12th January 2012, 08:17 | #1401 | Link |
I can confirm this bug, although I haven't got an idea as to the exact cause. The first MKV file I attempted to index using MeGUI caused ffmsindex to crash. It'll demux the audio stream, but it won't index.
I also tried using a basic script (because that's all I know) but it refused to index the file. LoadPlugin("C:\Program Files\ffms2\ffms2.dll") FFVideoSource("E:\video.mkv") Normally just opening the above script would cause the file to be indexed, but instead when opening it with MPC-HC I got: Evaluate: System Exception - Access Violation E:\script.avs, line 2 The MKV file contains AVC video, DTS audio and srt subtitles. Removing the subtitles when remuxing fixed the problem (I don't think removing the audio made any difference). Remuxing the MKV while retaining all three streams still caused ffmsindex to crash. Reverting to the previous ffms version used by MeGUI (seems to be r588) returned everything to normal. Here's a sample. |
13th January 2012, 15:05 | #1404 | Link |
Image corruption in VC-1 (.m2ts remuxed to .mkv using eac3to)
Script Code:
LoadPlugin("..\ffms2.dll") #rev624 FFVideoSource("..\video.mkv",threads=1) #seekmode=0 and -1 do not help either Trim(240,240)
14th January 2012, 00:41 | #1405 | Link | |
47.952fps@71.928Hz
I loaded the source mkv into VDub with ffms2 rev624. Exact script you posted. While it does show that the invidual frame is corrupted as you posted. I decided to encode to x264. The resulting encode turned out perfectly without any corruptions, especially in frame 240. Frame 240 after encoding to x264 x264 codec via Vdub 1.9.11/1.10.1 experimental (December 24, 2011) x264 settings I'm not entirely sure, but it just maybe the program having a hiccup when displaying the video. Resulting Test: Code:
http://www.mediafire.com/download.php?xw8vwdsfv7nau09
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
14th January 2012, 12:40 | #1406 | Link |
could you try with x264 cli?
14th January 2012, 14:15 | #1407 | Link |
47.952fps@71.928Hz
I did with a very simple function.
(x264 build: x264 core:120 r2120 0c7dab9(from http://x264.nl/)) Code:
x264 --crf 19 -o "E:\Work\test_cli.mkv" E:\Work\video.mkv" D:\App Bin\x264\32bit 8bit-depth>x264 --crf 19 -o "E:\Work\test_cli.mkv" E:\Work\video.mkv" ffms [info]: 1920x1080p 1:1 @ 24000/1001 fps (vfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Slow SlowCTZ x264 [info]: profile High, level 4.0 x264 [info]: frame I:12 Avg QP: 9.09 size: 56780 x264 [info]: frame P:865 Avg QP:18.32 size: 38949 x264 [info]: frame B:720 Avg QP:23.24 size: 5039 x264 [info]: consecutive B-frames: 35.1% 13.1% 3.9% 47.8% x264 [info]: mb I I16..4: 61.0% 30.5% 8.5% x264 [info]: mb P I16..4: 4.7% 6.2% 1.2% P16..4: 25.3% 10.3% 5.4% 0.0% 0.0% skip:47.0% x264 [info]: mb B I16..4: 0.3% 0.1% 0.0% B16..8: 8.9% 1.4% 0.4% direct: 1.2% skip:87.7% L0:32.8% L1:48.0% BI:19.2% x264 [info]: 8x8 transform intra:48.8% inter:67.8% x264 [info]: coded y,uvDC,uvAC intra: 43.6% 47.6% 22.8% inter: 12.9% 11.1% 1.7% x264 [info]: i16 v,h,dc,p: 72% 13% 4% 11% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 13% 32% 6% 8% 8% 5% 5% 8% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 21% 25% 6% 7% 6% 6% 4% 6% x264 [info]: i8c dc,h,v,p: 64% 16% 17% 3% x264 [info]: Weighted P-Frames: Y:15.3% UV:9.1% x264 [info]: ref P L0: 65.8% 16.8% 12.5% 4.6% 0.3% x264 [info]: ref B L0: 87.8% 10.2% 2.0% x264 [info]: ref B L1: 96.7% 3.3% x264 [info]: kb/s:4563.98 encoded 1597 frames, 3.88 fps, 4564.06 kb/s Code:
General Complete name : E:\Work\test_cli.mkv Format : Matroska Format version : Version 2 File size : 36.3 MiB Duration : 1mn 6s Overall bit rate : 4 568 Kbps Writing application : x264 r2120 0c7dab9 Writing library : Haali Matroska Writer b0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1mn 6s Bit rate : 4 478 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 1.199 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 1.801 Stream size : 35.6 MiB (98%) Writing library : x264 core 120 r2120 0c7dab9 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No But eac3to was able demux the resulting video to elementary stream of x264. I loaded the ES x264 into "DGAVCIndex" and saved the project. However... The fps turned out to be a constant 25fps... Code:
Stream Type: AVC Elementary Profile: High Level: 4 Frame Size: 1920x1080 SAR: 1:1 Display Size: 1920x1080 Frame Rate: 25.000000 fps Colorimetry: BT.709* [2] Frame Structure: Frame Frame Type: not yet Coded Number: 250 Playback Number: 250 Frame Repeats: 0 Field Repeats: 0 Bitrate: 10.391 Bitrate (Avg): 6.519 Bitrate (Max): 11.388 Elapsed: 0:00:00 Remain: 0:00:00 FPS: Info: Finished! I usually use Vdub or other with it ^_____^ Here's the resulting video in MKV format, using x264 (core:120 r2120 0c7dab9)... Code:
deleted, uploading proper converted file
14th January 2012, 14:35 | #1408 | Link | |
BTW, has anyone considered using Intel Media SDK software decoder inside FFMS? It would be a nice solution for interlaced VC-1 decoding. |
14th January 2012, 15:17 | #1409 | Link |
@Sparktank
you were supposed to encode my script not video.mkv !
