Old 2nd June 2010, 16:02   #1341  |  Link
nevragain
Quick related question what about UTF-16?
nevragain is offline   Reply With Quote
Old 3rd June 2010, 02:50   #1342  |  Link
trabanom
Originally Posted by MrC View Post
@trabanom
your subs file is a ANSI format srt. Right now AVStoDVD does not handle special chars from ANSI files (next release will do). Simple workaround: open your srt files with Notepad and "save as" UTF-8 format. That's all.
Bye
Thanks. It worked perfect.
trabanom is offline   Reply With Quote
Old 3rd June 2010, 11:37   #1343  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Not supported. If anybody finds a UTF16->ANSI or UTF16->UTF8 conversion function (better if written in VB ), please share it.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 11th June 2010, 22:21   #1344  |  Link
TechiePatriot
I updated AVS2DVD to the new version 2.3.0 today. I have been using AVS2DVD for creating menu based DVD's. I was taking some MPG2 streams I made from capturing some old VHS tapes to make a DVD with (I'm using Pinnacle Studio 11). But both the 2.2.5 and 2.3.0 version seem to be hosing up the menu playback. I can create the menu fine and it has the 3 videos on it. But when I generate the DVD structure and select a menu option two of the options are playign the same video. For the one that seems hosed it starts to play it for about 2 seconds then it switches to playing one of the other videos. Does anyone know if there are some "glitches" in the menuing?
Note: I'm new to all this kind of stuff.
Thanks,
TechiePatriot is offline   Reply With Quote
Old 13th June 2010, 16:44   #1345  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Hi TechiePatriot,
first of all, welcome here.
Just 2 quick questions to better understand the problem:
1. Have you tried to burn the DVD and play the disc in a standalone DVD player? Same issue?
2. What operating system are you using?
3. Do you still have the log file generated by AVStoDVD? If yes, please post it.
Let me know
Bye
MrC
AVStoDVD Homepage
Old 15th June 2010, 03:03   #1346  |  Link
TechiePatriot
Hi TechiePatriot,
Let me know
Bye
1)
I was able to burn the DVD and the Menu and DVD worked fine. It looks like it just won't work in PowerDVD (V7.3).
2)
I am using WinXPSP2
3) Log:
<6/14/2010 5:34:56 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 3
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: Lana1
DVD Menu: Static Menu
Output Folder: O:\Temp\DVD
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6000
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: LITE-ON DVDRW LH-20A1H LL06
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: M:\_PinnacleProjects\Vacations\Tape1\Vacation06172001.d2v
Info: DGIndex - 6294 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (BFF) - 30:56 minutes - 55635 frames
Audio 1: M:\_PinnacleProjects\Vacations\Tape1\Vacation06172001 Tc0 L2 2ch 48 224 DELAY 0ms.mp2
Info: MPEG-1 Audio layer 2 - 224 kbps - CBR - 2ch - 48000Hz - 30:56 minutes - External
Subs:
[A2DInfo.avsi]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files\AVStoDVD\DGIndex\DGDecode.dll")
LoadPlugin("C:\Program Files\AVStoDVD\Lib\LeakKernelDeint.dll")
Video = MPEG2Source("M:\_PinnacleProjects\Vacations\Tape1\Vacation06172001.d2v")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("M:\_PinnacleProjects\Vacations\Tape1\Vacation06172001 Tc0 L2 2ch 48 224 DELAY 0ms.mp2", CacheFolder = "R:\Temp")
Video = Video.ConvertToYV12(interlaced = true)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: QuEnc CBR 1-pass
Target Video FileSize: 1711.6 MB
QuEnc Parameters: -i "R:\Temp\Vacations1_0_Title_01_Vacation06172001_1.avs" -o "O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001.m2v" -b 7736 -1 -hq -novbr -scene -trell -aspectratio 4:3 -interlaced -bff -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<6/14/2010 6:19:04 PM>
END VIDEO ENCODING OPERATIONS
