9th May 2011, 13:41 | #464 | Link |
@meshaun:should be fixed in latest public release,...
@devaster: good to know,.. damn, switching to chroma&luma sharpen instead of (un)sharpen doesn't help either,.. :/ Found a way use mencoder_mt (and rename it to mencoder) from i.e. http://ps3mediaserver.googlecode.com...aserver/win32/ (or http://sourceforge.net/projects/mpla...ision%2032848/) and the speed is a lot better => does anyone have any experience with mencoder_mt ? (if it doesn't have any known problems I'll switch to mencoder and mplayer MT for hybrid) Last edited by Selur; 9th May 2011 at 15:07. |
10th May 2011, 12:03 | #468 | Link |
Duke is my hero
i was looking on nvidia docs about decoder. It will be easier to incorporate the decoding and maybe filtering part into your encoder - maybe lower overhead with frame transferring ...
NVIDIA CUDA(5.0 RC) on 460M |
11th May 2011, 10:46 | #469 | Link |
Did some extensive testing on why I used the normal mencoder and not the mencoder_mt build and I found out why.
-> sometimes mencoder_mt doesn't start up properly, i.e. when calling Code:
mencoder.exe "G:\Hybrid\test - clips\test.avi" -ovc raw -noskip -vf scale,format=i420 -forcedsubsonly -nosub -nosound -mc 0 -lavdopts threads=8 -ofps 25 -aspect 1.81818:1 -of rawvideo -o - | x264.exe --crf 42 --f ps 25 --input-res 640x352 --output NUL - which will cause Hybrid to abort current since no output (and or stats file for 2pass 1st pass) will be created. so not using mplayer_mt/mencoder_mt was a stability choice. (will keep on testing new mt versions in the case that I find updated binaries ) Cu Selur Ps.: @devaster: please also add an option to use the decoder without the encoding part, this would allow to use the decoder part and pipe the output to x264/xvid/mencoder/.. instead of using the nvidia encoder. Last edited by Selur; 11th May 2011 at 11:04. |
11th May 2011, 13:39 | #470 | Link |
Hybrid rev 2011.05.11.1
*fixed* - mkvextract: removed '--raw' from extraction cl - problem when importing chapters *changed* - frameCounter: limit buffer to 20MB + better frame detection *added* - win7/vista: show progress in taskbar - hibernate as an additional option on queue finished *updated* - windows packages: frameCounter -> downloads: http://www.selur.de/downloads |
12th May 2011, 01:01 | #471 | Link |
Practising Schemer
Will you be updating hybrid for the new x264 presets sharktooth is discussing here. http://forum.doom9.org/showthread.ph...52#post1499552
12th May 2011, 06:30 | #472 | Link |
Judging from:
1. a x264 download from x264.nl and 2. the git summary (http://git.videolan.org/?p=x264.git;a=summary) these device presets are not preset in x264 atm. When they are included, and there are working binaries with them, I will adjust Hybrid accordingly to support them. Cu Selur |
19th May 2011, 08:34 | #473 | Link |
Hybrid rev 2011.05.19.1:
*fixed*
16th June 2011, 10:18 | #477 | Link |
I am using last version 2011.05.19.3 in archlinux with last git version of x264. The other apps are from arch official repository.
All is apparently working fine but If I try to encode for blu ray the resulting video has colors wrong: skins are almost blue...like in some sf movies... The original file has been taken from a Sanyo Xacti video camera: AVC, Progressive, Bitrate 12166, Resolution 1920x1080, PAR 1, 29,97, aac. The options changed in Hybrid are: 1) Structure: Blu ray on Main tab 2) Audio handling auto add first on Main tab 3) Hardware blu ray on x264 tab 4) Constant rate factor (2 pass) on the x264 tab 5) Scale output frame rate to 23,976 or 24 in filtering tab (is this right?) 6) Encoding to ac3 in audio tab. The same movie demuxed with tsmuxer, changed aac to ac3 and authored with easyBD is playing fine with right colors in my panasonic BD60 blu ray player (no re-encoding!) |
16th June 2011, 10:32 | #478 | Link | ||||
How do the complete encoding calls look like ? (disable 'Minimize job command lines' and post the complete lines of the encoding calls) Quote:
Cu Selur |
16th June 2011, 11:02 | #479 | Link | ||
Under x264 tab:
16th June 2011, 11:06 | #480 | Link |
"-vf filmdint=io=29.97:23.976,softskip" is probably wrong for your input -> try disabling Filtering->Deinterlace/Telecine Settings->Auto deinterlacing
Strange thing is, Hybrid shouldn't insert this unless the source is detected as interlaced,.. -> would be cool if you could upload a small sample to MultiUpload (or similar site) so I can do some tests. DOOHHH,.. it's not added by the deinterlacer but by the frame rate changer -> think I know where the problem is. ("-vf filmdint=io=29.97:23.976,softskip" needs to be a "-vf scale,format=i420,filmdint=io=29.97:23.976,softskip") What version 32/64bit of linux do you use, so I can send you a test version of a hopefully fixed Hybrid. Cu Selur Last edited by Selur; 16th June 2011 at 11:23. |
