Old 23rd March 2019, 20:40   #1561  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
Originally Posted by Pushman View Post
https://github.com/Nevcairiel/LAVFilters/releases/tag/0.74
Note, there's a newer 0.74.1 version of LAVFilters in case anybody is thinking that above link is the newest version (which it's not):
____HTPC____  | __Desktop PC__
2.93GHz Xeon x3470 (4c/8t Nehalem) | 4.5GHz 1.24v dual-core Haswell G3258
Radeon HD5870  | Intel iGPU
2x2GB+2x1GB DDR3-1333 | 4x4GB DDR3-1600
Nintendo Maniac 64 is offline   Reply With Quote
Old 23rd March 2019, 22:58   #1562  |  Link
mzso
Hi!
Is there anything out there that can encode valid AVIF images?
Does (dev versions of) Chrome/Firefox support viewing AVIF images? (Anything else?)
Old 24th March 2019, 00:22   #1563  |  Link
nevcairiel
Originally Posted by mzso View Post
Hi!
You can encode with this tool, for example:
https://github.com/Kagami/go-avif (binary: https://ci.appveyor.com/project/Kaga...uild/artifacts)
They also have a avif.js demo that can decode it using JavaScript (https://kagami.github.io/avif.js/). I don't think any browsers have native support yet, since the spec for AVIF was only officially signe-off a week ago or so.
Interestingly, the upcoming Windows 10 "19H1" seems to have native support, both in Explorer for thumbnails, as well as in Paint for importing - assuming the AV1 Video Extension is installed.
Old 24th March 2019, 00:44   #1564  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
AVIF is basically AV1 codec in HEIF container, so you can also use ffmpeg with libaom enabled (or ffmpeg + aomenc) to encode the pictures into ivf and then use MP4Box -add-image to convert the ivf files into avif.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 24th March 2019, 01:36   #1565  |  Link
nevcairiel
To be fair, any AVIF file is a HEIF file, but if your tool doesn't know what its doing, then a HEIF file with AV1 in it may not be valid AVIF (since it defines some constraints to make it easier on readers that only want to support AVIF and not the full HEIF spec).
That said, MP4Box actually supports AVIF however, but you should be passing "-brand avif" to make sure it makes a proper one.
Compatible software and some invocation commands are listed here:
https://github.com/AOMediaCodec/av1-avif/wiki
Old 24th March 2019, 01:44   #1566  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Thanks for the link, SmilingWolf's script also adds -ab miaf, I guess that is optional?
Monochrome Anomaly
Old 24th March 2019, 02:30   #1567  |  Link
nevcairiel
Yeah, sort of optional. The spec says it should be there, but its not clear to me if you need to use one of its profiles. You can have a whole list of alternate/compatible brands in such a file. The AVIF spec lists them:
https://aomediacodec.github.io/av1-a...es-constraints
"avif" from the AVIF spec itself.
"mif1" from HEIF
"miaf" from the MIAF spec
and finally "MA1B" or "MA1A" to identify the AV1 profile in use.
Or various alterations of the above for special types of images.
... this ISOBMFF image format stuff is a real mess.
Old 6th April 2019, 07:59   #1568  |  Link
NikosD
I did a small comparison between lib-aom and lib-dav1d earlier this week.
I used LAV Video 0.73.1-31 x64 for lib-aom and LAV Video 0.74.1-1 for lib-dav1d (no idea if LAV uses the latest versions of both libraries, but should be close to latest)
The two systems mentioned below have Win 10 October Update and I used DXVA Checker v4.20 for both of them.
The AV1 sample is Chimera - AV1 - 1080p - 8bit - 6.7Mbps file.
Skylake system:
Core i5 6500 (4C/4T) at 3.2GHz (All core turbo 3.3GHz) using 1x8GB DIMM of DDR4-2133 MHz RAM (Single channel)
Haswell system:
Core i3 4170 (2C/4T) at 3.7GHz (No Turbo) using 2x8GB DIMMs of DDR3-1600 MHz RAM (Dual channel)
Benchmark results:
(min/avg/max fps)
Skylake Core i5 6500:
libaom 30/48/149 CPU usage 65%
dav1d 77/128/282 CPU usage 91%
Haswell Core i3 4170:
libaom 21/37/153 CPU usage 71%
dav1d 53/91/240 CPU usage 90%
Comments:
For both AVX2 capable CPUs, the speedup is similar ~2.5 times faster for dAV1d than libaom (2.46 for Haswell and 2.67 for Skylake) and the CPU usage also goes to ~90% for both.
The difference is huge for multi-threaded systems.
Core i5 6500 manages to be faster from 30% (using libaom) to 41% (using dav1d) than Core i3 4170.
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 6th April 2019, 09:23   #1569  |  Link
dapperdan
MSU HEVC/AV1/VP9 encoding test results:
http://compression.ru/video/codec_comparison/hevc_2018/
dapperdan is offline   Reply With Quote
Old 9th April 2019, 01:11   #1570  |  Link
soresu
Did anyone see the SVT-AV1 announcement from Intel/Netflix.
