10th February 2009, 18:21 | #963 | Link |
Programmer (or just 教务长)
Everyday it seems complete for the goals I set for myself.
To-do list: * AVCHD split (allowing (for example) 15GB bluray movie only rip to go into 2xDVD9 or 4xDVD5 discs or just to a USB disk for Playstation3) * Add content to existing multiAVCHD generated output * Compatible output for Panasonic TV/BD SD cards playback Last edited by deank; 10th February 2009 at 18:30. |
10th February 2009, 19:04 | #964 | Link |
[QUOTE=kenguru2005;1247743]Done with mac via crossover: look at this nice ß
kenguru, how did u get the custom menu work on mac - im also using crossover but multiAVCHD says there's a problem with x264/avisynth. how does crossover work with them? i get a menu but not custom. thanks |
10th February 2009, 21:35 | #967 | Link | |
But when I launched the build 361 I admit it was sad to see that only 19 had already donate. I haven't a Paypal account but I'm sure that I'll donate for this very good job. Thanks Dean |
10th February 2009, 21:38 | #968 | Link | |
FSNAVI |
10th February 2009, 21:42 | #969 | Link | |
We move forward to new horizons. |
11th February 2009, 02:52 | #971 | Link | |
I've put the DBMV folder(real stream removed) here in case you have chance to take a look. Thanks. http://rapidshare.de/files/45137286/BDMV.ZIP.html |
11th February 2009, 10:23 | #972 | Link |
You can uncheck [x] Delete temp files and check yourself the TEMP folder... open .meta files and you will see how they are generated. I can't do anything else - sorry. Try using multiAVCHD in Wine....
11th February 2009, 12:10 | #973 | Link | |
i will do the same project in windows and mac and will try to find the difference. Thank You! |
11th February 2009, 15:34 | #975 | Link | |
*** Build 362: * I wonder how no one reported this bug: Blue and red channels were swapped (because of AviSynth) and colors for menu titles and outline didn't work as expected It is fixed now * All entry boxes will now allow you to use characters, specific to the code page / character set you select in tsMuxer tab. For example - now I can enter title names, welcome screen message and menu headline/credits in cyrillic. * More options in Authoring tab - probably most of you will like it a lot. - You can now change the title of multiAVCHD menu to anything you like - You can now change the font used for the title and bottom credits - Top menu title and bottom texts (version/site/date-time) will use the color you select for "Menu font color" but top title will have 40% decreased luminosity and bottom texts will have 70% decreased luminosity (both will be a bit dimmed) * Menu is now encoded in 1080p (opposed to "interlaced" for former builds) Dean Last edited by deank; 11th February 2009 at 16:08. |
11th February 2009, 16:46 | #977 | Link |
It can be done easily if .AC3 files are named after the imported file...
for example if you have test.mov and test.ac3 in the same folder (and an option checked) - multiAVCHD will include it in the final output. |
11th February 2009, 17:51 | #979 | Link |
Hi dean,
i just made a multiAVCHD (this time on windows) of the 6 star wars episodes (about 50G!) anyway, i made a custom menu, and the arrows work but clicking on a title just sends me back to the menu again - doesnt jump to the title even if i "jump to title 1" (on PS3). what went wrong? using v361. thanks |
11th February 2009, 17:54 | #980 | Link |
I can't say... post your log and check your output folder.
Try again with one episode and use [x] Verbose logging to see what happens. ONE THOUSAND POSTS Last edited by deank; 11th February 2009 at 18:03. |