14th January 2012, 21:18 | #1410 | Link | |
47.952fps@71.928Hz
x264 log: Code:
D:\App Bin\x264\32bit 8bit-depth>x264 --crf 19 -o "E:\Work\test_cli.mkv" E:\Work\ffms_test.avs" avs [info]: 1920x1080p 0:0 @ 24000/1001 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2Slow SlowCTZ x264 [info]: profile High, level 4.0 x264 [info]: frame I:12 Avg QP: 9.09 size: 56786 x264 [info]: frame P:865 Avg QP:18.30 size: 38968 x264 [info]: frame B:720 Avg QP:23.28 size: 5030 x264 [info]: consecutive B-frames: 35.1% 13.1% 3.9% 47.8% x264 [info]: mb I I16..4: 60.9% 30.5% 8.5% x264 [info]: mb P I16..4: 4.6% 6.2% 1.2% P16..4: 25.3% 10.3% 5.4% 0.0% 0.0% skip:47.0% x264 [info]: mb B I16..4: 0.3% 0.1% 0.0% B16..8: 8.8% 1.4% 0.4% direct: 1.2% skip:87.8% L0:32.6% L1:48.1% BI:19.4% x264 [info]: 8x8 transform intra:48.8% inter:67.7% x264 [info]: coded y,uvDC,uvAC intra: 43.6% 47.6% 22.7% inter: 12.9% 11.1% 1.7% x264 [info]: i16 v,h,dc,p: 72% 13% 4% 11% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 13% 32% 6% 8% 8% 5% 6% 8% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 21% 25% 6% 7% 6% 6% 4% 6% x264 [info]: i8c dc,h,v,p: 64% 16% 17% 3% x264 [info]: Weighted P-Frames: Y:15.3% UV:9.1% x264 [info]: ref P L0: 65.8% 16.8% 12.5% 4.7% 0.3% x264 [info]: ref B L0: 87.8% 10.2% 2.0% x264 [info]: ref B L1: 96.7% 3.3% x264 [info]: kb/s:4565.26 encoded 1597 frames, 3.81 fps, 4565.35 kb/s New conversion with AVS, new upload, same name. Code:
http://www.mediafire.com/download.php?1ag4lcvbpqdu5jd
14th January 2012, 22:18 | #1411 | Link |
wrong again! you encoded whole file without trim!
14th January 2012, 22:26 | #1412 | Link |
warpsharpened
Like I said on the bug tracker it works if it's accessed linearly. Doing trim(x,y) (where x isn't 0) counts as seeking. I don't know why there is corruption when seeking. Threads > 1 also appears to work correctly if accessed linearly.
14th January 2012, 22:59 | #1413 | Link |
maybe this is just a coincident but with trim(242,...) frame is not corrupted. according to mkvinfo frame 242 (10.082s) is a location of next cluster timecode. btw how to get list of keyframes with ffindex.exe?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 14th January 2012 at 23:03. |
15th January 2012, 18:47 | #1414 | Link |
Another example that there is seriously something wrong with VC-1 decoding while seeking
Now We have frame 1 mixed with frame 968 plus nice blocks. Probably the same happens with my previous example! Script Code:
LoadPlugin("..\ffms2.dll") FFVideoSource("..\video.mkv",threads=1) Trim(967,967)
17th January 2012, 12:14 | #1415 | Link |
ffms2-r624 crashes when parsing DVB-S .ts
Hi everyone,
A friend recorded some 'ITV HD' stream in 1080i and now wants to process it further. I recommend him to use the latest ffms2 release 624. But parsing the file throws error: Insanity detected: Decoder returned an empty frame Here is a snipp of his recording -> http://www.megaupload.com/?d=S7719U3P I hope you guys could have a look at. I was able to open and index/demux it with DGAVCdecode ... Last edited by may24; 17th January 2012 at 13:10. |
18th January 2012, 01:35 | #1416 | Link |
Excessively jovial fellow
MPEG TS support is even more broken than usual in r624, due to a regression introduced in r615. We're working on it. In the meantime you can remux the file to MKV with eac3to or just use 2.16.
18th January 2012, 23:03 | #1419 | Link |
I'm trying to compile the latest FFMS2 revision against the latest FFmpeg revision, but I keep getting the following error in the ./configure-phase.
checking for LIBAV... yes checking whether linking with FFmpeg or Libav... FFmpeg checking whether FFmpeg works... no configure: error: in `/home/<user>/tmp/ffms2': configure: error: cannot link with FFmpeg Code:
./configure --disable-everything --enable-gpl --enable-postproc --enable-protocols --enable-demuxer=matroska,ogg,avi,h264,mov,m4v,mpegts,mpegvideo --enable-decoder=h264,vc1,wmv*,mpeg2video,mpeg1video,mpeg4,theora,vp8 --enable-parser=h264,mpeg4video,mpegvideo,vc1,vp8 --prefix=/home/<user>/build make make install Code:
LIBAV_CFLAGS=-I/home/<user>/build/include LIBAV_LIBS=-L/home/<user>/build/lib ./configure --prefix=/home/<user>/build make make install |
18th January 2012, 23:37 | #1420 | Link | |
