21st February 2005, 10:54 | #201 | Link |
ReMember
I've stumbled on this thread a little late but I was playing around with the methods listed on the original website (Photoshop method). For the most part it is a straight port of his method, except the green mask is toned down a bit and I merged the original base layer with the final result.
On the left is the "film" look and on the right is the original video. Xvid@Q5: http://rapidshare.de/files/665159/Li..._xvid.avi.html Tomorrow I'll see how it looks on my TV and play around with the FPS. Also, I suck at Subtitle(), can anyone post a sample of a simple Subtitle line for showing text on the bottom right? |
21st February 2005, 20:57 | #202 | Link |
mad computer-scientist
nice effect, looks really good IMO
only thing i'd add would be addgrain with very mild settings and please post your complete script/procedure http://www.avisynth.org/Subtitle maybe subtitle(text="abc", align=3) |
21st February 2005, 21:19 | #203 | Link | |
ReMember
First I captured footage from my HDR-FX1, saved a portion of my cousin's lizard eating in DGIndex, used this script to export BMPs from Virtual Dub:
Mpeg2Source("00.d2v") SeparateFields() Lanczos4Resize(960,540) Then this script was used to compare the two and lower the green a little bit in the "film" clip. Code:
a=AVISource("Lizard_FILM.avi").crop(0,0,-480,0).RGBAdjust(1, .955, 1, 1, 0, 0, 0, 0).subtitle("FILM",-1,-1,0,900,"arial",30,$ffffff) b=AVISource("Lizard_VIDEO.avi").crop(480,0,0,0).subtitle("VIDEO",-1,-1,0,900,"arial",30,$ffffff) return StackHorizontal(a,b) Quote:
22nd February 2005, 03:06 | #205 | Link |
ReMember
As best as I can, sure. I'm actually about to start trying the same method in AVISynth now.
EDIT: The procedure listed on that website can definitely be done in AVISynth...I think to the T. It might take me a bit to get it, have to learn all about Overlay() but I think it will work. And I'm sure it'll be MIGHTY slow. For now, I loaded up two AMP files with your plugin and they worked just like how they should. Last edited by Backwoods; 22nd February 2005 at 04:46. |
23rd February 2005, 04:49 | #207 | Link |
ReMember
Which features do you think AVISynth can't do? From what I can tell, all can be done. The only problem I see is when the image has to be converted to LAB color and effects applied to certain layers.
LoadPlugin("C:\Program Files\AviSynth 2.5\yea\DGDecode.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\GiCoCU.dll") Mpeg2Source("menu.d2v") #base=Mpeg2Source("menu.d2v") #FILM=Mpeg2Source("menu.d2v") #Mpeg2Source("menu.d2v") ConvertToRGB() SeparateFields() #FILM Layer GiCoCU("C:\download\filmy.amp",photoshop=true) #Sharpen & Gaussian Blur [Unsharp Mask on Luminance Layer + GB on A/B Channels] #Contrast Layer 1 [Dup FILM layer - (70% blue, 10% green, 20% red) Opacity 20%] #Highlight Layer [Dup FILM Layer - Gaussian Blur Radius 5 pixels Layer blend Screen, Opacity 52%] #Detail Layer [Dup FILM layer - Highpass Radius 6 pixels Image/Adjust/Desaturate Layer blend Soft Light, opacity 30%] #Color Cast [Fill with color cast choice; medium dark green or orange are good Layer blend Soft Light, Opacity 40%. Use lower opacity for less dramatic effect] #Original Blend [Dup base (unmodified) layer. Layer blend normal, opacity 30%. Adjust this opacity to get a balance between contrast and smoothness.] #Shadow Pull-up [Layer blend Lighten, Opacity 15% - Base Layer] GiCoCU("C:\download\shadow.amp",photoshop=true) #Highlight Pull-Down [Layer blend Lighten, Opacity 20% - Base Layer] GiCoCU("C:\download\highlight.amp",photoshop=true) #Contrast Layer 2 [Dup FILM Layer - Desaturate by 50% Layer blend Soft Light, Opacity 10%] That is the script so far, just loading 2 AMP files and commenting on what else is needed. The use of Overlay and naming commands, then applying certain effects to them is still needed. I've done an other test using PS and it came out pretty good I think, have to make a couple AVIs comparing again and output to TV. I'll post an Xvid of it tonight or tomorrow. Last edited by Backwoods; 23rd February 2005 at 04:51. |
23rd February 2005, 11:30 | #208 | Link |
OK, here is mylist:
