit. Aborting. [16:18:25] - Failed video encode, aborted Here is the contents of lastcmd.txt "C:\Documents and Settings\XXXXXXXX\Desktop\BD-RBV01808\BD_Rebuilder\tools\x264.exe" "C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.AVS" --crf 16 --output NUL I've also attached some screenshots of the contents of the galapagos blu-ray disc stream folder and what is displayed by BD rebuilder when it reads the ripped disc folder to clarify the situation. thanks Last edited by YolkiePolkie; 12th February 2009 at 17:30. |
12th February 2009, 17:24 | #1222 | Link | |
Long term compatibility may be a tricky issue for all of us, but for those with only a PS3 it will likely be a bit more complicated. When considering a new standalone, PS3 owners may want to stay in the Sony family, or at least they make sure they buy a player that fully supports AVCHD. |
12th February 2009, 17:56 | #1224 | Link |
I'm thinking it may be saturation, but Dark Shikari would be a better source for that information (he's probably the most prolific developer for X264). I know I ran a test encode last night with the intent of putting a single LOST episode on a BD-9, and found the output to be only 5GB. I ran it again with a BD-5 target and it sized very exactly. I made the assumption that it was encoder saturation -- but didn't follow up by looking at any of the logs.
12th February 2009, 17:57 | #1225 | Link |
I'm still waiting for someone to run the failed encode from the command line using LASTCMD.TXT so I can see what we're getting... just the word "crash" alone doesn't give a person a lot to work with. I've already gotten at least 10 of those reports on the new release.
12th February 2009, 18:25 | #1228 | Link |
I have tried what you said (I'm still waiting for someone to run the failed encode from the command line using LASTCMD.TXT so I can see what we're getting) but get no info when the error happens.. do i need to rerun with VERBOSE STATUS REPORTING on before seeing the error report?
Also i dont have vc-1 decoding on in FFDShow as at the min i get around 16fps but if i put it on i get arounf 0.35fps... do i need it on ? |
12th February 2009, 20:52 | #1229 | Link | |
What I don't understand is why it is happening to you but not to me? Can you also post the contents of INFO.AVS? |
12th February 2009, 21:54 | #1230 | Link |
Well I also had the x264 crash but only on one title.... It did a fine job a couple nights ago on The Secret Life of Bees, but had the same crashing as Yolkie when I attempted Pride & Glory last night.... I then overwrote that x264.exe with the exe from 0.18.07 and it appeared to encode fine, but when I awoke this morning BD-RB had completely shut down and exited, with only about half of the encoding done???
Anyways I reloaded the current x264.exe back into 0.18.8 and attempted a different movie, SpaceBuddies, and the current x264 no longer crashed. Just FYI, Pride & Glory is VC-1 encoded..... but GaPony stated that he was successful on this title a couple nights ago already?? Not sure what to think at this point.
MBK |
12th February 2009, 22:47 | #1231 | Link | |
#Created by BD Rebuilder - v0.18.8 (beta) DirectshowSource("C:\BLU-RAY RIPS\GALAPAGOS BLURAY RIP\GALAPAGOS_UK\BDMV\STREAM\00001.m2ts", fps=29.97, framecount=88260, audio=false) LoadPlugin("C:\Documents and Settings\XXXXXXX\Desktop\Copy of BD-RBV01808\BD_Rebuilder\tools\decomb521.dll") FieldDeinterlace(blend=false) Tweak(0.0,1.1,0.0,1.0) WriteFile("C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.INI",""" "[Options]" """) WriteFile("C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.INI",""" "framecount=" ""","framecount") WriteFile("C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.INI",""" "framerate=" ""","framerate") WriteFile("C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.INI",""" "width=" ""","width") WriteFile("C:\BD9S\GALAPAGOS H264 BD9\WORKFILES\INFO.INI",""" "height=" ""","height") ConvertToYV12() trim(0,-1) Regards, YP |
12th February 2009, 23:01 | #1233 | Link |
x264 kept saying it was crashing for me with a VC-1 disc so I had to turn it on in FFDShow and it dropped to about the same speed, for a full disc back up it took 12 days, it was either that or it got no where because of crashing
12th February 2009, 23:46 | #1234 | Link |
I gotta' tell you. If I had to wait 12 days for an encode, I'd probably just buy an extra copy of every movie... more likely though, I'd buy a new computer. You must get tired just from shoveling coal into the rear of that one.
12th February 2009, 23:48 | #1235 | Link | |
12th February 2009, 23:50 | #1236 | Link | |
12th February 2009, 23:53 | #1237 | Link | |
13th February 2009, 00:22 | #1239 | Link |
OK jdobbs, I put back the X264 executable and started the encode of Hancock again. When the x264 error poped up I left it hang. Went into lastcmd to get you the last command.
"C:\Users\Wayne Cierkowski\Desktop\Blu-Ray Tools\BD_Rebuilder\tools\x264.exe" "E:\BLU-RAY WORKING\WORKFILES\VID_00123.AVS" --bitrate 4651 --level 4.1 --sar 1:1 --aud --vbv-bufsize 14500 --keyint 24 --min-keyint 1 --vbv-maxrate 17500 --filter 0,0 --subme 2 --me hex --bframes 3 --8x8dct --direct auto --weightb --trellis 0 --analyse none --threads auto --thread-input --progress --no-psnr --no-ssim --stats "E:\BLU-RAY WORKING\WORKFILES\VID_00123.AVS.264.stats" --pass 1 --output NUL What should I do now....
3 - VMC's - Each has a Quad processor with 8 GB's memory 2 - Dells 1 - Built from scratch |