Created File: O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001.m2v (1711.9 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7736 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (BFF) - 30:54 minutes - 55579 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "M:\_PinnacleProjects\Vacations\Tape1\Vacation06172001 Tc0 L2 2ch 48 224 DELAY 0ms.mp2" -acodec copy "O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001_1.ToFix.mp2"
<6/14/2010 6:19:09 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001_1.mp2 (49.6 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 224 kbps - CBR - 2ch - 48000Hz - 30:56 minutes
TITLE 2 SOURCE FILES
Video: M:\_PinnacleProjects\Vacations\Tape2\Vacation2008.d2v
Info: DGIndex - 6292 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (BFF) - 30:59 minutes - 55740 frames
Audio 1: M:\_PinnacleProjects\Vacations\Tape2\Vacation2008 Tc0 L2 2ch 48 224 DELAY 0ms.mp2
Info: MPEG-1 Audio layer 2 - 224 kbps - CBR - 2ch - 48000Hz - 30:59 minutes - External
Subs:
[A2DInfo.avsi]
AVISYNTH SCRIPT
Video = MPEG2Source("M:\_PinnacleProjects\Vacations\Tape2\Vacation2008.d2v")
Audio = A2DAudioSource("M:\_PinnacleProjects\Vacations\Tape2\Vacation2008 Tc0 L2 2ch 48 224 DELAY 0ms.mp2", CacheFolder = "R:\Temp")
Target Video FileSize: 1715.3 MB
QuEnc Parameters: -i "R:\Temp\Vacations1_0_Title_02_Vacation2008_1.avs" -o "O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008.m2v" -b 7736 -1 -hq -novbr -scene -trell -aspectratio 4:3 -interlaced -bff -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<6/14/2010 7:10:21 PM>
Created File: O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008.m2v (1715.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7736 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (BFF) - 30:58 minutes - 55684 frames
FFmpeg Parameters: -i "M:\_PinnacleProjects\Vacations\Tape2\Vacation2008 Tc0 L2 2ch 48 224 DELAY 0ms.mp2" -acodec copy "O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008_1.ToFix.mp2"
<6/14/2010 7:10:26 PM>
Created File: O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008_1.mp2 (49.7 MB)
OUTPUT AUDIO INFO: MPEG-1 Audio layer 2 - 224 kbps - CBR - 2ch - 48000Hz - 30:59 minutes
TITLE 3 SOURCE FILES
Video: M:\_PinnacleProjects\Vacations\Vacation08102009\Vacation08102009.d2v
Info: DGIndex - 8500 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (TFF) - 14:32 minutes - 26145 frames
Audio 1: M:\_PinnacleProjects\Vacations\Vacation08102009\Vacation08102009 T80 2_0ch 384Kbps DELAY 0ms.ac3
Info: AC3 - 384 kbps - CBR - 2ch - 48000Hz - 14:32 minutes - External
Subs:
[A2DInfo.avsi]
AVISYNTH SCRIPT
Video = MPEG2Source("M:\_PinnacleProjects\Vacations\Vacation08102009\Vacation08102009.d2v")
Audio = A2DAudioSource("M:\_PinnacleProjects\Vacations\Vacation08102009\Vacation08102009 T80 2_0ch 384Kbps DELAY 0ms.ac3", CacheFolder = "R:\Temp")
Target Video FileSize: 804.2 MB
QuEnc Parameters: -i "R:\Temp\Vacations1_0_Title_03_Vacation08102009_1.avs" -o "O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009.m2v" -b 7736 -1 -hq -novbr -scene -trell -aspectratio 4:3 -interlaced -tff -mpeg2mux noaudio -dc 10 -priority 5 -auto -close
<6/14/2010 7:36:58 PM>
Created File: O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009.m2v (804.4 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 7736 kbps - 720x480 - DAR 1.333 - 29.97 fps (CFR) - Interlaced (TFF) - 14:31 minutes - 26119 frames
FFmpeg Parameters: -i "M:\_PinnacleProjects\Vacations\Vacation08102009\Vacation08102009 T80 2_0ch 384Kbps DELAY 0ms.ac3" -acodec copy "O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009_1.ToFix.ac3"
<6/14/2010 7:37:03 PM>
Created File: O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009_1.ac3 (39.9 MB)
OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 2ch - 48000Hz - 14:32 minutes
START DVD MENU BUILDING OPERATIONS
DVD Menu settings: Style 0, DAR 0, Titles Format 1, Video BitRate 6000, Menu Pages 1, Menu Titles 3
<6/14/2010 7:37:09 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): R:\Temp\Vacations1_0_MenuPage1.bmp (1 MB)
Created File: R:\Temp\Vacations1_0_Menu.ac3 (0.3 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "R:\Temp\Vacations1_0_BatchMux.ini"
