Old 13th February 2009, 10:22   #1041  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Build 376:
* Added charsets 77 and 177
* Title font is now selectable in Authoring
I added more than 40 fonts for you to choose of. I tried to add all kinds of font-scripts - Cyrillic, Greek, Hebrew, Arabic, Chinese, Japanese...
If for some reason fonts don't work for you or menu lines are not aligned with the navigational arrow - use Courier New.
Dean
p.s. The tutorial/guide is updated. Download links in first post updated to build 376.
Old 13th February 2009, 10:30   #1042  |  Link
~bT~
н∂-ƒαиαтι˘
how to make font options stick?
edit: which option do i edit to change the navigation arrow colour dean?
edit2: nvm, i found it
Old 13th February 2009, 11:25   #1043  |  Link
siopilos
Yesterday I bought the Panasonic DMP-BD35 Blue Ray.I have a mkv file (Magadaskar 2) 4Gb(size).
Can i use multiAVCHD to make a dvd witch be able to play on my blue Ray player???
siopilos is offline   Reply With Quote
Old 13th February 2009, 11:26   #1044  |  Link
deank
deank's Avatar
Forum rules (esp #6) forbid discussing downloaded material. Edit your post.
Old 13th February 2009, 12:21   #1045  |  Link
marax
Guys, one question
If I have video in 2 parts but subtitles in one part, so do I must divide the subtitle file in two parts also right or is there any easier solution, can I add files as APPEND instead ADD in multiAVCHD? It will be a good feature.
Anyway, great program.
Regards
marax is offline   Reply With Quote
Old 13th February 2009, 14:05   #1046  |  Link
vpapanik
Can you also add the Impact font ? I am pretty sure it's going to work as well. I wonder why you don't include the full font list (just tile the custom title font), and let us choose what is working or not. There is always the solution of courier after all
vpapanik is offline   Reply With Quote
Old 13th February 2009, 14:16   #1047  |  Link
deank
deank's Avatar
No, not all fonts work and I can't add all, because each font requires specific offset setting to make first letter of a title to be positioned next to the navigational arrow. It is different for each font.
I'll add impact too.
Old 13th February 2009, 14:22   #1048  |  Link
vpapanik
Thanks mate This font is ideal for 'Lost' hehe
Old 13th February 2009, 15:18   #1049  |  Link
deank
deank's Avatar
Build 379
* Impact font added
* Input playlists handling is re-written
* Initial release to support multiple playlists in imported AVCHD folders
If imported AVCHD folder is:
*** created with multiAVCHD (builds 343+) title names will show automatically in Title editor
*** created with older multiAVCHD - title names will be set to "Older multiAVCHD compilation title#xx" in Title editor
*** not created with multiAVCHD - - title names will be set to "AVCHD compilation title#xx" in Title editor
NB! At this point if such folders/compilations with multiple playlists are added - YOU SHOULD NOT use UP/DOWN/DELETE buttons in Media tab or title names will get messed.
If input AVCHD folder has ONLY ONE TITLE (PLAYLIST) you can proceed as before and edit/rearrange media items in Media tab.
You can see if a folder is created by multiAVCHD in Media tab:
[m] - multiAVCHD compilation
[d] - AVCHD folder
[f] - MKV/TS/MOV/MPEG file
Also you will see information in LOG tab for imported folders.
Please share your experience on this.
Dean
Old 13th February 2009, 16:36   #1050  |  Link
asherungar
Hi Dean!
i finally got hebrew subtitles to work when using multiAVCHD in mac (with crossover) - it all had to do with language settings in crossover iteslf (similar to the option of "default language for non-unicode programs" in XP's language settings). now i use the 177 code page and subtitles show fine, even menu titles can be written in hebrew.
so, if there are any other non-english users over there on mac who need this: here's how to set up language in crossover:
http://www.codeweavers.com/support/d.../faq#id2501616
(question 2.8)
Keep up the good work!
asherungar is offline   Reply With Quote
Old 13th February 2009, 16:39   #1051  |  Link
deank
deank's Avatar
I'm glad it worked
There are about 5 Hebrew fonts in Authoring to use for title names also. I hope it works
I added this link to multiAVCHD_Mac.txt in the installation file archive.
Old 13th February 2009, 17:02   #1052  |  Link
asherungar
actually multiAVCHD_mac.exe is not needed, with crossover multiAVCHD.exe works fine.
even updates, there's an error in the end - but it works even with the error..
Old 13th February 2009, 17:04   #1053  |  Link
deank
deank's Avatar
What is the error? I'm planning on discontinuing _mac.exe so it will be helpful to know what is the problem.
Old 13th February 2009, 17:18   #1054  |  Link
kenguru2005
FinalCut´ter
kenguru2005's Avatar
I never had success with auto update using crossover. When starting the normal exe (not mac_exe) I got dozens of errors. I never tested again since at least 10 builds. This evening I will test again and then report the erros.
So please dean: keep on with mac_exe for a while.
kenguru2005 is offline   Reply With Quote
Old 13th February 2009, 17:20   #1055  |  Link
deank
deank's Avatar
Probably there is an option to allow network access for win32 executables, running under Crossover. Please check. And let me know what errors occur.
Old 13th February 2009, 17:29   #1056  |  Link
NirvClub
Originally Posted by siopilos View Post
Yesterday I bought the Panasonic DMP-BD35 Blue Ray.I have a mkv file (XX) 4Gb(size).
There is a guide here which explains how to convert an MKV file to AVCHD and burn it to a standard DVD. It works on the BD 35.
Dean is working on a solution for multiAVCHD so you can run the AVCHD video directly from an SD card and play it on the BD 35, instead of having to burn it to DVD.
NirvClub is offline   Reply With Quote
Old 13th February 2009, 18:19   #1057  |  Link
asherungar
i already posted about the error at the end of the update, but here it is again:
"DownloadInFile: fWrite: (RT) invalid parameter - Line 132".
but it does download and update the main .exe.
Old 13th February 2009, 18:20   #1058  |  Link
cmcmill01
I have been able to burn some MKV files using multiAVCHD and imgburn and they play on the BD35. Other files start for about 1 second and then stop again. Not sure why there is a difference, so tyring various orginal MKV files.
cmcmill01 is offline   Reply With Quote
Old 13th February 2009, 18:24   #1059  |  Link
deank
deank's Avatar
Is this when multiUPDATE.exe runs or when multiAVCHD.exe?
Old 13th February 2009, 18:31   #1060  |  Link
asherungar
when multiUPDATE runs (because multiAVCHD automatically opens it)
