9th December 2013, 11:35 | #381 | Link |
1.3.0
1.3.0 was tagged.
But is there an official announcement somewhere other than the git tag? Download section still only has 1.2.0. |
9th December 2013, 11:49 | #382 | Link |
Swallowed in the Sea
From the changelog file...
9th December 2013, 16:21 | #383 | Link |
Compiled vpxenc&vpxdec using https://github.com/jb-alvarado/media-autobuild_suite
but either something is wrong with that build script or vpx is simply broken. lossless creates a 1byte file normal vp9 and vp9 encoding produces an output where it looks like that the color space got totally mixed up. -> Can someone compile and upload current vpxenc so I can check with that and contact jb-alvarado or the vpxenc devs depending on where the problem is. Code:
mencoder -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -demuxer lavf -vfm ffmpeg -noskip -vf scale,format=i420 -forcedsubsonly -nosub -nosound -mc 0 "H:\TESTCL~1\test.avi" | vpxenc --codec=vp9 --passes=1 --pass=1 --target-bitrate=1500 --end-usage=vbr --profile=0 --good --cpu-used=3 --undershoot-pct=0 --buf-sz=6 --buf-initial-sz=4 --buf-optimal-sz=5 --drop-frame=0 --resize-allowed=0 --kf-min-dist=0 --kf-max-dist=250 --auto-alt-ref=0 --noise-sensitivity=0 --sharpness=0 --static-thresh=0 --tile-columns=2 --tile-rows=1 --threads=16 --width=640 --height=352 -o "H:\Temp\test_16_23_09_2810_01.vp9" - Cu Selur Last edited by Selur; 10th December 2013 at 16:18. |
10th December 2013, 00:06 | #384 | Link |
Firefox apparently now supports VP9 playback in its development branches:
http://www.phoronix.com/scan.php?pag...tem&px=MTUzODA |
10th December 2013, 18:16 | #385 | Link |
attached my broken vpxenc versions I build with media-autobuild_suite to a post over at videohelp
Cu Selur |
10th December 2013, 19:35 | #386 | Link |
LoadCPlugin("G:\avsiynth\avisynthPlugins\ffms2.dll") # loading source FFVideoSource("H:\TESTCL~1\test.avi",cachefile="H:\Output\21437943319_16_52_0110.ffindex",fpsnum=25000,fpsden=1000) Code:
avs2yuv "H:\Output\encodingTempAvisynthSkript_19_16_52_0110.avs" - | vpxenc --codec=vp9 --passes=2 --pass=1 --target-bitrate=1500 --end-usage=vbr --fpf="H:\Output\test_19_16_52_0110_03.stats" --profile=0 --good --cpu-used=3 --bias-pct=70 --minsection-pct=15 --maxsection-pct=10000 --min-q=0 --max-q=63 --lag-in-frames=25 --undershoot-pct=0 --buf-sz=6 --buf-initial-sz=4 --buf-optimal-sz=5 --drop-frame=0 --resize-allowed=0 --kf-min-dist=0 --kf-max-dist=250 --auto-alt-ref=0 --noise-sensitivity=0 --sharpness=0 --static-thresh=0 --tile-columns=2 --tile-rows=1 --threads=16 --width=640 --height=352 -o NUL - avs2yuv "H:\Output\encodingTempAvisynthSkript_19_16_52_0110.avs" - | vpxenc --codec=vp9 --good --cpu-used=2 --psnr --threads=0 --profile=0 --lag-in-frames=25 --min-q=0 --max-q=63 --cq-level=20 --end-usage=0 --auto-alt-ref=1 --passes=2 --pass=2 --fpf=file.fpf --kf-max-dist=9999 --kf-min-dist=0 --drop-frame=0 --static-thresh=0 --bias-pct=50 --aq-mode=2 --minsection-pct=0 --maxsection-pct=2000 --arnr-maxframes=7 --arnr-strength=5 --arnr-type=3 --sharpness=0 --undershoot-pct=100 --psnr --target-bitrate=275 --width=640 --height=352 - -o "h:\Output\try1.webm" Code:
