7th September 2007, 02:06 | #2961 | Link |
Mr. Sandman
well, probably it's not worth spending time on a function it is going to be replaced.
however that could be a suggestion for bautodeint...
7th September 2007, 02:25 | #2962 | Link |
Mr. Sandman
could you please try if MeGUI has problems with TIVTC 1.0.1 using the AVS creator?
7th September 2007, 02:37 | #2963 | Link |
Mr. Sandman
0.2.6.1006 Commit by Sharx1976: - Fixed some visual interface glitches - AVS Creator: Checking "Resize" enables "Suggest Resolution" - AVS Creator: Checking "Suggest Resolution" automatically checks "Resize" - (Kurtnoise) fix subtitles streams parsing when we have strings instead of numbers.
7th September 2007, 05:29 | #2964 | Link |
Posts: n/a
The mewiki has changed slightly from what I've seen. What used to be:
http://mewiki.project357.com/wiki/Main_Page is now http://mewiki.project357.com/index.php/Main_Page If this is a permanent change, the internal links in MeGUI should be updated. Also, here's two more patches for minor visual errors: Code:
Index: MuxProvider.cs =================================================================== --- MuxProvider.cs (revision 170) +++ MuxProvider.cs (working copy) @@ -433,7 +433,7 @@ maxFilesOfType = new int[] { -1, -1, -1, 1 }; base.type = MuxerType.MKVMERGE; generator = CommandLineGenerator.generateMkvmergeCommandline; - name = "Mkv muxer"; + name = "MKV Muxer"; // base.audioInputFilter = "All supported types (*.aac, *.ac3, *.dts, *.mp2, *.mp3, *.mp4, *.ogg)|*.aac;*.ac3;*.dts;*.mp2;*.mp3;*.mp4;*.ogg|RAW AAC Files (*.aac)|*.aac|AC3 Files (*.ac3)|*.ac3|DTS Files (*.dts)|*.dts" + // "MP2 Files (*.mp2)|*.mp2|MP3 Files (*.mp3)|*.mp3|MP4 Audio Files (*.mp4)|*.mp4|Ogg Vorbis Files (*.ogg)|*.ogg"; // base.videoInputFilter = "All supported types (*.avi, *.mkv, *.mp4)|*.avi;*.mkv;*.mp4|AVI Files (*.avi)|*.avi|Matroska Files (*.mkv)|*.mkv|MP4 Files (*.mp4)|*.mp4"; Code:
Index: VobinputWindow.cs =================================================================== --- VobinputWindow.cs (revision 170) +++ VobinputWindow.cs (working copy) @@ -382,7 +382,7 @@ this.projectNameLabel.Name = "projectNameLabel"; this.projectNameLabel.Size = new System.Drawing.Size(100, 13); this.projectNameLabel.TabIndex = 3; - this.projectNameLabel.Text = "d2v Project Ouput"; + this.projectNameLabel.Text = "d2v Project Output"; // // saveProjectDialog // |
7th September 2007, 08:36 | #2965 | Link |
phjbdpcrjlj2sb3h
re: web site, please see my sig or http://forum.doom9.org/showthread.php?p=1042398#1328
7th September 2007, 13:58 | #2967 | Link |
Mr. Sandman
0.2.6.1007 - (Sharx1976) New changelog format - (Sharx1976) Fixed 1735676 (Video Output filename can't be changed directly) - (Kurtnoise) fix wiki link - (Kurtnoise) fix label typos - (Kurtnoise) remove hint track option for NDAAC encoder + several tunings - (Kurtnoise) few tunings for audio encoders
8th September 2007, 21:02 | #2968 | Link | |
8th September 2007, 23:30 | #2969 | Link |
Posts: n/a
I think Sharktooth is talking about choosing to not integrate Yadif into MeGUI's current auto-deinterlacer, as there are tentative plans to replace the current auto-deinterlacer with Bautodeint instead. As Bautodeint is also AviSynth based, Yadif should be able to be integrated into it instead.