Original: baselayer=dv.deinterlace... not sure which deinterlacer, should be tested also we have to convert to rgb FILM Layer: filmlayer=baselayer.gicocu.... i see no problem here Sharpen and Grain: filmlayer=filmlayer.limitedsharpen... filmlayer=filmlayer.addgrain... modified for avisynth, other filter can be used here aswell also i skipped the chroma blurring for now we need yuv colorspace here Contrast Layer 1 : contrastlayera=filmlayer.channelmixer... AFAIK there is no channelmixer in avisynth but it should be very easy to code Highlight Layer: highlightlayer=filmalyer.gaussianblur... there is a gaussian blut plug-in Detail Layer: detaillayer=filmlayer.highpass... detaillayer=detaillayer.tweak... desaturatino can be done with tweak i suppose for highpass filterign there is no plug-in i know off but if seen it done in a script by subtracting a blurred image from the original not sure if this is what we need here Color Cast: colorcast=blankclip.... not sure if this really needs an extra layer EDIT: rgblut should be able to do the same job :EDIT Original Blend: no problem Shadow Pull-up / Highlight Pull-Down here we'd need LAB colorspace EDIT: i got some code in my test-app that looks good i think i can implement processing of L-curves :EDIT Contrast Layer 2: no problem Illumination coloring layer: don't knwo of a filter doing a "Gradient Map" but i think i can code such a filter for yuv colorspace Grain Layer: no problem addgrain should do the job in avisynth For black and white [optional]: no problem i think then we just have to overlay everything properly EDIT: i found a site with algorithms for "lighten", "screen", ... i think they'll be doable in rgblut :EDIT so, i'll wait for some comments now, before i start looking into coding the missing plug-ins Last edited by E-Male; 23rd February 2005 at 18:02. |
23rd February 2005, 21:00 | #209 | Link |
ReMember
Gaussian blur for AVISynth: http://forum.doom9.org/showthread.php?s=&threadid=88645
Unsharp Mask for AVISynth shouldn't be too hard for someone to code. I believe there is such a plugin for VDub. Overlay can do lighten but I do not see screen, so screen would be needed. LAB color I have no idea about. The LAB color part was the only thing I saw as a problem, but like you mentioned: "then we just have to overlay everything properly." Scripting that would take me some trial and error but I'm confident in that. By the looks of it, we have just about everything. |
23rd February 2005, 21:59 | #210 | Link |
yep, that the gausian blur i meant
i think we don't have to use the same sharpener lighten, but not softlighten rgblut IMO is the best solution, fast and programabel as long as the curve only manipulated tha L-channel the formulas aren't that hard, but i haven't testet it yet 3 plug-ins and some scripting to go, looks like we'll soon have a test version |
24th February 2005, 09:43 | #212 | Link |
i just noticed there is no rgblutxy
so i'll have to add the blending features to the plug-ins to do list this might slow down things again i daubt working on the script will be worth the effort as long as we don't have the plug-ins/functions for all teh steps |
26th February 2005, 19:02 | #213 | Link |
How about packaging GiCoCu with a readme and a page?
Reclusive fart. Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers Last edited by FredThompson; 26th February 2005 at 21:41. |
26th February 2005, 20:25 | #214 | Link |
you have an unsharp mask filter in the warpsharp.dll plugin if i right remember.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec. AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles. |
27th February 2005, 00:03 | #215 | Link | |
ReMember
The script is coming along and I'm taking progress shots to compare to the same procedure in Photoshop. Hopefully by the middle of the week I'll have everything done that I can possibly do as of now. |
27th February 2005, 10:58 | #216 | Link |
i know i'm lazy with readmes, i'll try to improve on that
why do we have to use the same sharpener as in photoshop there are great sharpeners for avisynth, like limited sharpen i think some modification of that script might be the best we can get |
27th February 2005, 23:02 | #217 | Link |
ReMember
Sure some modification will have to be done, I was just going along with the original at first and we can always improve from there. Also I think using LimitedSharpen would make the script run slower. That is why I'd like to hold off on that for now.
28th February 2005, 03:00 | #219 | Link |
ReMember
Original Video from HD cam
Video processed frame by frame in Photoshop Video processed with AVISynth E-Male, I think we're there. Script: Code:
