24th December 2006, 05:17 | #201 | Link |
Well if most people are getting around/less than 4fps, that's fine. Just wanted to make sure I wasn't the only one.
Thanks for all of your assistance.... this was really helpful. I don't have 1GB+ of ram. I have 2x512MB running @ DDR2-916. (Overclocked my Core 2 Duo E6300 to 3.2Ghz.) I'll try some other bobbers and see if the quality gain is proportionate to the time spent. I might not be one of those people where quality is worth it at any expense. Regards, Steve77 |
24th December 2006, 12:33 | #202 | Link | |
Formerly davidh*****
David |
24th December 2006, 13:16 | #204 | Link |
I'm working on a program that will break an AviSynth script up into sections and farm it out to multiple machines (which must have AviSynth, plugins and codecs installed). I've proved the concept - now I just need to write the control program.
David |
24th December 2006, 13:20 | #205 | Link | |
But about encoding - or you plan to work with uncompressed material? Or parts will be for several frames to process them parallel and combine to one part every second and compress with encoders (MPEG4 or other) in realtime |
24th December 2006, 13:42 | #206 | Link |
I'm not quite sure what you mean...
Each machine will compress (or not, as you choose) it's own segment. Then they can be brought together in another AVS script. To save disk space I will probably use Xvid at 10mbps - with a script as slow as mcbob, the extra time spent encoding won't matter. Perhaps this thread http://forum.doom9.org/showthread.php?t=119436 would be a better place to continue the discussion David |
25th December 2006, 19:12 | #208 | Link |
http://forum.doom9.org/search.php?searchid=1429307 or: http://www.google.de/search?q=median...le-Suche&meta= Last edited by krieger2005; 25th December 2006 at 22:07. |
25th December 2006, 23:06 | #209 | Link |
Hello all,
Thanks for your help with MCBob.... now I'm looking for MVBob. I've scoured the forums and simply cannot find the script for it. Could sombody point me in the right direction? Regards, Steve P.S. I'm currently processing some material that has frames that are partially interlaced (PAL source)... I used a smart-bobber (TDeint) and it did an ok job of it. Is there a better way of going about these? |
25th December 2006, 23:15 | #210 | Link | |
Derek Prestegard IRL
If you are planning on doing something like this, I would strongly suggest that you not use a lossy codec like Xvid, but instead a lossless codec like huffyuv - or something newer like lagarith / ffv1 / msu lossless. This will make a big difference if the user is going to encode the result of your program to Xvid or x264. MPEG-4 is very lossy and is not suitable as an intermediate codec. ~MiSfit
These are all my personal statements, not those of my employer :) |
26th December 2006, 02:16 | #211 | Link |
Angel of Night
I find Xvid with the EHR matrix, at q2 (or q2/3 with b-frames), makes an excellent replacement for ffv1 at about the same speed, nearly a third the size. The main problem is that ffdshow ignores packed bitstream, so non-linear editing with it is painful; don't use b-frames if you try it.
You can spot artifacts by flipping between the original and the encode at 200%, but I doubt they'd be enough to affect a final encode. |
26th December 2006, 03:43 | #212 | Link | ||
likes to tinker
Thanks anyway, however
Any suggestions ? |
26th December 2006, 16:49 | #214 | Link |
You can get the most recent v0.84 of MedianBlur from here:
http://www.64k.it/andres/dettaglio.php?sez=avisynth (medianblur_25_dll_20050119.zip) It's also included in the latest package of scharfis_brain's MVBob.
26th December 2006, 17:34 | #215 | Link |
HDConvertToX author
@Didée
64k.it/andres is my site i hope i haven't broke any licenseses... i use it as a repository/mirror (i will glady give account/password to avisynth/filter developers to upload/update filters) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
26th December 2006, 18:22 | #216 | Link | ||
Look at the first post of that thread. |
26th December 2006, 22:48 | #217 | Link |
likes to tinker
Well blow me down, thanks krieger2005. For some reason that 1st post blew up on be when I tried to download it previously; now it works when I tried it again just then. Sorry about that. Also many thanks to Didee and bizzqw for the repository.
Cheerio. |
27th December 2006, 15:42 | #218 | Link |
XviD User
I actually do the same thing on most of my material and it works very well. Got a new Panasonic DV Cam recently and I'll be curious how it performs with that source :-)
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2 |
28th December 2006, 00:49 | #219 | Link |
Hello all,
I posted a day or 2 ago about finding the MVBob() script. I looked all through these forums as well as googled many combinations of mvbob.avs, mvbob() etc. Could sombody just post the contents of the script for me please? I have some hybrid material and TDeint leaves some residual combing. MCBob did the job, but took 11h for a 30 minute clip. Any help would be GREATLY appreciated. Regards, Steve |
28th December 2006, 01:14 | #220 | Link |
2 Days? Bad searching! It took 20 seconds to find
http://home.arcor.de/scharfis_brain/mvbob/mvbob.rar - even in this very thread. Amount of residual combing after MVBob is similar to TDeint, TDeint perhaps even less. To securely avoid residual combing with either one, reduce thresholds. Zero should be perfectly secure.
