Old 17th October 2019, 19:31   #17541  |  Link
slalom
slalom's Avatar
Originally Posted by Pauly Dunne View Post
So as great as DE is, there can be a LOT of time that the servers aren't doing anything..so if there was a way to have RB to at least start the next job, once the chunks of the previous job were completed, that could save a reasonable amount of time, and power.
But Temp disk is being used for the previous job, you will slow it down if the program starts a new job simultaneously
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
slalom is offline   Reply With Quote
Old 17th October 2019, 19:58   #17542  |  Link
byteshare
ByteShare
byteshare's Avatar
Good point. If you're muxing on the temp drive while trying to transfer the video to the job folder at the same time that would only compound things.
You'd have to pre-load the video for the next job once the current job starts to get around that but still not starting while the last job is muxing...tricky timing.
Old 17th October 2019, 23:46   #17543  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
You're probably correct, but at least while the muxing is being done, the next job is at least starting it's process, which could save some time & resource's.
Even if the muxing & copying was a little slower, you're not having to wait for one job to be completed.
But here's an idea, what if there was a second temp drive, and you allocated which temp drive to be used, when creating new jobs. (wouldn't work too well with batching)
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 18th October 2019, 03:06   #17544  |  Link
byteshare
ByteShare
byteshare's Avatar
That is kind of the point, it would slow it down enough that your next job would actually be encoding later than the way it works now. Yes, technically the job would "start" sooner but the time for the video to copy to the temp drive would take longer with the last job muxing at the same time.
The only way it would be "faster" is if once jobs are started the next job loads the video while the other job is still encoding, then muxing would happen and the next job would start, then while that job is still going but after the last muxing is done the next-next job would start copying the video...this only really works if your jobs are both small enough/slow enough encodes that the timing can work...like I was saying, it would be tricky and wouldn't be helpful in many cases.
...Ideally if some symbolic link to the original file could be used for the sharing (in DE) so that you wouldn't have to even copy a file, then it would be much simpler/faster to start the next job while the last job is muxing.
Wouldn't work for a lot of people I'd guess. Wouldn't work for me. I'd have to get a 3rd drive.
Old 18th October 2019, 04:04   #17545  |  Link
Pauly Dunne
Grumpy Old Man.
Good to see you've given this some thought, as well.
So I have to ask, do you do many, if any, 4K movie encodes, and how many pc's can you use for DE ??
I'm just trying to figure out some way to utilise the DE servers more energy efficiently. It just frustrates me to see several servers whirring away, using power, but not doing any encoding
Well, if I step up to using SDD's or NVMe's for the temp & encodes drives, I'm going to have to buy a LOT
But if a 2nd temp drive could be implemented, I think it would be worth having to buy another drive
Old 18th October 2019, 04:13   #17546  |  Link
Pauly Dunne
Grumpy Old Man.
Could you test your SSD/HDD in my benchmark tool?
http://www.mediafire.com/file/i630b6...Tester.7z/file
Upload MyLog.csv somewhere.
OK, have done your test's as requested, I hope I have provided the info you wanted to know.
I checked ALL the drives in that PC, just for comparison, some didn't have enough free space to do the 120Gb test, but the speeds are still relevant, I'd say.
Now remembering that these SSD's aren't anything special, they were just a few I had lying around.
http://www.mediafire.com/file/dqlf6c...sktop.rar/file
Old 18th October 2019, 04:48   #17547  |  Link
byteshare
ByteShare
byteshare's Avatar
I do some 4K. I've been doing more and more with time.
I have had up to 6 computers in DE mode, but right now I use 2 since upgrading some systems (made the others ones pointless), and 1-2 other computers with a local only DE mode. I see no reason you can't easily have
8-16 computers being used on one jobs (assuming longer/high CPU jobs).
The main thing is having a fast temp drive for large files.
The main thing would be using the SSD/M.2 for the temp drive (locally mux) then if you still want it somewhere else, have it auto-move to another drive with the new after job scripting to allow the next job will start while it is moving.
Old 18th October 2019, 15:17   #17548  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Your SSDs are even worse than your HDDs!
No wonder that muxing takes ages! You really need some good MLC SSD instead of those TLC garbage.
Old 18th October 2019, 16:03   #17549  |  Link
Pauly Dunne
Grumpy Old Man.
