1st November 2011, 00:02 | #6641 | Link | |
MPC-HC 2.2.1 |
1st November 2011, 00:05 | #6642 | Link | |
1st November 2011, 01:13 | #6643 | Link |
clsid: i have used codec tweak tool and the other one that they do but it keeps changing back to "system default" and even if lav splitter is set and golagoda: the mpc-hc idea won't work as i can't block something i want know what its using in the first place
this is the outcome of a encoded avi of when the splitter isn't set http://rghost.net/28028481 i even get the same problem when using dgnv (nvidia 450 gts @ 100 fps max!) this is why i use dss as i can get the cpu to do the decoding give me over 60-120% boost faster then dgnv can give me when using my gfx card Last edited by cegy; 1st November 2011 at 01:26. |
1st November 2011, 04:04 | #6645 | Link | |
BTW: Something I should have said is that GPU-Z has always shown the GPU Core and Mem to be at it's rated spec of 625 MHz core, 500 MHz mem when a movie is playing. As I close the movie it moves down to the modest 100 MHz core, 150 MHz mem within 3 seconds. But again every time a movie is playing in MPC-HC it correctly bumps up the speeds to the "normal" values. Not sure this minimum speed tweak is going to do anything for me if it's always at 625/500 when playing movies. |
1st November 2011, 04:21 | #6646 | Link | |
I've got all those settings in my power plan already. My media is being accessed via gigabit network. HTPC is just a 64GB SSD with windows and media software. |
1st November 2011, 05:58 | #6647 | Link | |
n00b
1st November 2011, 06:45 | #6648 | Link |
It's only "temperamental" if you don't know exactly what it's doing. It can clash with other settings of players or renderers, so you must know what to enable or disable. That's why it was recommended to disable VSync when using with madVR, for instance.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
1st November 2011, 08:55 | #6650 | Link | ||
For NVIDIA cards you have to create a custom resolution to get exactly 23.976Hz/FPS. My NVIDIA system settings are in german, so I don't know what the options are called in English but go to Change Resolution -> button below resolution list -> Create User Specified Resolution In the upper Display Mode box (1920x1080) select 23 Hz as frequency and progressive, expand Timings below, set Standard from automatic to manual and make sure those are the according numbers: active pixels horizontal: 1920 vertical: 1080 front porch horizontal: 638 vertical: 4 sync width horizontal: 44 vertical: 5 total pixels horizontal: 2750 vertical: 1124 polarity horizontal: positive vertical: positive refresh rate: 23.976 Test, save and make sure the new resolution is active. The tray icon should offer 23 Hz now with right click (although it lists the new resolution as 24 Hz in user specified res list). Good Luck |
1st November 2011, 09:13 | #6651 | Link | ||
1st November 2011, 11:28 | #6653 | Link | |
even tryed halli as the splitter as it makes the encoded file even worst then the link i posted (not something i would want to archive!) Last edited by cegy; 1st November 2011 at 11:35. |
1st November 2011, 12:39 | #6654 | Link | |
1st November 2011, 12:40 | #6655 | Link |
another general question:
I want to use SVP (realtime Frame Interpolation) which will need a lot of GPU. How do I know how much GPU is already 'reserved' for CUVID? Own a MSI Cyclone GTX460 1GB DDR5 oc edition overclocked@880Mhz. |
1st November 2011, 13:31 | #6656 | Link | |
The NVIDIA driver suite treats 24p literally as 24.000, although most "24" content actually is 23.976. So out of the box you sadly get an asynch mess from NVIDIA for most of the content out there. After this simple change you wont need Reclock anymore (at least for drifting clocks caused by this). |
1st November 2011, 13:43 | #6657 | Link |
Thanks for your quick reply. I know that both the 24 and 23 standard NVIDIA settings don t make sense at all (the 23Hz reports 23,971xx in madVR.
But I have some other things that I m dealing with atm which confuses me: Here are my results with madVR and as you can see things are strange and something in the report by madVR is not correct: NVIDIA 1080p custom 23Hz @23,976 (with everthing else standard) - madVR reports 23,97495 in the top of the OSD (so a deviation of 0.00105). - one frame dropped every 6 minutes says OSD - 22 dropped frames after 120 minutes of playback says OSD The above all seems 'correct', but now NVIDIA 1080p custom 23Hz @23,978 (with everything else standard) - madVR reports 23,97795 in the top of the OSD (so a deviation of 0.00195). - one frame dropped every 18 minutes says OSD - 2 frames dropped after 120 minutes of playback says OSD The above just is not right. With this I mean that some of the information is incorrect. First off all the deviation is BIGGER then with the 23,976nvidia setting but the 'one frame dropped every' information is 'better' then the 23,976nvidia setting. And the this that is the most strange to me is that I only got 2! dropped frames so this assumes it is almost perfect which does not correspond with the other information. |
1st November 2011, 15:08 | #6658 | Link |
Don't know whether I'm reading it right, but I assume the second set is with the values I posted?
Those values are the closest you can get with the basic handles NVIDIA provides. So 2 dropped frames over the course of 120 mins is pretty great with all the hardware and different clocks in a PC. Seems like you are getting there. I don't know how madVR calculates those values, perhaps madshi can chime in. But at least the "one frame dropped every X minutes" looks like extrapolation based on numbers it got right now. |
1st November 2011, 15:11 | #6659 | Link |
I'm sorry, but this is not the "How do i setup my NVIDIA card" thread, and i would appreciate if you move all these discussions elsewhere. AVS Forum for example already has alot of threads on the topic in its HTPC section.
1st November 2011, 15:57 | #6660 | Link | |
Keep up the good work you re doing! |
