5th February 2009, 01:56 | #1041 | Link | |
Or was yours just a single m2ts movie? I used TSSplitter to join the multiple AVS.264 files w/ the AC3 audio, then remuxed with TSMuxer and the resulting BD-9 plays without skipping also. But if I use only TSMuxer to join and remux, then the resulting BD still skips on the PS3s.
MBK Last edited by MikeyBK; 5th February 2009 at 02:02. |
5th February 2009, 03:38 | #1042 | Link |
Hi, I have been using BD-RB for awhile now and for some really strange reason when I use v0.17.13 Movie only encodes work perfectly on my Panasonic BD-30. anything after that build, no matter what combination of choices I make in the app, not 1 Disk has worked on my standalone Player.Like I said I have made many tests with options on and off, even ripping with anydvd with different options on and off and still not 1 disk plays. When I revert back to v0.17.13 all is perfect once again. so there is def something changed in version 0.18.07 and it is driving me crazy!
5th February 2009, 03:57 | #1043 | Link |
@jdobbs
In the BDREBUILDER.INI are 2 lines regarding subtitles. Code:
[Options] MODE=1 QUICK_EXTRAS=0 PRIORITY_CLASS=1 RESIZE=0 TARGET_SIZE=7910 VERBOSE_STATUS=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all TRELLIS=1 COLOR_BOOST=1 DTS_REENCODE=0 AC3_REENCODE=1 AC3_640=1 AVCHD=- AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 [Paths] SOURCE_PATH=G:\EIGHT_BELOW\ WORKING_PATH=D:\REBUILDS\ I know that subtitle selection has been disabled in the GUI but I would like to have that option. I tried using "none" in place of the default "all" but that did not work.
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
5th February 2009, 04:10 | #1044 | Link | |
I would rather have a solid conversion tool versus which subtitle I want in the movie. Just my .02 cents.
3 - VMC's - Each has a Quad processor with 8 GB's memory 2 - Dells 1 - Built from scratch |
5th February 2009, 06:34 | #1045 | Link | |
5th February 2009, 06:43 | #1046 | Link |
Video Maniac
Greetings Again jdobbs From Ds9delta
I Have Just Tried An Encode Of Matrix Revolutions From 34.3G To 23G First Of It Is Still Being Undersized Roughly A GB From Target Size And Second For The First Time Ever It Skipped On PowerDVD! I Have Tested Everything I Have Done With 18.7 With PowerDVD Using DAEMON TOOLS To Mount The Image Before Burning And Testing On My Standalone.. All Have Worked... Until Now When I Checked The Completed M2TS Did Play Fine In Windows Media Player But In PowerDVD The Movie Played For 6Seconds Then Video And Audio Freeze And A Minute Later 9Seconds And So On And So Forth... I Have Attatched The BD-RB Setup Files... P.S. Would Love To Be Able To Keep DTS-HD\PCM In The Next Version... PLEASE! And Always For The Great Work
5th February 2009, 12:43 | #1047 | Link |
I set a film going again yesterday morning, it just had the main movie to encode as all extras have been done over the last week or so.
This morning I get up it says 100% progress on pass 2/2 but is 9 frames less (156270 / 156279), x264 is taking up 100% of the CPU. This was 2 hours ago and nothing has changed. If I look in the WORKFILES folder the x264 file has a last modified date of 3:54AM this morning but adds about 30mb to it's size every 10 minutes or so, it's only 8Gb so I assume it's got a while to go (shrinking it all down to 25Gb BD-R) since the WORKFILES folder is only 12Gb in size at the moment. Is it meant to do this or has something crashed? screenshots: EDIT: 6 hours later and it still says exactly the same, CPU is still at 100% and has been unusable all day, the files size in the 264 file keeps increasing and is now at 13.6Gb, I'm assuming it's doing the 2nd pass but the percentage never reset to 0 after the 1st pass! Last edited by mmace; 5th February 2009 at 18:42. |
5th February 2009, 20:07 | #1048 | Link |
Found a bug, which i think may have been touched on:-
Have done full back up of Taken (BD-25) - some extras don't work, reason being is that they only have french language as audio, and BD Rebuilder has automatically stripped them, maybe if a variable was added that ensured every stream retained at least 1 audio track, this would sort it. Also this film came in over 2 gig undersize?? Its no biggy for now because the copy i have of this film is defective (No Forced English subs for French speaking parts!!! Somebody has fudged up big time). Will try again when i get a Retail copy. |
5th February 2009, 23:42 | #1049 | Link | |||
I was just wishing that it was maybe possible by editing the REBUILDER.INI or one of the .avs or .meta files. It could save quite a bit of space which could be used to get a higher bitrate for the movie. Just as Capsbackup requested yesterday in post #1030. @Capsbackup: didn't mean to pull you into this. Quote:
Have a good one.