avs2yuv -raw "H:\Output\encodingTempAvisynthSkript_19_16_52_0110.avs" - | vpxenc --codec=vp9 --passes=2 --pass=1 --target-bitrate=1500 --end-usage=vbr --fpf="H:\Output\test_19_16_52_0110_03.stats" --profile=0 --good --cpu-used=3 --bias-pct=70 --minsection-pct=15 --maxsection-pct=10000 --min-q=0 --max-q=63 --lag-in-frames=25 --undershoot-pct=0 --buf-sz=6 --buf-initial-sz=4 --buf-optimal-sz=5 --drop-frame=0 --resize-allowed=0 --kf-min-dist=0 --kf-max-dist=250 --auto-alt-ref=0 --noise-sensitivity=0 --sharpness=0 --static-thresh=0 --tile-columns=2 --tile-rows=1 --threads=16 --width=640 --height=352 -o NUL - avs2yuv -raw "H:\Output\encodingTempAvisynthSkript_19_16_52_0110.avs" - | vpxenc --codec=vp9 --good --cpu-used=2 --psnr --threads=0 --profile=0 --lag-in-frames=25 --min-q=0 --max-q=63 --cq-level=20 --end-usage=0 --auto-alt-ref=1 --passes=2 --pass=2 --fpf=file.fpf --kf-max-dist=9999 --kf-min-dist=0 --drop-frame=0 --static-thresh=0 --bias-pct=50 --aq-mode=2 --minsection-pct=0 --maxsection-pct=2000 --arnr-maxframes=7 --arnr-strength=5 --arnr-type=3 --sharpness=0 --undershoot-pct=100 --psnr --target-bitrate=275 --width=640 --height=352 - -o "h:\Output\try1.webm" -> seems like vpxenc now only supports y4m input, despite the fact that the help only states: Code:
--yv12 Input file is YV12 --i420 Input file is I420 (default) (didn't consider testing y4m since the help doesn't mention it) btw. ffmpeg as decoder works fine too as long as yuv4mpegpipe is used. (using raw i420 or yv12 produces the above problems.) -> filed a bug report: http://code.google.com/p/webm/issues/detail?id=678 Last edited by Selur; 10th December 2013 at 20:38. |
10th December 2013, 22:08 | #387 | Link | |
using:
ffmpeg -v -10 -i "H:\TestClips&Co\test.avi" -an -sn -threads 8 -vsync 0 -r 25 -pix_fmt yuv420p -f yuv4mpegpipe - | vpxenc --codec=vp9 --lossless=1 --end-usage=q --min-q=0 --max-q=0 --width=640 --height=352 -o "H:\Output\test.webm" - Cu Selur |
10th December 2013, 23:56 | #388 | Link |
I got valid 2-pass encoding but also lossless with this command line and your "broken" 32-bit vpxenc from your videohelp post :
ffmpeg -i input.avi -an -pix_fmt yuv420p -f yuv4mpegpipe - | vpxenc --codec=vp9 --passes=1 --pass=1 --fpf="test.stats" --lossless=1 --min-q=0 --max-q=0 --end-usage=q --width=224 --height=384 - -o test.webm |
11th December 2013, 00:07 | #389 | Link |
Compiled a new version (v1.3.0-290-ge18eb77) which works fine with 2pass here.
Seems like the missing '--passes=1 --pass=1' was the problem. (I even got dvd->vpxenc working by doing a double-pipe: mencoder ... | ffmpeg ... | vpxenc ... ) |
14th January 2014, 05:46 | #393 | Link |
Two semi-recent papers on VP9 efficiency.
