6th August 2008, 20:24 | #2122 | Link |
I dont care so should you
You know you can make your own profiles... Just because you have presets does not mean you have to use them...
Cropping and resize are taken care of by by AVIsynth
My Installer's || Last edited by Ajax_Undone; 6th August 2008 at 20:56. |
6th August 2008, 23:49 | #2123 | Link | |
8th August 2008, 02:45 | #2126 | Link |
Atak - As many have said, great program!
I'm having trouble with one of my TS files - I'm getting a message "No video sequence header found", then "No data. Check your PIDS." I'm able to open the same TS file with DGAVCIndex.exe and am able to demux video and audio. This is a H264 transport stream and every tool I have can open this - TSPE, TSRemux. Even displays with GraphEdit. Can you please help? Thanks. |
8th August 2008, 02:50 | #2128 | Link |
Atak - I found the video log, it appears maybe I have a bad rip? eac3to v2.56 command line: "C:\Users\Damian\Desktop\RipBot264v1.10.5\Tools\eac3to\eac3to.exe" "C:\Users\Damian\Videos\DVD Backup\30_DAYS_OF_NIGHT\" 1) 2:"G:\temp\RipBot264temp\job1\video.mkv" ------------------------------------------------------------------------------ M2TS, 1 video track, 6 audio tracks, 9 subtitle tracks, 1:53:06 1: Chapters, 16 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: TrueHD/AC3, English, 5.1 channels, 48khz 4: TrueHD/AC3, French, 5.1 channels, 48khz 5: AC3, Spanish, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB 6: AC3, Thai, 5.1 channels, 640kbit/s, 48khz 7: AC3, Portuguese, 5.1 channels, 640kbit/s, 48khz, dialnorm: -28dB 8: AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB 9: Subtitle (PGS), English 10: Subtitle (PGS), English 11: Subtitle (PGS), French 12: Subtitle (PGS), Spanish 13: Subtitle (PGS), Portuguese 14: Subtitle (PGS), Portuguese 15: Subtitle (PGS), Chinese 16: Subtitle (PGS), Thai 17: Subtitle (PGS), English [v02] Extracting video track number 2... [v02] Muxing video to Matroska... [v02] This TS/M2TS file seems to be damaged (sync byte missing). Aborted at file position 23341580288. |
8th August 2008, 03:22 | #2129 | Link |
Sample here
8th August 2008, 12:37 | #2131 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th August 2008 at 12:43. |
8th August 2008, 20:00 | #2132 | Link |
Why the hell does it always hang after encoding audio? It just sits there saying "Normalizing audio..." even after I have double checked that I have not selected it. And even if I have selected it. Anyone have a clue as to why this is happening and how to solve it? Oh, and btw, my Task Manager shows it's running BePipe for over an hour now and the total audio file is a little over 25 minutes, using a Core2Duo e6300. Shouldn't take more than a couple of minutes.
8th August 2008, 21:33 | #2134 | Link |
Atak - thanks. So just to clarify, I should remux the file with TSMuxer so I get a 264/AVC video file and an AC3 audio file. I would then use Ripbot, feed the individual video and audio file in to create the MKV? Sorry if this is a question you have answered many times, I really haven't needed to use TsMuxer more then a couple of times as Ripbot has handled everything I have thrown at it so far.
8th August 2008, 21:40 | #2135 | Link |
mpeg4.ts -> mpeg4_new.ts
8th August 2008, 22:26 | #2136 | Link |
Deus Ex Machina
I recently added subtitles to a Blu-Ray movie I created using RipBot. I selected two different subtitles: one English and the other Spanish (and in that order).
However, whenever I attempt to choose the English subtitles on the Blu-ray movie, nothing shows up. The Spanish subtitles are the only ones that can be displayed. I decided to use MediaInfo to see if the English subtitles were even placed into the movie to begin with. They were. However, I found something odd in the information it gave me about the subtitles. Here is the info I gathered concerning the subtiltes: Code:
Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Video delay : 52mn 42s Language : English Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Language : Spanish
Don't live your life celebrating victories, but overcoming defeats. -Ernesto "Che" Guevara Last edited by dm1105; 8th August 2008 at 22:28. |
8th August 2008, 22:46 | #2137 | Link |
Send me english subtitles (.srt file)
8th August 2008, 23:01 | #2138 | Link |
I can't run RipBot, since MP4box crashes when I try to open the input file. It's an mp4, it's 3.6 Gb and Windows Media Player says it contains the following:
Video: MPEG4 Video (H264) 1136x640 [Video] Audio: AAC 48000Hz stereo 1536Kbps [Audio] What's wrong? I've tried removing codec packs, still no go. Are there size limits? Limits on filenames? I start RipBot, try to load the file, MP4box crashes and RipBot says the audio is missing. I have no logs. Oh, and how do I update all the tools used by RipBot? |
9th August 2008, 03:03 | #2139 | Link |
Hi! I am trying to encode m2ts into H.264.
RipBot264v1.10.5 ffdshow_rev2063_20080804_clsid Vista Other required componets are installed. An m2ts file is loaded ok. Audio is AAC. Finished, created .m2ts, not mp4. I checked "save as mp4" in the menu. The log is attached. Any other components are missing ? edit-------------- I forgot to change the default output directory. In Vista C: cannot be used. I changed it to p:, now it is ok. mp4 is created. But with no audio. Is AAC 2ch audio in m2ts not supported ? Last edited by pjo; 9th August 2008 at 06:55. |
9th August 2008, 07:03 | #2140 | Link |
Where did you get .m2ts with AAC audio? I have newer seen blu-ray/AVCHD video with AAC audio.