Link here.
Still havent seen a comprehensive comparison of it compared to libaom, x265 and vp9 quality wise.
soresu is offline   Reply With Quote
Old 9th April 2019, 03:38   #1571  |  Link
tnti
AV1 encoder's speed and compression rate reach the practical level of VOD
https://mp.weixin.qq.com/s?__biz=MzU...Dp&wx_header=1
关于对比rav1e和SVT-AV1,以下为来自Zoe Liu的回复:
“rav1e和SVT-AV1在github上的开源编码器,迄今为止还没有完成AV1标准中的最主要的编码工具集。对于任意一款AV1编码器,如果没有实现AV1标准的主要工具,只是在码流格式上符合AV1标准规范,而无法体现AV1的标准优势,其实还没有达到作为AV1编码器的基准要求。
我们对最新的SVT-AV1 github版本做了相对粗略的RD性能测试,其目前的编码效率还停留在AV1的前身VP9的大致水平。对这样开发阶段的编码器,放到AV1类别里面做编码性能与速度评估,不仅没有意义,对这样的开源项目也是不公平的。”
The following is the content of machine translation:
Regarding the comparison between rav1e and SVT-AV1, the following is a response from Zoe Liu:
"Rav1e and SVT-AV1 open source coders on GitHub have not yet completed the most important coding tool set in AV1 standard. For any AV1 encoder, if there is no main tool to implement the AV1 standard, it only conforms to the AV1 standard in bit stream format, but can not reflect the standard advantages of AV1. In fact, it has not reached the standard requirements as AV1 encoder.
We have done a relatively rough RD performance test for the latest version of SVT-AV1 github, and its coding efficiency is still at the approximate level of VP9, the predecessor of AV1. It is not only meaningless to evaluate the coding performance and speed of the coder in the AV1 category, but also unfair to such open source projects.
tnti is offline   Reply With Quote
Old 9th April 2019, 12:21   #1572  |  Link
hajj_3
Intel to make their own AV1 software decoder:
https://www.phoronix.com/scan.php?pa...-Decode-FFmpeg
https://trello.com/c/oEZQai7L/26-av1-decoder
Old 9th April 2019, 13:19   #1573  |  Link
utack
Originally Posted by hajj_3 View Post
Seems like they were not happy dav1d runs well on Ryzen
utack is offline   Reply With Quote
Old 9th April 2019, 14:00   #1574  |  Link
hajj_3
Hopefully the dav1d decoder will copy any improvements that intel makes in their decoder. I have an intel kaby lake chip so i'm not complaining about intel making a new software decoder :P
Old 9th April 2019, 15:45   #1575  |  Link
nevcairiel
Well dav1d certainly won't get slower through any of their efforts.
That said, dav1d puts a lot of effort into AVX2, which current-gen Ryzen doesn't even do particularly fast, so..
Additionally, that Trello "av1 decoder" task existed before dav1d was even a thing, and contrary to the Phoronix article, dav1d is actually quite decently fast on 8-bit content (work on speeding up 10-bit has started).
BUT, one should know that an encoder basically contains a decoder already, because it has to practically decode encoded frames to get accurate reference frame information, so splitting that out may always be an option.
Old 9th April 2019, 16:13   #1576  |  Link
mandarinka
mandarinka's Avatar
Dav1d will be always better for us end users, I think that's almost certain. SVT encoders are kind enterprise code which likely won't be too receptive about various issues of users in the wild, who have weird needs like non-AVX2 CPUs, non-mod16/8/4 video (for example) and integration into various players which the coders of these server-side encoders for commercial use are not going to see as important or even be aware of.
Dav1d devs are going to be more in touch with this and generally, the ffmpeg circle sort of development has proved itself with decoders.
mandarinka is offline   Reply With Quote
Old 10th April 2019, 00:43   #1577  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
"mif1" from HEIF
As I read it, "miaf" is required for AVIF, and defines a fair number of important constraints. I wish it was possible to view MIAF's draft standard, but if you aren't in MPEG, ISO, or IEC it looks like that's not possible at all for at least another month.
Old 10th April 2019, 17:56   #1578  |  Link
Nintendo Maniac 64
Though Intel does seem to like segmenting their CPU lineup with regards to AVX feature-set.
Old 11th April 2019, 07:47   #1579  |  Link
NikosD
Even the current Ryzen architecture is very fast using dAV1d probably due to the highly multi-threaded nature of both (dAV1d and Ryzen)
The multi-threaded gain seems to be more significant than the AVX2 loss for current-gen Ryzen.
Old 14th April 2019, 17:02   #1580  |  Link
soresu
Seems that rav1e is prioritising chunked/segment encoding early on to maximise parallelism, they just opened a new project list to target specific tasks. Link here.
