17th September 2009, 10:27 | #9341 | Link |
HDConvertToX author
same here...
just installed haali, ffdshow tryouts, xvid.. and used clsid reg tools for windows 7 BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
20th September 2009, 22:39 | #9342 | Link |
hi,
just been converting an HD-DVD I own (Elizabeth: The Golden Age) and I came across the following issue. Here's the log of eac3to's operation: Code:
eac3to v3.16 command line: eac3to.exe L: 1) 2: chapters.txt 3: video.mkv 4: audio.dts 8: subs08.sup ------------------------------------------------------------------------------ EVO, 1 video track, 4 audio tracks, 3 subtitle tracks, 1:54:50 1: Joined EVO file 2: Chapters, 20 chapters with names 3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 4: TrueHD, English, 5.1 channels, 48khz, dialnorm: -27dB 5: E-AC3, English, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB, -8ms 6: E-AC3, French, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB, -8ms 7: E-AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -8ms "Director Commentary" 8: Subtitle (DVD), English, "SDH" 9: Subtitle (DVD), French 10: Subtitle (DVD), French, "Forced" Creating file "chapters.txt"... [v03] Extracting video track number 3... [a04] Extracting audio track number 4... [v03] Writing new framerate "24fps /1.001" to bitstream. [a04] Removing TrueHD dialog normalization... [v03] Removing VC-1 pulldown... [a04] Decoding with libav/ffmpeg... [a04] Writing WAVs... [v03] Muxing video to Matroska... [a04] Creating file "audio.C.wav"... [a04] Creating file "audio.L.wav"... [a04] Creating file "audio.R.wav"... [a04] Creating file "audio.SL.wav"... [a04] Creating file "audio.LFE.wav"... [a04] Creating file "audio.SR.wav"... [s08] Extracting subtitle track number 8... [s08] Creating file "subs08.sup"... [a04] Original audio track, L+R+C+LFE: constant bit depth of 16 bits. [a04] Original audio track, SL+SR: constant bit depth of 24 bits. [a04] Audio has a gap of 10ms at playtime 0:00:00. <WARNING> [a04] Starting 2nd pass... [a04] Extracting audio track number 4... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Writing WAVs... [a04] Realizing RAW/PCM gaps... [a04] Creating file "audio.L.wav"... [a04] Creating file "audio.SL.wav"... [a04] Creating file "audio.C.wav"... [a04] Creating file "audio.R.wav"... [a04] Creating file "audio.SR.wav"... [a04] Creating file "audio.LFE.wav"... [a04] Processed audio track, L+R+C+LFE: constant bit depth of 16 bits. [a04] Processed audio track, SL+SR: constant bit depth of 24 bits. Encoding DTS <1536kbps> with Surcode... Found Surcode DTS Encoder version 1.0.29.0. Surcode encoding successfully started. Please wait... Closing Surcode... Added fps value to MKV header. Video track 3 contains 165207 frames. Subtitle track 8 contains 1093 captions. eac3to processing took 43 minutes, 37 seconds. Surcode encoding took 14 minutes, 35 seconds. Done. Code:
eac3to audio.dts audio.wavs eac3to audio2.ac3 audio2.wavs I watched the original disc on my HD-DVD HD-A30 player and there was no noticeable sync issue with the TrueHD track. The 89ms sync issue was noticeable when watching the video muxed with this derived .dts audio on my PC. (Again, the same video muxed with .ac3 derived from the E-AC3 track was also in-sync on my PC) Can it be that eac3to hasn't read/observed some kind of delay (separate meta-data?) that should apply to the TrueHD track in this case? And would this delay/offset only turn up when extracting TrueHD from HD-DVD sources (vs BluRay TrueHD tracks)? (has the HD-DVD side of the code been abandoned anyway?!) Thanks in advance of any help or feedback. ps - probably an easier question - what does (DVD) signify in the subtitle track listings? Obviously, these extract as HD subs in a .sup file (albeit presumably an HD-DVD specific .sup variant) Last edited by magic144; 20th September 2009 at 22:43. |
22nd September 2009, 13:56 | #9343 | Link |