BatchMux ini file:
-d "O:\Temp\DVD\Vacations1_0\VIDEO_TS"
-mxp "R:\Temp\Vacations1_0_MuxMan.mxp"
-l "R:\Temp\Vacations1_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001.m2v"
-vidmode 4:3
-a1 "O:\Temp\DVD\Vacations1_0_Title_01_Vacation06172001_1.mp2"
-a1lang en
-cellfr "R:\Temp\Vacations1_0_Title_01_Vacation06172001_MuxMan.txt"
-progfr "R:\Temp\Vacations1_0_Title_01_Vacation06172001_MuxMan.txt"
-chapfr "R:\Temp\Vacations1_0_Title_01_Vacation06172001_MuxMan.txt"
-SEG2v "O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008.m2v"
-SEG2vidmode 4:3
-SEG2a1 "O:\Temp\DVD\Vacations1_0_Title_02_Vacation2008_1.mp2"
-SEG2a1lang en
-SEG2cellfr "R:\Temp\Vacations1_0_Title_02_Vacation2008_MuxMan.txt"
-SEG2progfr "R:\Temp\Vacations1_0_Title_02_Vacation2008_MuxMan.txt"
-SEG2chapfr "R:\Temp\Vacations1_0_Title_02_Vacation2008_MuxMan.txt"
-SEG3v "O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009.m2v"
-SEG3vidmode 4:3
-SEG3a1 "O:\Temp\DVD\Vacations1_0_Title_03_Vacation08102009_1.ac3"
-SEG3a1lang en
-SEG3cellfr "R:\Temp\Vacations1_0_Title_03_Vacation08102009_MuxMan.txt"
-SEG3progfr "R:\Temp\Vacations1_0_Title_03_Vacation08102009_MuxMan.txt"
-SEG3chapfr "R:\Temp\Vacations1_0_Title_03_Vacation08102009_MuxMan.txt"
-SEG4v "R:\Temp\Vacations1_0_MenuPage1.bmp"
-SEG4vidmode 4:3
-SEG4a1 "R:\Temp\Vacations1_0_Menu.ac3"
-SEG4s1 "R:\Temp\Vacations1_0_Menu.sst"
-SEG4s1dmode LB
-SEG4hlmnu "R:\Temp\Vacations1_0_MenuPage1_Buttons.mnu"
-SEG4hlcsm "R:\Temp\Vacations1_0_HighlightScheme.csm
-hcn "R:\Temp\Vacations1_0_BatchMux.hcn"
<6/14/2010 7:43:29 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 4458.5 MB
vs Estimated Size: 4450 MB -> 0.2% oversize
vs Assets Size: 4371.9 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: O:\Temp\DVD\Vacations1_0 (4458.5 MB)
Log file created by AVStoDVD Release 2.3.0
Old 15th June 2010, 05:02   #1347  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Thus you have to complain with PowerDVD author... What about Media Player Classic?
From the log file, everything is OK.
Bye
MrC
AVStoDVD Homepage
Old 17th June 2010, 16:38   #1348  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
A new 2.3.1 (very very) Alpha has been released. No help file, no installer available.
Change log:
- Some bugs fixed
- Added 'DVD Subs Font' in 'Preferences'/'AuthoringBurning': allows change of font name, format and size for authored subs.
- Added 'Use PAL SpeedUp for NTSC-film to PAL' in 'Preferences'/'Encoding' (AssumeFPS() is used instead of DGPulldown to upsize fps)
- Added 'Save general Settings at program Exit' in 'Preferences'/'Misc' ('DVD Size', 'Output Setup', 'Advanced Project Settings' can be stored in the Windows Registry)
- Added 'MSharpen' AviSynth filter (by Donald Graft) in 'Title Edit'/'AviSynth'
- Added 'ColorMatrix' AviSynth filter (by Wilbert & Tritical) in 'Title Edit'/'AviSynth'
- Added 'SubsExtension' option in 'Title Edit'/'Subtitles'
- FFmpeg updated to r23107
- MediaInfo updated to 0.7.33
Any report is appreciated.
Bye
MrC
AVStoDVD Homepage
Old 27th June 2010, 14:50   #1349  |  Link
shreeit
I am using AVStoDVD 2.3.0 Mat release, which as HCenc beta. With the new version of AVStoDVD, my mkv to DVD conversion failed. This is due to HCenc. (I am trying to use HCenc vbr 2 option). Soon AVStoDVD started, I noticed HCenc process is not responding. and failed in few sec. ANy suggestion? thanks
shreeit is offline   Reply With Quote
Old 27th June 2010, 19:32   #1350  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@shreeit
some more details such as:
1. Operating System used
2. DirectShow codecs installed
3. Is Haali Media Splitter installed?
4. Does the problem happen only with 2.3.0 (with HCenc 0.24beta) or with 2.2.6 (with HCenc 0.23) too?
5. Copy and past AVStoDVD log file here
Have you read the Help section carefully? The FAQ can help you a lot.
Bye
MrC
AVStoDVD Homepage
Old 27th June 2010, 23:55   #1351  |  Link
shreeit
OS = WinXP SP3
HaaliSplitter installed.
I installed everything came in installation packege.
