8th February 2007, 09:11 | #261 | Link |
Qpel & idct
Becasue QPEL was introduced in MPEG4,
libmpeg2-idct even does not know about QPEL. So libmpeg2-idct must be excluded when QPEL is detected. Is this correct? I'm n00b to these things, any advice is wellcome. |
8th February 2007, 11:40 | #262 | Link | |
I did a frame comparison and came up with the same conclusions like you: http://simpleupload.net/download/44120/idct.rar.html Last edited by fastplayer; 8th February 2007 at 14:41. Reason: Updated DL link. |
8th February 2007, 13:13 | #264 | Link | |
To name the ones that shouldn't matter at all: MSP 6, VHQ 4, VHQ for b-frames, Chroma ME, trellis, chroma optimizer, CC 15/6. If the matrice (Didee's SixOfNine) could have an influence on the bug, I've ruled that out: the sample is cut from my 2-pass encode, but I've seen the same things happening with my 1-pass samples, while I was testings CQMs, with 11 other matrices, including H.263 quantization and MPEG standard. @ haruhiko: I haven't got the faintest idea, unfortunatelly. @ fastplayer: sh**, I can't view files at filefactory - my ISP's issue, 1/4 of webpages doesn't load; might be sth with proxy Thanks
"Only two things are infinite: the universe and human stupidity, and I'm not sure about the former."
8th February 2007, 13:26 | #265 | Link | |
8th February 2007, 14:19 | #266 | Link | |
lavc xvid/auto (yes, auto works always as it should) identical to xvid 1.1.2. lavc libmpeg2 not identical to xvid 1.1.2. |
8th February 2007, 14:30 | #267 | Link | |
http://forum.doom9.org/showthread.ph...ight=qpel+idct
MPC-HC 2.1.7.2 |
9th February 2007, 22:05 | #269 | Link |
Didée Fan
Hello, I'm hoping that leakkerneldeint can be put into the Deinterlacers section of FFDshow in the next rev.
9th February 2007, 22:14 | #270 | Link | |
I just did a benchmark with a non-interlaced H.264 file. Having HW deinterlacing enabled in the output settings hurts performance a bit. In this one test about 16% lower dfps. But it will probably depend on the power of the graphics card. Mine is pretty weak. So my recommendation to everyone is too keep it turned off (the default) if you mostly play progressive files and to use a software deinterlacer when needed.
MPC-HC 2.1.7.2 |
9th February 2007, 22:31 | #271 | Link | |
By the way, is there an option in ffdshow that allows me to see what IDCT is being currently used (when it's set to 'auto')? Last edited by fastplayer; 9th February 2007 at 22:36. |
10th February 2007, 00:26 | #272 | Link |
Didée Fan
haruhiko_yamagata,
I tried the HW Deinterlacing in the Output Tab. - I set the output to YV12 only, and FFDshow Video decoder would not show up, but FFDshow Audio would. - If I set it to YUY2, FFDshow Video decoder showed up, but the HW deinterlacing was off. I tried other and all Output Colorspaces, but they all set it to Software mode deinterlacing. I have a few questions. - What Output colorspace do I need to USE HW Deinterlacing: Bob ? - Why can't I just use YV12 ? I'm using the Nvidia Video Codec, and Media Player Classic. I've tried VMR9 renderless, and default in the MPC output tab. I've tried fiddling with the video card properties. I'm using FFDshow rev 814 |
10th February 2007, 02:34 | #274 | Link |
Big thanks to the developers of FFDShow.
I'm not sure that this is the right place to talk about the difficulties from using FFDShow. And English is not my mother tongue. Your patience will be really appreciated. Unlike PowerDVD 7, v5 has no compatability issue with FFDShow. But in recent FFDShow builds after the rev657_20061209_clsid, there is no way that make it work with my PowerDVD 5 but to stop using the blacklist which is very useful for me. Excluding PowerDVD.exe from the list does nothing in my PC and I don't know why. Is this designed intentionally? If so, how can I bypass it? Or is there something that I overlooked or misunderstood in configuration? Last edited by ouchi; 10th February 2007 at 02:51. |
10th February 2007, 03:30 | #275 | Link |
Curious Beta Tester
Flac audio playback is broken. When installing builds with the flac option enabled, and playing it back in wmp11 no playback occurs and an error message is generated "wmp cannot play the file.......not supported...."
Also, why are the cslid and drevilxxx builds different for default installs? I see vorbis tremor has different defaults. |
10th February 2007, 09:48 | #279 | Link | |
HW deinterlacing should work with YUY2, if it does not work, it should be nVidia's issue. |
10th February 2007, 09:53 | #280 | Link | |
It was intentionally designed, I didn't know PowerDVD5 worked though. There is no way to bypass currently. Is there way to check version of PowerDVD? |