just tried another HD-DVD disc
"Pride & Prejudice" - this also has both TrueHD and EAC-3 English audio alternatives. Extracted both audio tracks directly to .wavs using eac3to 3.16 (latest). Here is the log. Code:
eac3to v3.16 command line: eac3to L: 1) 4: audio_thd.wavs 5: audio_eac3.wavs ------------------------------------------------------------------------------ EVO, 1 video track, 4 audio tracks, 3 subtitle tracks, 2:08:18 1: Joined EVO file 2: Chapters, 16 chapters with names 3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags 4: TrueHD, English, 5.1 channels, 48khz, dialnorm: -27dB 5: E-AC3, English, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -8ms 6: E-AC3, French, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, -8ms 7: E-AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, -8ms "Director Commentary" 8: Subtitle (DVD), English, "SDH" 9: Subtitle (DVD), French 10: Subtitle (DVD), French, "Forced" [a05] The Nero decoder doesn't seem to work, will use libav instead. [a04] Extracting audio track number 4... [a05] Extracting audio track number 5... [a04] Removing TrueHD dialog normalization... [a05] Removing E-AC3 dialog normalization... [a04] Decoding with libav/ffmpeg... [a05] Decoding with libav/ffmpeg... [a04] Writing WAVs... [a05] Remapping channels... [a05] Applying RAW/PCM delay... [a05] Reducing depth from 64 to 24 bits... [a05] Writing WAVs... [a04] Creating file "audio_thd.L.wav"... [a04] Creating file "audio_thd.R.wav"... [a04] Creating file "audio_thd.SR.wav"... [a04] Creating file "audio_thd.C.wav"... [a04] Creating file "audio_thd.LFE.wav"... [a04] Creating file "audio_thd.SL.wav"... [a05] Creating file "audio_eac3.L.wav"... [a05] Creating file "audio_eac3.LFE.wav"... [a05] Creating file "audio_eac3.SR.wav"... [a05] Creating file "audio_eac3.C.wav"... [a05] Creating file "audio_eac3.SL.wav"... [a05] Creating file "audio_eac3.R.wav"... [a04] Original audio track, L+R+C+LFE: constant bit depth of 16 bits. [a04] Original audio track, SL+SR: constant bit depth of 24 bits. Video track 3 contains 184586 frames. eac3to processing took 22 minutes, 25 seconds. Done. As a complementary test, last night I compared the centre-channel of the separate THD and AC3 tracks from my BluRay version of 2010 (the THD track actually has AC3 embedded, but I used eac3to to only extract the THD for comparison with a separate AC3 track). In this case, there was no measurable time lag between the two. Unfortunately (or fortunately?) I don't have any more HDDVD discs with THD audio, however I will dig out a few more BluRay discs for comparison over the coming days/weeks and report any significant discrepancies if I find any. Perhaps others could repeat my experiment with their own HDDVD THD/EAC3 discs and report their findings. Last edited by magic144; 22nd September 2009 at 14:02. |
23rd September 2009, 06:31 | #9344 | Link |
FYI, just compared the distinct TrueHD and AC3 Japanese audio tracks from my Letters from Iwo Jima BluRay - another small measureable difference of -9ms (THD actually is AHEAD of the AC3 in this case), this would be very hard to detect perceptually - nothing like the 89ms from eac3to's audio extractions from the Elizabeth HDDVD.
Maybe the "Audio has a gap of 10ms at playtime 0:00:00. <WARNING>" message in the Elizabeth HDDVD THD track extraction log is a clue to the discrepency. Last edited by magic144; 23rd September 2009 at 06:34. |
24th September 2009, 14:10 | #9345 | Link | |
Help me extract to E-ac-3 to Wav???
27th September 2009, 03:47 | #9347 | Link |
I notice that in some movies, like Kill Bill 1&2, forced subtitles are not detected. There is one big English subtitle track with all subs, and another much smaller track with just the forced subs, but eac3to does not detect it as forced (nor does any other tool like BDSupToSub). Yet standalone Blu-Ray players somehow figure this out... how?
