Old 11th February 2009, 18:20   #981  |  Link
vpapanik
Thanks for the excellent additions in authoring tab. Is it possible to easily create a 'preview' option for the menu image ?
PS. The custom 'Top Menu Title' and corresponding font is not saved in the .ini file. Furthermore, the 'Credits Info' cannot be edited (build 362).
vpapanik is offline   Reply With Quote
Old 11th February 2009, 18:41   #982  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Originally Posted by kenguru2005 View Post
A really helpfull feature would be the possibility to add additional .ac3 files to be muxed into those .ts/.mov./.mkv files, which are to be authored.
Can you do some tests with build 363?
Option is added in "Advanced" tab:
[x] Add external audio tracks
If checked - AC3/PCM/LPCM audio tracks named after video (video_file.mts -> video_file.ac3 or video_file.pcm or video_file.lpcm) will be added to final compilation
Old 11th February 2009, 18:45   #983  |  Link
vpapanik
A few more things (build 362) :
1) The default titles are still trimmed to 7 characters ! (strange) It does it all the time for any .mkv filename.
2) The program always creates 14 menu arrows irrespective of the number of .mkv files included. The empty arrows point to the intro screen. (note : I am previewing it in Nero Showtime, I don't know whether it is a problem of multiAVCHD or not).
3) Is there any way NOT to show the intro screen, and go straight to the menu ?
4) Dots '.' do not appear in the menu preview tab.
5) Is it easily possible to increase the max 37 characters for menu entries to 50 ? And use a better font than courier, e.g. Lucida Console (I understand that there has to be a courier type font in order to control the menu entry length).
6) I think than 1s 295ms is too long for the first SRT line. I tested 300 ms and works fine, while values lower than 50 ms scrambled the subtitle sequence.
Old 11th February 2009, 18:59   #984  |  Link
deank
deank's Avatar
Yes, but in SAPs and PS3 there is no way to see the unused positions... That's the way it is.
Yes. I think adding these options in authoring are more than enough for now. Once free version expires then it might be possible.
Did you ever try or just love to ask questions?
multiAVCHD will show title names up to 60 characters and it is since its initial build. What you see in the program window (37 chars only) is because there is no space to show more. If you click on a title you will see that it has its full name and it will be used when menu is generated.
About the font - I'll check if LC or any other font works with the menu.
Preview - it is possible.
Old 11th February 2009, 19:10   #985  |  Link
vpapanik
That's fine. I keep using Showtime because it is faster for testing minor things.
You are right. Looking forward
You are right, it was not obvious that it internally kept the full title. A full preview option will help on this, or just a scrolling listbox that contains full 60-char titles.
Thanks a lot for your efforts. Donation raised
Old 11th February 2009, 20:16   #986  |  Link
Tineg
A small bug in build 361 : when .mkv files are added, their default menu title is truncated to 7 first characters. e.g. 'Lost S05E01.mkv' becomes 'Lost S0'.
The problem still occurs with the build 362 except if you edit the title with the edit function in Media Tab.
It's no big deal but...
Thanks and Good luck .
Tineg is offline   Reply With Quote
Old 11th February 2009, 20:22   #987  |  Link
deank
deank's Avatar
I can't replicate this problem...
Does it happen with all titles?
Does it happen after you edit a title name in "MENU" tab?
Do you actually see the truncated name when you play the compilation?
What do you see in details.txt/multiMENU.txt/multiAVCHD.txt files in the output folder?
Old 11th February 2009, 20:55   #988  |  Link
vpapanik
Tried :
Lost S05E01 -> becomes Lost S0
Prison Break S04E01 -> becomes Prison Break S0
hmmm... there is something wrong after character zero '0'. Is it set as a delimiter maybe ?
No, in the very beginning, when you add the .mkv files
Yes
* Lost S0 (in details.txt)
Lost S05E01.mkv (in multiAVCHD.txt)
Lost S0 (in multiMENU.txt)
Hope that helps.
Old 11th February 2009, 21:05   #989  |  Link
deank
deank's Avatar
Can you try with build 366? Are you using localized version of Windows?
Old 11th February 2009, 21:07   #990  |  Link
vpapanik
It seems there is a clear pattern for the error. Some examples may help :
abcd efgh.mkv -> 'abcd'
abcdefgh.mkv -> 'abcd'
12345678.mkv -> '1234'
Hello World.mkv -> 'Hello W'
HelloHelloHello.mkv -> 'HelloHelloH'
Build 365, Windows Vista
Old 11th February 2009, 21:09   #991  |  Link
vpapanik
366 didn't solved the problem.
Windows is Vista Business, English, with Greek regional settings.
Old 11th February 2009, 21:14   #992  |  Link
gemad9
It's been quite a few builds since my problems were solved so I thought I'd give 366 a ride and try some of the features that were added over the last week. For me it's perfect (on a Sony SAP)!
Great job!
gemad9
gemad9 is offline   Reply With Quote
Old 11th February 2009, 21:14   #993  |  Link
deank
deank's Avatar
Yes, it cuts the last 4 letters for some reason and it doesn't happen with my files... try again with build 367
Old 11th February 2009, 21:15   #994  |  Link
~bT~
н∂-αиαтι
Tried :
i can confirm this bug.
and also dean, force 16:9 is not working...
Old 11th February 2009, 21:16   #995  |  Link
vpapanik
Well done !!! Solved
Old 11th February 2009, 21:16   #996  |  Link
~bT~
н∂-αиαтι
working fine now so what was the issue?
Old 11th February 2009, 21:19   #997  |  Link
deank
deank's Avatar
A stupid typo (and it happened with my files, but their names were too long to notice)
And about 16:9... multiAVCHD can only set values for 16:9... nothing else... If you find a way to make your files play in 16:9 I'll implement it... I did a lot of tests and PS3 just does not comply...
Old 11th February 2009, 21:30   #998  |  Link
vpapanik
It would be also nice if the fonts for 'Top menu title' and 'Credits info' could be saved in the .ini file.
Old 11th February 2009, 22:01   #999  |  Link
~bT~
н∂-αиαтι
so what resolution would you recommend me to encode WS NTSC SD content at to stay AVCHD legal..
720*480 as u are aware displays @ 4:3 AR.. and anamorphic flags are not recognised.
Old 11th February 2009, 22:13   #1000  |  Link
deank
deank's Avatar
I didn't do it on purpose.
Yes, but AVCHD standard says that you can have 720x resolutions both 16:9 and 4:3, so we are missing something.
Can you send me a sample video of your encodes? I have captures of 720x576 (PAL) 4:3 and I can't make them play 4:3 - they play horizontally stretched in my PS3 - so I have the opposite problem
Dean