9th September 2007, 00:16 | #2970 | Link |
I certainly want to add yadif to MeGUI. I already use it myself, using AVS templates in MeGUI. The automatic deinterlacing will still use the TIVTC package, because they provide filters such as TIsCombedTIVTC, but yadif should be offered as a possible filter if the source is detected as interlaced.
9th September 2007, 01:49 | #2971 | Link | |
Mr. Sandman
@kurtnoise: thank you for your help with megui
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 9th September 2007 at 02:04. |
10th September 2007, 03:09 | #2972 | Link |
Mr. Sandman
0.2.6.1009 - (Kurtnoise) fixed 1660566 (Audio Streams were discarded from command line in the Adaptive Muxer). - (Kurtnoise) [AVS Creator] Add yadif.dll deinterlacer (also added to AutoUpdate) - (Kurtnoise) [AVS Creator] Re-order deinterlacers, to prefer TDeint over TDeint+EEDI2, and yadif over TDeint - (Kurtnoise) [MainForm] : some refactoring in the Help Menu. - (Kurtnoise) added a TabControl for Program Paths. - (Kurtnoise) updated MediaInfo.dll & MediaInfoWrapper.dll (0.7.4.4 to 0.7.5.3) - (Kurtnoise) move Settings & Update items to Options Menu. it should be removed from the settings too since there is a special section in the upgrade.xml named: <AviSynthFile type="tree" displayname="AviSynth plugins"> that includes ALL the avisynth plugins for the autoupdate. all files placed there will be automatically copied to the avisynth plugins directory stored in the settings. the changes to to updatewindow.cs and settingsform.cs have be reverted and yadif.dll path removed from the settingsform.cs Look at the upgrade.xml file megui parses for the updates, it will make you understand better. just adding: Code:
<yadif type="file"> <filepath version="0.9">yadif09.zip</filepath> </yadif> so, i've built 0.2.6.1009 without fixing the yadif stuff since it's 5:00 AM and i need to sleep, but before fixing other bugs please have a look at the yadif stuff.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 10th September 2007 at 04:11. |
10th September 2007, 05:54 | #2973 | Link |
HDConvertToX author
yadif should have a specific path for load since is a LoadCplugin..
in automkv (avaiable in next update) i added a cplugin folder for adding and loading all avisynth_C plugins. If cplugin folder is present and *.dll found i will load it with loadCplugin.. else skip just my 0.02€ BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
10th September 2007, 06:41 | #2974 | Link |
Actually, I added yadif (and re-ordered the deinterlacers) -- you probably just misread the SVN log. Anyway, as buzzqw said, it's a C plugin, so it can't be put in the AVS plugins folder. This is why I put it in a MeGUI program files folder. If we will support more C plugins, then it might be worth doing what buzzqw does with automkv.
10th September 2007, 12:46 | #2975 | Link |
Mr. Sandman
Oops.... so where should yadif be added in the upgrade.xml?
EDIT: Nevermind, found it. EDIT: There is a problem in the program paths browse buttons. they do not open the dialog.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 10th September 2007 at 17:39. |
10th September 2007, 14:35 | #2977 | Link |
Pain and suffering
I compiled a fresh new megui, but when i run a clean install, updater keeps asking for this:
Trying server: http://megui.org/auto/stable/ Retrieving update file from server... File downloaded successfully... Loading update data... Update data loaded successfully... Finished parsing update file... There are 1 files that can be updated. Updating libs. File 1/1. Error: libs could not be found on the server Update completed. 0 files were completed successfully 1 files had problems. Easy fix i assume... |
10th September 2007, 14:48 | #2978 | Link |
Mr. Sandman
does it work now?
also where i can find the megui NSIS installer script you use?
10th September 2007, 14:58 | #2979 | Link |
Pain and suffering
It works but uhm, aren't the libs i compiled newer and possibly needed??
http://x264.nl/megui.nsi Edit: Also why does the "new updates available" pop-up, pop up behind the main windows? Last edited by bob0r; 10th September 2007 at 15:02. |
10th September 2007, 15:02 | #2980 | Link | |
Mr. Sandman
EDIT: is it ok if i add the installer script to megui svn? ... if so, who's the author?
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 10th September 2007 at 15:05. |
development, megui, not a help thread |