VP9 intra performance vs HM/JM/VP8. TLDR: VP9 needs 20% less bitrate than VP8. HEVC needs 30% less than JM, 15% less than VP9. Authors suggest 2/3 of HEVC's gains over VP9 due to having more prediction angles + SAO, the rest due to slightly better entropy coding. VP9 vs HM vs x264 in playback/random-access config. TLDR: The paper found that VP9 needs 80% more bitrate than HEVC, 8% more than x264. Unfortunately, VP9 was ran with min-q=max-q=$QP. If that's what that sounds like, their results for VP9 are almost certainly invalid. For both papers, I wouldn't expect VP9's results to change more than 1-2% with a recent build. I recall almost all quality commits being for the higher speed presets. VP9 also now has adaptive quant. Aq-mode 1 seems to improve MS-SSIM bdrate by several percent on a couple 1080p clips I've tried. I'm not particularly sure what aq-mode 2 does, and on testing with crowdrun seq, both subjective viewing and MS-SSIM bdrate showed worse performance compared to aq1. It'd be nice to do a subjective comparison against x265+AQ, but VP9's wildly off its 2pass target bitrates when AQ is on. That along with how encoding is single-threaded and how cpu-used=0 is roughly as fast as the HM mean I'm not too keen on trial-and-error encodes. Last edited by xooyoozoo; 14th January 2014 at 05:50. |
27th January 2014, 18:14 | #395 | Link |
Quote from the mailing list (in the context of encoding):
"Right now VP9 is a lot slower than VP8. We are working hard to correct that. Watch for big speed increases in the couple of months." Obviously easier said than done, but thought I'd note it anyway. |
3rd February 2014, 13:04 | #397 | Link | |
VBR: vpxenc --good --end-usage=vbr --target-bitrate=X --cq-level=0 --aq-mode=1 --cpu-used=0 --threads=0 --profile=0 --lag-in-frames=25 --min-q=0 --max-q=63 --auto-alt-ref=1 --passes=2 --kf-max-dist=9999 --kf-min-dist=0 --drop-frame=0 --static-thresh=0 --bias-pct=50 --minsection-pct=0 --maxsection-pct=2000 --arnr-maxframes=15 --arnr-strength=6 --arnr-type=3 --sharpness=0 --codec=vp9 I noted in VBR that it's best to set the cq-level to 0, else the encoder will be eager to try to save a lot bits in flat areas leading to macro-blocks, of course you may want this and if so increase the cq-level value accordingly. CQ: vpxenc --good --end-usage=3 --cq-level=X --aq-mode=1 --cpu-used=0 --threads=0 --profile=0 --lag-in-frames=25 --min-q=0 --max-q=63 --auto-alt-ref=1 --passes=2 --kf-max-dist=9999 --kf-min-dist=0 --drop-frame=0 --static-thresh=0 --bias-pct=50 --minsection-pct=0 --maxsection-pct=2000 --arnr-maxframes=15 --arnr-strength=6 --arnr-type=3 --sharpness=0 --codec=vp9 The only change in the CQ encode is the -end-usage parameter, you could also experiment with aq-mode=2 which I haven't yet examined. Also I'm using --good here, for the best quality you should use --best but it is REALLY slow so unless you have a lot of time or are doing a comparison between encoders I would use --good It's been a bunch of weeks since I last did some tests so I hope these settings are still valid. |
3rd February 2014, 21:35 | #398 | Link |
Some months ago, VP9 defaults in libvpx were changed to match the high-quality suggestions. In the same commit, the developers also recommended against using --best over --good.
IIRC, the only thing you'd need to worry about now is cpu-used, end-usage, aq-mode, kf-max-dist. |
25th February 2014, 19:34 | #399 | Link |
Posts: n/a
MulticoreWare accelerates VP9
MulticoreWare, the company behind the x265 project, is working with Google and semiconductor companies to accelerate VP9.
http://www.prweb.com/releases/2014/02/prweb11612574.htm |
26th February 2014, 18:02 | #400 | Link |
There was also a similar project from ittiam for the ARM MALI GPU.
http://malideveloper.arm.com/demo-sh...-using-opencl/ Both seem to have involved collaboration with Google and the use of OpenCL, but I don't know if that means we should expect other chips to have similar solutions. Also, ffmpeg's VP9 decoder had a blog post from one of the authors, which has some stuff about decoder speed, decoder threading and encoder quality: http://blogs.gnome.org/rbultje/2014/...decoder-ffvp9/ Last edited by dapperdan; 26th February 2014 at 18:02. Reason: linkify urls |
google, ngov, vp8, vp9, vpx, webm |