LoadPlugin("C:\Program Files\AviSynth 2.5\yea\DGDecode.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\Decomb521.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\GiCoCU.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\TweakColor.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\FFT3DFilter.dll") LoadPlugin("C:\Program Files\AviSynth 2.5\yea\WarpSharp.dll") #LoadPlugin("C:\Program Files\AviSynth 2.5\yea\.dll") BaseLayer=AVISource("Menu_VIDEO2.avi") ColorLayer=ImageSource("c:\download\color_cast.bmp") #FILM Layer FILM=BaseLayer.ConvertToRGB24().GiCoCU("C:\download\filmy.amp",photoshop=true) #Sharpen & Gaussian Blur [Unsharp Mask on Luminance Layer + GB on A/B Channels] SG=FILM.ConvertToYUY2().unsharpmask(300,2,0).FFT3dFilter(plane=1,bt=1,sharpen=-5).FFT3dFilter(plane=2,bt=1,sharpen=-5) #Contrast Layer 1 [Dup FILM layer - (70% blue, 10% green, 20% red) Opacity 20%] CONT=SG.Levels(5, 1, 255,0, 255) #Highlight Layer [Dup FILM Layer - Gaussian Blur Radius 5 pixels Layer blend Screen, Opacity 52%] HIGH=FILM.Blur(1) #Detail Layer [Dup FILM layer - Highpass Radius 6 pixels Image/Adjust/Desaturate Layer blend Soft Light, opacity 30%] DETAIL=FILM.ConvertToYUY2().TweakColor(sat=.5) #Color Cast [Fill with color cast choice; medium dark green or orange are good Layer blend Soft Light, Opacity 40%. Use lower opacity for less dramatic effect] COLORCAST=ColorLayer.BicubicResize(720,540) #Original Blend [Dup base (unmodified) layer. Layer blend normal, opacity 30%. Adjust this opacity to get a balance between contrast and smoothness.] OBLEND=BaseLayer #Shadow Pull-up [Layer blend Lighten, Opacity 15% - Base Layer] SHADOW=BaseLayer.ConvertToRGB24.GiCoCU("C:\download\shadow.amp",photoshop=true) #Highlight Pull-Down [Layer blend Lighten, Opacity 20% - Base Layer] HIGHPD=BaseLayer.ConvertToRGB24.GiCoCU("C:\download\highlight.amp",photoshop=true) #Contrast Layer 2 [Dup FILM Layer - Desaturate by 50% Layer blend Soft Light, Opacity 10%] CONT2=SG.ConvertToYUY2().TweakColor(sat=.5) #Return () a=Overlay(SG, CONT, mode="Blend", opacity=.4) b=Overlay(a,HIGH, mode="Add", opacity=0.52) c=Overlay(b, DETAIL, mode="SoftLight", opacity=.3) d=Overlay(c, COLORCAST, mode="SoftLight", opacity=.15) e=Overlay(d, OBLEND, mode="Blend", opacity=.3) f=Overlay(e, SHADOW, mode="Lighten", opacity=0.15) g=Overlay(f, HIGHPD, mode="Lighten", opacity=0.2) h=Overlay(g, CONT2, mode="SoftLight", opacity=0.1) Overlay(h, BaseLayer, mode="Blend", opacity=0.7) I couldn't get AVISynth's Tweak to work for me, so I used TweakColor, I rather not use FFT3DFilter but that came to mind when I had to apply blur to UV only. Not sure if it's doing what it's intended, but maybe someone else can help out before the time it taks me to figure some other methods out. Also I'm not sure if the CONT layer is doing what I want it to. Probably not. I'm pretty satisfied with the result. Last edited by Backwoods; 28th February 2005 at 06:40. |
28th February 2005, 13:49 | #220 | Link |
looks pretty nice already
on "#Sharpen & Gaussian Blur [Unsharp Mask on Luminance Layer + GB on A/B Channels] SG=FILM.ConvertToYUY2().unsharpmask(300,2,0).FFT3dFilter(plane=1,bt=1,sharpen=-5).FFT3dFilter(plane=2,bt=1,sharpen=-5)" try "SG=FILM.ConvertToYUY2() SG=mergeluma(s.unsharpmask(300,2,0)) SG=SG.VariableBlur(2, 2, 2, 3, 3, true, false, true)" see http://www.avisynth.org/Merge http://forum.doom9.org/showthread.php?s=&threadid=88645 "#Contrast Layer 1 [Dup FILM layer - (70% blue, 10% green, 20% red) Opacity 20%]" won't work without a channel-mixer plug-in which i yet have to write "#Highlight Layer [Dup FILM Layer - Gaussian Blur Radius 5 pixels Layer blend Screen, Opacity 52%]" could also be done with VariableBlur, not sure if i'll be better "#Detail Layer [Dup FILM layer - Highpass Radius 6 pixels Image/Adjust/Desaturate Layer blend Soft Light, opacity 30%] DETAIL=FILM.ConvertToYUY2().TweakColor(sat=.5)" doesn't have the highpass filter i've seen it done with subtracting a blurred version try something like "DETAIL=FILM.ConvertToYUY2() DETAIL=DETAIL.subtract(DETAIL.VariableBlur(6, 6, 3, 3, 3, false, false, false)) DETAIL=DETAIL.TweakColor(sat=.5)"" for "#Color Cast [Fill with color cast choice; medium dark green or orange are good Layer blend Soft Light, Opacity 40%. Use lower opacity for less dramatic effect]" see http://www.avisynth.org/BlankClip "#Shadow Pull-up [Layer blend Lighten, Opacity 15% - Base Layer]" and "#Highlight Pull-Down [Layer blend Lighten, Opacity 20% - Base Layer]" can't be done that way, because the cuves are for lab colorspace, not rgb i'll do a L-curve plug-in "Illumination coloring layer" is missing can be done with blankclip and overlay i think "Grain Layer" is missing aswell could be done without an additional layer by using addgrain on the result IMO does "overlay" really supports all needed modes and do they work/look like in photoshop?? can you really just overlay images with different colorspaces? still to do for me are these plug-ins: channel-mixer & L-curve (& new overlay ?) posssible improvements / modifications on the procedure: do artefact removal before the film-look procedure add grain after it with addgrain try different sharpeners ..... Last edited by E-Male; 28th February 2005 at 14:29. |