6th February 2009, 00:27 | #1050 | Link |
Skipping problems
Just want to post the results of skipping problems I have had. On the movies I am having the skipping problem they all skip on the PS3 and will not load on the Panasonic BD55. The movies that don't skip play on both. The movies that do skip work fine when played on the bluray player in the computer and do not skip. So its not the burn. I have tried different brands of media and burned on different burners with the same result "skipping in the PS3 and work fine in the computer" I have tried using versions 17.13 & 18.07.
6th February 2009, 05:36 | #1051 | Link | |
I was also able to get a working BD9 of Ghost Town using this approach. It only has one AVS.264 file and an audio track. The .m2ts file rebuilt by BD-Rebuilder v0.18.07 skips on the PS3 (it worked with an earlier version). The .m2ts file rebuilt manually using TsMuxer does not. Again, I was able to do this without playing around with the pulldown. |
6th February 2009, 13:47 | #1052 | Link | |
Kinda odd as well is that BD-RB uses TSMuxer as you did to remux the workfiles into BD structure AFAIK.... so why'd it work for you and not in BD-RB?
MBK |
6th February 2009, 13:48 | #1053 | Link |
finally got Mamma Mia shrunk, burnt it to a BD-RE and tested it (full back up)
the intro plays, the warnings play, the menu works, the pop-up menu's work none of the videos play, they are just black (the pop-up menu works when it's playing nothing) all the m2ts files play fine on my PC but not when it's put together as a BDMV, it's a BDLive disc if that makes a difference? using latest (25th Jan) version of BD-RB |
6th February 2009, 14:48 | #1054 | Link | |
Any help? What has changed? How about reporting: What movie? What does the INI say? Was it a multipart movie? Is there anything unusual about the activity you see? Movie only, full backup? This is a beta test release, I need reports that give me something to work with. So far all I'm getting is "It worked in 0.17.13... well I compared the encode and remux commands and they are the same except for multi-part encodes... can someone try a single part encode and tell me whether it works? Last edited by jdobbs; 6th February 2009 at 14:51. |
6th February 2009, 15:06 | #1055 | Link | |
Mummy 3, which is a single m2ts BD, also skipped when using 0.18.07... EDIT: (just wanted to clarify that the skipping was on PS3s only, my Sony BDP-BX1 played all discs prefectly.) I think we're kinda finding out that it's not an encoding issue, but rather a remuxing issue. DarWun and I were successful remuxing either the AVS.264 or m2ts files from the workfiles folder. We both did this with Max Payne workfiles. He was successful using TSMuxer only, I was not with TSMuxer only, but I was if using TSSplitter to join first and then TSMuxer to remux. He usde the append command to join his multi files in TSMuxer while I used the 'add' tab. He was also successful remuxing using Ghost Town workfiles using TSMuxer, which had only a single m2ts.
MBK Last edited by MikeyBK; 6th February 2009 at 15:10. |
6th February 2009, 16:14 | #1057 | Link | |
Have you changed anything else? Are you using the version(s) of software that were included with BD-RB? I'm pulling my hair out on this one -- and frankly after working on it for a while I don't have any spare hair to lose... It would help immensely if we removed all outside software (like TSSPLITTER) from the process and only used TSMUXER for the muxing. That is all that was in use in v0.17 -- and all reports are that it worked then. I'm tempted to go out and buy a PS-3 -- but unfortunately the donations have been pretty thin, and I simply can't justify it. My wife thinks I'm crazy for spending this much time on freeware it as it is... Last edited by jdobbs; 6th February 2009 at 16:20. |
6th February 2009, 16:51 | #1058 | Link | |
I only used TSSplitter to try and salvage one of the BD-9 encodings since my daughter has a PS3 and would be using that to view these BD-9s on... and I prefer not to have her use the original Blurays discs. As for versions of TSMuxer with BD-RB, I only use the versions you include in your set-up files. I do have standalone version of it but did not overwrite your included version with my standalone version. I'm not sure what to add as to why the 0.18.07 encodes skip on the PS3s now??? Wish I could offer more feedback to you so that you could have more to work with in figuring out what changed. As for donations... sorry to hear that they have been sparse... I'll be sending you a donation (EDIT: Donation Sent) and hope that starts a new wave of them.... and I call upon all those who are benefitting from this great program to donate what they can to help you out.... Come on guys, let's help JD out here....
MBK Last edited by MikeyBK; 6th February 2009 at 17:15. |
6th February 2009, 17:14 | #1060 | Link |
Finally able to post after 5 day wait.
I'm sending you a donation, so that should help some. I appreciate your work on this. My goal is to do a movie only backup to BD-25. I've tried Eagle Eye and Prince Caspian, but I get the error extracting audiosubs that was mentioned a few pages back. I read your comments then and have tried enabling all the languages used in the subs and still get the same problems. It happens with movie only and with full backups. Any other suggestions? (I'm at work now, so can't post log file, but the log output looks pretty much the same as the others that were reporting the problem.) Thanks, Jeff |