The Log file is as follows
<6/27/2010 8:45:28 AM>
START PROCESS
PROJECT SETTINGS
DVD Titles number: 1
DVD Label: DVD
DVD Menu: No Menu
Output Folder: F:
PREFERENCES
AVS Source Filter: AVISource
Video Resolution: 0
Video BitRate Level 1: 6500
DVD Audio Format: 0
Normalize Audio: 0
DVD Burning Drive: D: TSSTcorp CDDVDW SH-S203B SB00
DVD Burning Speed: 8x
Save Log file: 1
Video: G:\tmg-bb-720p-x264.mkv
Info: AVC - 3287 kbps - 1280x544 - DAR 2.353 - 23.976 fps (CFR) - Progressive - 2:34:44 hours - 222615 frames
Audio 1: G:\tmg-bb-720p-x264.mkv
Info: DTS - 768 kbps - CBR - 6ch - 48000Hz - 24bit - 2:34:44 hours - Internal
Subs:
[MediaInfoLib - v0.7.32]
AVISYNTH SCRIPT
Video = AVISource("G:\tmg-bb-720p-x264.mkv", audio=false)
# 'AVISource' replaced with 'DirectShowSource' for AC3 audio support
Audio = DirectShowSource("G:\tmg-bb-720p-x264.mkv", video=false)
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,88,0,88)
Video = Video.Spline64Resize(720,480)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3816.4 MB
HCenc Parameters: -ini "C:\Temp\DVD_1_tmg-bb-720p-x264.HCenc.ini"
HCenc ini file:
*INFILE C:\Temp\DVD_1_tmg-bb-720p-x264_1.avs
*AVSRELOAD
*OUTFILE F:\DVD_1_tmg-bb-720p-x264.m2v
*LOGFILE C:\Temp\DVD_1_tmg-bb-720p-x264.HCenc.log
*MAXBITRATE 9000
*BITRATE 3448
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<6/27/2010 8:45:46 AM>
PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
CHECK LOG FILE <F:\DVD_1.LOG> FOR MORE INFO.
Old 28th June 2010, 11:39   #1352  |  Link
rendez2k
rendez2k's Avatar
I've just tried converting an MKV to PAL DVD. What I've found is that the resulting disc has slight pauses every few seconds. I assume this is to do with converting 23->25 fps? Any ideas how to avoid this?
rendez2k is offline   Reply With Quote
Old 28th June 2010, 12:59   #1353  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@shreeit
please reply to questions 2. and 4.
Instead of starting the project, click on the 'Preview Clip' icon. If there is any AviSynth error message in the screen, please report it here. Thanks.
@rendez2k
Yes, it could be. New 2.3.1 Alpha has the option to use NTSC->PAL 4% speed up using AssumeFPS instead of DGPulldown. Just activate 'Preferences'/'Use PAL SpeedUp for NTSC-film to PAL' before adding your mkv to the project.
Let me know
Bye
MrC
AVStoDVD Homepage
Old 30th June 2010, 07:54   #1354  |  Link
rendez2k
rendez2k's Avatar
@rendez2k
Let me know
Bye
Well I tested it with a few samples. It doesn't have the larger pauses every few seconds but it doesn't seem perfectly smooth either.
Old 30th June 2010, 11:17   #1355  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Well, something better is better than nothing... take note that the 23.976->25 fps pulldown causes a very small jerk in video playback (every 0.5 seconds one field is repeated), not a large pause every few seconds, so maybe the cause is not (only) the pulldown effect.
Could you provide a small clip sample?
Bye
MrC
AVStoDVD Homepage
Old 30th June 2010, 14:01   #1356  |  Link
rendez2k
rendez2k's Avatar
Bye
No problem! I'll send you something when I get home tonight.
Old 1st July 2010, 13:35   #1357  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@rendez2k
thanks for sending the sample clip. It seems that the stuttering issue is caused by the 'convertfps=true' flag in the DirectShowSource call. Removing it, or using FFMpegSource, along with the NTSC->PAL 4% speed option on, video playback is smooth. Please confirm if it works for you as well.
As a matter of fact, 'convertfps=true' should be used when video framerate is variable (VFR). From the next release, I will add this flag only if it is really necessary.
Bye
MrC
AVStoDVD Homepage
Old 1st July 2010, 16:01   #1358  |  Link
shreeit
@Mrc:
The error:
AVIFileSource: Couldn't open file 'G:\tmg-bb-720p-x264.mkv'
(C:\Temp\AviSynthP.avs, Line 1)
2. DirectShow codecs installed -Yes
3. Is Haali Media Splitter installed? - Yes
Yes. I did not have problem in past.
Old 1st July 2010, 16:38   #1359  |  Link
@shreeit
Read and follow forum rules, especially rule 6.
@all
Do not respond further to shreeit's issue.
Old 1st July 2010, 17:12   #1360  |  Link
shreeit
Ok ..How about this..
@Mrc:
The error:
AVIFileSource: Couldn't open file 'G:\abc.mkv'
[IMG] code is Off
