6th August 2019, 18:16 | #17081 | Link |
But why would you need that?
6th August 2019, 18:55 | #17082 | Link |
When I'm trying to find the ideal bitrate or if I don't like the quality of the encode. Really, just about any time you have to redo the encode. Some settings can be tweaked like subme or aq-mode. I have encode that have a dark scene that don't look good and I'll change aq-mode to 3 and it looks a lot better.
I know other settings like --tu-inter can't be changed otherwise it'll affect the data stored in the analysis file. Just a thought, if it's to much work I understand. |
7th August 2019, 09:01 | #17083 | Link |
ByteShare
*.LWI Files
Two questions about the LWI files:
1. Once they get made if you keep the file and later add a video (new job) that has a *.lwi file will it be reused or does a new one get generated? 2. Is it possible to have the .lwi files written to the job folder? --So that clean up is easier and to save a little bit of time in the cases (like myself) when the RipBot temp folder is on a different drive, such as video on a physical drive and the temp folder on a SSD. |
7th August 2019, 09:59 | #17084 | Link |
Unfortunatelly lsmash plugin does not have an option to select folder for index file. This annoys me as well...
7th August 2019, 16:52 | #17086 | Link | ||
ByteShare
Or do the chunks get made and the chunk list shows and then nothing happens after that? Any logs? I had an issue with starting a job, checking a few chunks but not liking the output so I changed the job, but then the first few chunks weren't over written and the job would finish but then started all over again. It was strange. I manually (right click job > clear) cleared the DE progress and it worked. So, anything like that? Last edited by byteshare; 7th August 2019 at 16:55. |
7th August 2019, 19:10 | #17087 | Link | |
I usually using multiple servers but for testing i started an single instance which led to the same result. output for this job on remote machine: Code:
Y:\job6\Chunks>1.cmd ""\\USERX-MASTER\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\USERX-MASTER\RipBot264temp\job6\Chunks\1.avs" -strict -1 -f yuv4mpegpipe - | "\\USERX-MASTER\Ripbot264temp\tools\x264\x264_x64.exe" --seek 0 --colorprim bt709 --transfer bt709 --colormatrix bt709 --opencl --opencl-device 0 --opencl-clbin "C:\Users\UserX\AppData\Local\Temp\x264_lookahead_2.clbin" --pass 1 --bitrate 3000 --stats "\\USERX-MASTER\RipBot264temp\job6\Chunks\1.stats" --fps 25 --force-cfr --min-keyint 25 --keyint 250 --frames 1500 --sar 1:1 --level 4.1 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --ref 5 --stdin y4m --output NUL -" y4m [info]: 1280x720p 1:1 @ 25/1 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x264 [info]: OpenCL acceleration enabled with Advanced Micro Devices, Inc. Capeverde (SI) x264 [info]: profile Main, level 4.1, 4:2:0, 8-bit A s s e r t i o n f a i l e d ! P r o g r a m : \ \ U S E R X - M A S T E R \ R i p b o t 2 6 4 t e m p \ t o o l s \ x 2 6 4 \ x 2 6 4 _ x 6 4 . e x e F i l e : e n c o d e r / s l i c e t y p e . c , L i n e 1 9 8 9 E x p r e s s i o n : c o s t > = 0 |
8th August 2019, 08:13 | #17088 | Link | |
The location of the error and its description appear to me like a miscalculation in the x264 encoder; I wonder if the reason may be the OpenCL acceleration processing wrong data, maybe due to task switching... bold guess.
__ Quote:
8th August 2019, 08:16 | #17089 | Link | |
Yes Show log doesn't show anything Tried that, even removed the job and added it again
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
8th August 2019, 08:39 | #17090 | Link | |
8th August 2019, 09:25 | #17091 | Link |
Can I ask why lsmash is now the default decoder? What is the advantage?
I only ask because preparing the jobs now seems much slower. Cropping takes much longer and it seems to take too long each time I refresh the preview frame (to find a bright coloured frame for cropping accurately). Is this due to lsmash? Last edited by duffbeer; 8th August 2019 at 09:28. |
8th August 2019, 10:02 | #17092 | Link | |
https://forum.doom9.org/showthread.p...93#post1879893 lsmash also has better support for interlaced AVC (does not duplicate frame count).
8th August 2019, 10:25 | #17093 | Link | |
Does this change explain the speed problems I mentioned? I may have to go back to 1.24 as the new version is much slower now. |
8th August 2019, 11:22 | #17094 | Link |
Lsmash tries to be more accurate while seeking.
9th August 2019, 05:27 | #17096 | Link |
Hi, is is possible to modify the encoding server to work on a separate network?. specifically I have a few idle pc's that are offsite and would like to utilize them for encoding. We dont want to create a VPN. Is this a request that could be in the future?. RipBot264 works great with the few pc's that we have on the same Lan ??, a few more would definitely help
9th August 2019, 14:20 | #17099 | Link | |
--sar <width:height|int> Sample Aspect Ratio, the ratio of width to height of an individual pixel. Choose from 0=undef, 1=1:1("square"), 2=12:11, 3=10:11, 4=16:11, 5=40:33, 6=24:11, 7=20:11, 8=32:11, 9=80:33, 10=18:11, 11=15:11, 12=64:33, 13=160:99, 14=4:3, 15=3:2, 16=2:1 or custom ratio of <int:int>. Default 0
9th August 2019, 16:24 | #17100 | Link | |
ByteShare
That would seem like a security risk IMO. |
