4th June 2012, 18:18 | #13241 | Link |
Lol thanks guys! I'm busy at the moment and just responding on the phone:
1) I actually completely forgot that LAV supports TrueHD-since most of my Blu-Rays are DTA-MA (which afaik is not supported.) I will give that a shot. (That of course will not be an complete fix, but it would be nice to use ReClock! Well I have to run, I will go point-by-point later. Although I knew most of what you said, I liked the way you described it-I may reference your post in the future to people who ask me such questions...) Oh my GPU[s] are GeForxe 8600T's (I know they're the weakest part of my setup-but when using software decoding On my overclocked quad-core Q6600 CPU I am just fine. (It's Often fine even using HW decoding at times.) Well this phone is annoying me-more later... |
4th June 2012, 19:17 | #13243 | Link |
Are you sure about that? I thought that if the decoder cannot decode it, then the Arcsoft *renderer* is needed. I played around with the Arcsoft *decoder* in the past with limited success. (The thing is buggy as heck-some junior developer made it so that changes made in the GUI for the decoder never applied. This was a while back-I will take a look. Since this is off-topic, please PM me if you find anything interesting, I would love to decode these lossless codecs like I do everything else!
4th June 2012, 20:30 | #13244 | Link |
Well I know that the Arcsoft decoder allows DTS-HD MA decoding when used with eac3to and I don't know of any reason why LAV Filters wouldn't work with it too.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
4th June 2012, 20:46 | #13245 | Link |
It works fine. I use it all the time. However, I don't believe it works with 64 bit. Then again, neither does madVR, so, that's a moot point in this thread.
5th June 2012, 01:15 | #13247 | Link |
Thanks much for the responses on decoding DTS-MA on LAVAudioDecoder. I tried it and it plays fine, seeming to work.
However, are you sure it is not just decoding the CORE components and "down-sampling"* the lossless stuff? (edit: This post became so long and so off-topic that I moved it to the LAV Filters thread: http://forum.doom9.org/showthread.ph...02#post1577202 ) Last edited by Mikey2; 5th June 2012 at 02:22. Reason: moved to LAV Filters thread |
5th June 2012, 01:18 | #13248 | Link |
DTS core only has 5.1 channels. DTS-HD MA has 7.1. Hence, an easy thing to check. Anyway, yes, off topic, so, we can discuss it in the proper thread.
5th June 2012, 03:11 | #13249 | Link |
Woo Hoo! Thanks to 6233638 and others I found the solution to the studdering problem I had above! ( http://forum.doom9.org/showthread.ph...93#post1577093 )
Simply turning "Vertical Sync = off" in the NVidia Control Panel fixed the issue. I spent over an hour verifying it with it both on and off, and it is definitely the solution! (This must be an issue with Madvr and the new GeForce (301.42) drivers. Since I first built this computer I have always left VSync=On and never had a problem until now. ) Anyway thanks again everyone! I really thought I might be stuck with that one! MikeY PS - ajp-anton - How did you fix my picture? ...Nice work. |
5th June 2012, 11:06 | #13253 | Link |
Ok, now I'm a tad confused and yes, I'm dumb. On page 663 of the thread we have some people saying to turn "Off" Vertical Sync (Mikey2) and we have others saying to turn "On" Vertical Sync (6233638). But I guess all are in agreement not to set it to "Adaptive". I'm just going to leave it at "Use the 3d application setting" which I guess is the same as Vertical Sync "On"?
5th June 2012, 12:50 | #13254 | Link | |
The only time you should disable v-sync is when latency matters above image quality. (game tournaments playing for money) MadVR's exclusive mode is designed to avoid tearing if at all possible. |
5th June 2012, 13:55 | #13255 | Link |
You never want v-sync disabled unless you are benchmarking. Otherwise you'll see frames in the frame buffer as they are still being drawn. Exclusive mode just skips desktop composition. It's how opengl renders in full screen on vista/7.
5th June 2012, 14:46 | #13256 | Link |
madVR + Lucid's VirtuMVP
Hello!
I tried using madVR with Lucid's VirtuMVP, but it wasn't a success. I want to use iGPU with Quick Sync feature via LAV Video Filter, and show video via discrete GPU (NVidia). Is this configuration supported in madVR? |
5th June 2012, 15:49 | #13257 | Link |
It's not madVR that's the issue. It's very complicated to set this up. There's a post in another thread about doing this. It's not done through Virtu. I have mine set up so that I can do this if I want. You essentially go into your display properties, set the intel GPU as an extended display and enable it. If you do that, LAV should show QS as being available. It can be a little flaky though. I've got mine working perfectly, but, I use the Intel GPU for audio to my receiver and the 680 directly to the TV. (This is how I'll do 3D when I upgrade my TV later this year as my receiver doesn't support 3D). The one caveat I'll warn you about is that when you upgrade the nVidia driver it disables the intel GPU extended display so you have to go re-enable it. Good luck. You may need it.
5th June 2012, 16:35 | #13258 | Link |
VirtuMVP
I actually tried and know that it's possible with EVR.
Example is in the attachment. I don't like the idea of setting another "fake" extended desktop that much. Seems that it's madVR that doesn't recognize this kind of setup. |
5th June 2012, 16:37 | #13259 | Link |
Not sure what to tell you. As I said, it works just fine for me. I prefer my 680's CUVID in LAV for the moment but I tested QS to see how well it worked. I had no real problems with it.
6th June 2012, 13:16 | #13260 | Link | |
Also, I'm not sure why the present queue is not always full. IMO it's still very buggy and nothing like 260.99 or older drivers where things were truly flawless for me. So I eventually went back to the old FSE (yet again) for the peace of mind (that way I can keep the same settings for 72hz/24-48fps, 75hz/25-50fps, 60hz/60-30fps etc. and playback just "works" no matter what). But then again I have an older GPU so I guess I can't expect newer nvidia drivers to make things much better for me. |