Not that surprised by that...I did say they were all I had...
So, what would you suggest...SSD's or PCI-e mounted NVMe's ??
Old 18th October 2019, 16:05   #17550  |  Link
byteshare
ByteShare
byteshare's Avatar
Wow, I've never seen that. Maybe they're also near the end of their life?
TY for the graphs.
Those or M.2. Pretty much any drive that does 500MB/s or more read/write, which is pretty common these days.
I have an M.2 that does around 2GB/s for read/write.
Old 18th October 2019, 16:19   #17551  |  Link
Pauly Dunne
Grumpy Old Man.
TY for the graphs.
Yeah, pretty bad
Thanks, I'll get the best I can that will suit my MB (no native support)
Old 18th October 2019, 16:21   #17552  |  Link
Atak_Snajpera
TY for the graphs.
No, it is because SLC cache is tiny (around 3 GiB)
Obviously something using NVMe. Downside of PCI-e is that you most likely won't be able to boot from that drive. Before you buy anything make sure that write speed is good across whole capacity. Do not be fooled by that SLC-cache used in TLC/QLC drives.
Old 19th October 2019, 00:28   #17553  |  Link
mparade
1) Source files are on your home PC.
2) Work PC just needs EncodingServer.exe running!
3) The idea is that you connect via VPN to work PC and then Work PC sees shared folder (for example \\HOME-PC\RipBot264temp) on Home PC.
With VPN connection established using my remote PC, servers of the remote PC remain in offline mode even after trying to connect to them from home PC (after pressing ON button it tries to connect to remote servers but after some second it returns to offline mode again). Should I set something else as well? My admin told VPN now should be working. Please help. Thank you.
mparade is offline   Reply With Quote
Old 19th October 2019, 02:18   #17554  |  Link
Pauly Dunne
Grumpy Old Man.
Hey, well, I think I've decided what I want to try, and that is get a couple of NVMe PCI-e Adapter's, and maybe 500Gb M.2 Samsung 970's (or similar).
Might as well spend a little more, than "settle" for some "fast" SSD's, they are so 2017
And to a point that Atak made, PCI-e mounted NVMe's may not boot, but I won't be using them as the boot / OS drive.
Old 19th October 2019, 02:23   #17555  |  Link
Pauly Dunne
Grumpy Old Man.
I just noticed that these are depicted as being Green HDD's, but indeed, they were Green SSD's in a RAID 0...
So that show's you how piss weak they are !!!
Old 19th October 2019, 07:54   #17556  |  Link
byteshare
ByteShare
byteshare's Avatar
Can you reach the share manually from the remote PC?
Can you ping the remote PC?
Old 19th October 2019, 07:59   #17557  |  Link
Pauly Dunne
Grumpy Old Man.
Could you please give me your honest opinion on these items ??
NVMe PCI-e adaptors
https://www.amazon.com/Silverstone-S...1467552&sr=8-7
or
https://www.amazon.com/SilverStone-T...1467714&sr=8-3
500Gb NVMe's
https://www.amazon.com/XPG-SX8200-Ge...1467837&sr=8-1
or
https://www.amazon.com/Samsung-970-E...s%2C387&sr=8-2
At this stage, I think I would go a 500Gb for the temp drive, and 250Gb for the encode drive, and just "clean up" after every job or 2.
Old 19th October 2019, 13:32   #17558  |  Link
Atak_Snajpera
Like I said, if you can afford buy Samsung 970 PRO (MLC)... Adata sx8200 also looks good until 60GiB mark.
Old 19th October 2019, 14:03   #17559  |  Link
Atak_Snajpera
1) run encodingserver.exe on remote pc and take a screenshot.
2) run ripbot264.exe on your home pc. go to settings->Distributed encoding and show me what client ips are listed under CLIENT IP
3) Are you sure firewall on remote pc does block connection?
Old 19th October 2019, 14:11   #17560  |  Link
Pauly Dunne
Grumpy Old Man.
I would be interested to see this info for the new'ish 970 Plus.
Found some :- not too good
https://www.tomshardware.com/reviews...sd,5608-2.html
Adata is 2nd best, but a fair bit off the mark
I think the Pro is a little too exy for me, the Plus is substantially cheaper, but might be only a little "slower"
And are those adapters suitable ??
