Old 7th September 2005, 13:22   #601  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
To have the possibility to load avisynth scripts (avs files).
Old 7th September 2005, 13:48   #602  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
I need input plugin source
dimzon is offline   Reply With Quote
Old 7th September 2005, 18:59   #603  |  Link
dimzon
dimzon's Avatar
Kurtnoise13
I develop BeSweet encoding plugin framework. So some AAC+v2 arguments are changed. I think it's much better to use such engine bcz it's easy to develop and add new encoding plugins
So You must use new AAC+v2 arguments syntax in your nice GUI...
Old 7th September 2005, 19:03   #604  |  Link
Kurtnoise
Kurtnoise's Avatar
oo my...you're too fast.
Old 8th September 2005, 13:51   #605  |  Link
adoniscik
Does 0.22 beta 6 even work in batch? I tried to convert some files from WAv to AC3 and it got confused. I think it only processed the first file.
adoniscik is offline   Reply With Quote
Old 8th September 2005, 14:32   #606  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Batch is really confusing.. I think that all files in the list are merged into one file, but I'm not sure. Also BeLight crashes every time after:
Open 1.wav from File menu - Convert
Open 2.wav .. convert
and so on... convert
Click on the X to close .. and crash (access violation)
my subtitle site
dwrbudr is offline   Reply With Quote
Old 8th September 2005, 15:13   #607  |  Link
dimzon
dimzon's Avatar
Kurtnoise13
Can You add support for my FAAC BeSweet encoding plugin with AAC/MP4 output?
Old 8th September 2005, 16:19   #608  |  Link
Kurtnoise
Kurtnoise's Avatar
Yes it's buggy...sorry. I need to fix it.
Sure...but check my reply in your thread.
Old 8th September 2005, 16:27   #609  |  Link
Inc
Squeeze it!
Inc's Avatar
You could have a look at makeavis.exe sources from ffdshow.
it (I dont know exactly) takes the audio from the avs and serves it via vfw the audiodata (also maybe to stdout) ... so a vfw API command like AviFileGetStream() #StreamTypeAudio and AviStreamRead() could serve the needed audio bytes.
Inc is offline   Reply With Quote
Old 8th September 2005, 16:51   #610  |  Link
dimzon
dimzon's Avatar
I need BeSweet input plugin source...
Old 8th September 2005, 16:54   #611  |  Link
dimzon
dimzon's Avatar
Kurtnoise13
Can I help You in BeLight development? I have 5-year Borland Delphi experience (in the past)
Old 8th September 2005, 18:15   #612  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Me too (in present time)
Also the GUI resizing is quite broken
my subtitle site
Old 8th September 2005, 18:59   #613  |  Link
Kurtnoise
Kurtnoise's Avatar
Kurtnoise13
why not...grab the last sources in the cvs and just do it. There are some bugs to fix.
I'm creating the unicode version right now. Anyway If you want to speak about BeLight development, I prefer to have your ideas or suggestions directly in the Dev BeLight Forums.
It's fixed now AFAIK.
Old 8th September 2005, 19:54   #614  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Umm...
my subtitle site
Old 12th September 2005, 18:41   #615  |  Link
dimzon
dimzon's Avatar
Kurtnoise13
Seems like CLI API is finalized now!
Please add support for my plugins into new version of BeSweet.
Thanx!
Old 12th September 2005, 20:42   #616  |  Link
Kurtnoise
Kurtnoise's Avatar
Yep...i'm working on it. I already added Faac and Speex settings in the code. Now I need to fix some few bugs reported in the lastest weeks and I'll release a new beta.
Settings for lossless encoding are planned.
Keep up the good work.
Old 15th September 2005, 09:23   #617  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
I would like to recommend a setting for Below Normal priority in the main menu(as default) and I think it will be nice to have a check mark in the priority menu to see what is the current priority. The priority settings should be saved too
my subtitle site
Old 15th September 2005, 12:10   #618  |  Link
Kurtnoise
Kurtnoise's Avatar
What's about "idle" ? And by default I'll keep "Normal" priority.
Yes..it's done.
Done too...
Old 15th September 2005, 12:22   #619  |  Link
dimzon
dimzon's Avatar
You can add support for my AAC+v2 plugin based onto 3GPP reference encoder.
Command line will be:
-dimzon( -dllname bse_enhAacPlusEnc3GP.dll <options>)
options:
-cbr <bitrate in bps> Default is 64000. Range is 8000-65535
-mono - for mono encoding
Output wil be in mp4 container!
Old 15th September 2005, 14:08   #620  |  Link
tebasuna51
tebasuna51's Avatar
I don't konw if is more difficult to make a input plugin than a output plugin for BeSweet, but I think BeLight-BeSweet must support aac, mp4 like input files.
Now, for test and compatibility purposes, I use ffdshow (non-stable versions), foobar (broken: 5.1 -> 8 channel ?), aacdecdrop (lose SBR inf), Winamp diskwriter (limited to stereo output), ...
It's possible, with the knowledge and availability of Dimzon or others users not so busy than DspGuru, a input plugin with a decoder at least SBR compliant (better also with PS)?