28th September 2009, 05:36 | #9348 | Link |
Hey guys; I've searched the thread and addressed all the concerns regarding this issue that have been posted already with no luck.
OS: Win7 x64 (I had this working fine with Vixta x64 with the same installs) E:\Encoding\video\eac3to>eac3to.exe -test eac3to (v3.16) is up to date Nero Audio Decoder (Nero 6 or older) doesn't seem to be installed http://www.nero.com/eng/store-blu-ray.html CAUTION: You need Nero 7. Nero 8 won't work with eac3to. Nero 7.8.5.0 installed, including showtime, and the BluRay/HDDVD plugin is successfully "unlocked". The codecs are showing up correctly, but eac3to doesn't seem to like 'em. Like I said, I have the same config installed in Vista x64 and it works fine. Has anyone else had probs with Win7?
I encode with a commodore Vic 20. |
28th September 2009, 15:08 | #9350 | Link |
I found a solution to the Windows 7 problem!
For some reason the file... C:\Program Files\Common Files\Ahead\DSFilter\NeAudio2.ax didn't get installed with Nero on my Windows 7 machine. This is Nero's DirectShow audio filter module. I copied that file over from my XP machine, then registered that module as a service with Windows by opening a command prompt in that folder and using the command... regsvr32 neaudio2.ax Now when I run eac3to -test it says that Nero Audio Decoder is working fine. |
28th September 2009, 15:10 | #9351 | Link |
eac3to will decode DD+ without Nero 7. Nero 7 was only really needed for DD+ because it a certified DD+ decoder.
Madshi has indicated many times he can't hear the different between Nero doing the DD+ decoding and the default eac3to library. So the question becomes how important is it to have DD+ certified decoding of a lossy stream or can you survive with the default eac3to decoding which gives you pretty much the same results? How many HD-DVDs do you have to rip, because DD+ only existing on HD-DVDs and maybe a couple Blu-Rays? |
29th September 2009, 06:37 | #9352 | Link | ||
2. I installed this bloatware (Nero + Arcsoft) on my new Win7 install, I want to use it damnit.
29th September 2009, 10:00 | #9353 | Link |
Im wondering that i cant see the "removing Dialog Normalization" Message anymore when decoding A(E)C3,TrueHD ?
I think because the DialNom removal is a standard Operation and latest eac3to wont output that Message everytime? |
30th September 2009, 07:57 | #9354 | Link |
@ACrowley
I saw this message for both HDDVD and BluRay audio streams just this week using eac3to 3.16 (HD-DVD was E-AC3 extracting to .ac3, BluRay was TrueHD/AC3 extracting to .ac3, both sources reported as having dialnorm: -27dB) What is your source/command-line/output? |
30th September 2009, 10:49 | #9355 | Link | |
something like: eac3to input.truhd output.wavs Decoder is libavcodec for Dolby. I dont get this DialNorm removal Message anymore for TrueHD and AC3 |
30th September 2009, 14:34 | #9356 | Link |
I assume if your input file (.thd or .ac3) was previously extracted from a disc source, the DialNorm removal will have been done then (and only then) - unless perhaps you initially used keepDialnorm (I've never tried).
I still see it when I do something like this (track 2 being an AC3 stream in the source):- eac3to L: 1) 2: audio.ac3 Last edited by magic144; 30th September 2009 at 15:09. |
1st October 2009, 02:06 | #9358 | Link | |
SSRC(50050).AssumeSampleRate(48000) Maybe the SSRC routines used in Eac3to are more recent than SSRC routines in AviSynth. And is equivalent to TimeStretch(rate=98.0/1.001), the duration and the pitch change. Eac3to can't do the others TimeStretch modes: TimeStretch(tempo=98.0/1.001), change duration and preserve the pitch TimeStretch(pitch=98.0/1.001), change pitch and preserve duration
2nd October 2009, 10:05 | #9359 | Link | |
eac3to |
