17th September 2017, 17:37 | #45701 | Link | |
But the colors don't look -completely- washed out. I have that problem with Windows' HDR when going full-screen, it will wash out the image entirely. But what I'm seeing with my 980Ti is different; it's not completely washed out. It looks like a normal blu-ray film with the added brightness (nits). Here's a good example of what I get: WCG disabled. http://www.rtings.com/images/reviews...dard-large.jpg And here what it should look like, WCG enabled. http://www.rtings.com/images/reviews...-hdr-large.jpg |
17th September 2017, 17:59 | #45703 | Link | |
AMD: https://abload.de/img/amd480madvr7xyv0.png NVidia: https://abload.de/img/480mesbt.png Is it me or there is Chroma offset? I did make sure to use Jinc for Chroma and Luma scaling. Last edited by Kotik; 17th September 2017 at 18:05. |
17th September 2017, 18:12 | #45705 | Link |
in this image AMD. and before i forget check the image processing page in the CCC or what it's name is now.
@aufkrawall the microphone stand is the only part where YADIF clearly wins vs NVIDIA. the wrong chroma position could create a bunch of problems too. |
17th September 2017, 18:23 | #45706 | Link | |
@Huhn what do u think regarding YADIF vs AMD? I wanted to upgrade from my AMD to an NVidia card, if YADIF will give me similar results with AMD i will be happy to proceed otherwise i will have to sit and wait until AMD releases a single slot, low profile RX card....... NVidia has already GT 1030 out and it perfectly fits my HTPC case. |
17th September 2017, 18:32 | #45707 | Link |
if you want to update to a 1030 i recommend you to not update if you really don't need to.
none RX cards run amazing fast with madVR often outperforming nvidia cards in the same price range by quite a lot. if the chroma position get's fixed i don't think YADIF stand a chance against nvidia. but i'm not going to find out deinterlacing isn't that important to me. on the still image nvidia wins in my book. |
17th September 2017, 18:33 | #45708 | Link |
Spatially that AMD result looks nice especially very solid reconstructed the String the Microphone Pole the middle and top part no aliasing left overall much better then the current Nvidia result and look it even keeped the specular better preserved on the Microphone top as well on it's bottom before the cable goes into it the whole angle of it was better processed, it was clear they improved they continuously do since some time now it would be nice to see HD Graphics results as well now from Kaby Lake
But we really need to find the same setups without any interfering factors and i think we should try to get Samples in Motion done for each spatially is nice but without seeing results in Motion it's semi efficient to judge it @Kotik The new Vega Nano will be a beast not cheap but a beast. And your result looks really good it wouldn't even matter whats the cause anymore it just beats any of the others currently spatially and yes there is a visible offset it shifts the whole red lamp The cullprit are the strings best reconstruction result is definetly your AMD result here it does everything better then Yadif and Nvidia as a whole Yadif has master problems with keeping the strings Nvidia does better but your result tops both on the strings reconstruction amazing result at the same time your result keeps overall everything that yadif does + more We need a Football field compare
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 17th September 2017 at 19:41. |
17th September 2017, 19:34 | #45713 | Link | |
Deinterlacing for me is half the content during my daily usage of HTPC so it is important. But my HTPC case has enough space for Low Profile and 1slot size GPU, as you can understand my options are limited. Currently got R7 240 and been waiting for a year for AMD to release something and they came up with RX 550 LP but this one is a two slot card....... So i got two alternatives, either wait until AMD comes up with something new and hope it is single slot and low profile or get GT 1030 which doesnt impress me with the deinterlacing. Is the chroma shifting a madvr issue or is it a driver issue? Last edited by Kotik; 17th September 2017 at 19:59. |
17th September 2017, 19:43 | #45715 | Link | |
(if i press ctrl-r the dropped frames goes to 0, if i reopen the file i've dropped frames again). I tried to restore madvr settings, not touching anithing but always some frames dropped.
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM |
17th September 2017, 19:44 | #45716 | Link |
looks like no not a madVR issue. i get the same in MPC-HC.
so we are pretty much out of luck here a bug in madVR get's fixed a driver bug can take "forever"... nvidia has the chroma shift not AMD just to make that clear. i would never get an polaris card for madVR they are terrible at NGU. |
17th September 2017, 19:45 | #45717 | Link | |
or just post a screen with the OSD. |
17th September 2017, 19:47 | #45718 | Link | |
17th September 2017, 19:55 | #45719 | Link | |
i gonna download it myself looks like a nice test case
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 17th September 2017 at 19:59. |
17th September 2017, 20:07 | #45720 | Link | |
https://drive.google.com/file/d/0B32...ew?usp=sharing this was created using JRiver MC23 64bit, but the 32bit version has the same issue: MVC3D playback does not switch to FSE. It does in MC22 without issue. thanks |
