7th September 2017, 16:54 | #2481 | Link |
You can find mClean in the Filter Profiles editor on the defaults tab.
7th September 2017, 18:19 | #2482 | Link |
The option "Prevent system entering standby mode while encoding" does not work anymore. The system is entering standby mode after the time set in the windows options while StaxRip is encoding.
During the encode process I only have the job processing window open, no other StaxRip window. StaxRip 1.6.0.9 Windows 7 |
7th September 2017, 18:19 | #2483 | Link | |
Noob
https://forum.doom9.org/showthread.php?t=174804 i copy pasted mclean line from default tab to edit tab in filer profiles Last edited by Natty; 7th September 2017 at 18:24. |
7th September 2017, 18:31 | #2484 | Link |
@Natty:
Fire up StaxRip. Go to Apps. Go to Manage. Scroll down to find FFTW. Open FFTW. The last words are self explaining... This is the simple way to put the right 64bit FFTW file to your Windows\system32 directory. |
7th September 2017, 22:53 | #2486 | Link | |
Requirements .NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update) https://www.microsoft.com/en-us/down....aspx?id=55170 Download https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://1drv.ms/f/s!ArwKS_ZUR01goCzIRemxotXY_zz- 1.6.1.4 unstable test build
8th September 2017, 14:47 | #2488 | Link |
I'll run some tests today and see if I can reproduce it. Are there people that can confirm that it's working correctly on their system?
9th September 2017, 14:31 | #2489 | Link |
Nice job with the progress bar.
Great experience working with StaxRip. Thanks for the update.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
10th September 2017, 02:57 | #2491 | Link |
Guys,
I really would like to try the fdkaac. Can someone teach us how to install the encoder? Preferably something that has been compiled already Thaanks
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
10th September 2017, 03:19 | #2492 | Link |
@burfadel
I don't remember how it was before and when it was changed, the parsing code is simple, it reads the number before the percent character, the GUI is only refreshed if this number changes, keep in mind that additional parsing and drawing would use CPU time. There are some tools, I think it was eac3to and mkvtoolnix that have only 1 percent intervals, I can live with that.
10th September 2017, 05:10 | #2493 | Link |
I would bet real money that some number of releases back I was able to test AMD H.265 hardware encoding. I have been using the same PowerColor R9 380 video board since December 2016. I am now using a newer release of Windows 10 (build 16278) and a newer version of StaxRip. Now whenever I try to do an AMD H.265 encode I almost immediately get an error from VCEEncC 3.06 x64. The last line of the error window seems to give the relevant information: Failed to AMFCreateComponent: AMF_ENCODER_NOT_PRESENT, Finished with error in VCEEncC. I am also getting the same error on a newer PowerColor R9 380X Myst Edition board.
According to information I was able to ferret from the AMD website, both the R9 380 and R9 380X are Tonga generation boards and do have the H.265 encoder on board. According to HWInfo64, both boards show as Tonga. Am I imagining things and that H.265 encoding never worked on the R9 380 boards? I distinctly remember my test cases because i remember the video board fans going to near full speed while the encode was running and then returning to normal speed once done. What am I missing to make this all work? |
10th September 2017, 06:28 | #2494 | Link | |
10th September 2017, 12:34 | #2495 | Link |
I got some stalls on the progressive bar too.
Firstly I thought the encoding just stalled, but the GPU was working fully, so waiting a little more I saw a huge jump from 5% to 80% or something like that. The truth is that I use StaxRip on batch mode, so I almost never monitor the whole process. I just leave it to do its job.
10th September 2017, 12:46 | #2496 | Link |
@Khun_Doug
You can try to post on the vceenc tracker. https://github.com/rigaya/VCEEnc/issues @burfadel Turned out my custom control didn't repaint when the text property changes. @Nikos Maybe it's fixed in the new build. Requirements .NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update) https://www.microsoft.com/en-us/down....aspx?id=55170 Download https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://1drv.ms/f/s!ArwKS_ZUR01goCzIRemxotXY_zz- 1.6.1.5 unstable test build
11th September 2017, 19:42 | #2498 | Link |
@VfBFan
@Magik Mark I've made two tests, one on my Win 10 system and one on my Win 7 test system using vmware, on both systems I had standby time set to 5 Minutes and was running a 10 minute encode which successfully completed and successfully executed shutdown, the code for shutdown runs shutdown.exe, it's very simple and it wasn't much changed lately. https://github.com/stax76/staxrip/bl...neral.vb#L1447 The code for standby prevention wasn't changed since very long. If it happens again please use the bug tracker and if possible click on the star (only few stars are missing for second most popular VB.NET project).
12th September 2017, 06:36 | #2500 | Link |
Stax
Can you also put progress bar in encoding audio streams? Thanks
