27th January 2013, 12:10 | #123 | Link | |
PgcEdit daemon
27th January 2013, 12:18 | #124 | Link | |
27th January 2013, 12:41 | #125 | Link |
PgcEdit daemon
OK, I will try. Thanks again.
27th January 2013, 18:17 | #126 | Link |
Posts: n/a
Hmmm... Okay, let me check my settings for compile. Make sure things weren't set at minimum 10.8.
Edit: I think I know the prob. I have the latest Mac Mini which means it compiled with support for all SIMD stuff through AVX which is more likely the issue. I guess I'll limit my Qt to only SSE3 which should work for a minimum Core2Duo. Last edited by paradoxical; 27th January 2013 at 19:05. |
27th January 2013, 20:54 | #128 | Link |
Hi Sassbot, hi @all.
I'm trying to compile BDSup2Sub++ in Linux Mint KDE 13. I have all build packages installed, and also installed libqxt 0.6.1 (this is the version in repositories). I downloaded source from https://github.com/amichaelt/BDSup2SubPlusPlus When I qmake in terminal I get this error: Code:
WARNING: /usr/share/qt4/mkspecs/features/qxt.prf:7: Variable QMAKE_RPATH is deprecated; use QMAKE_LFLAGS_RPATH instead. What am I doing wrong?, wrong tools version?. Do you need further information to help me compiling?. |
27th January 2013, 21:07 | #129 | Link |
Posts: n/a
That's not really an error. But, sure if you can post the line you're using to compile and the part where the errors start I can try to help you. Also the version of your compiler is needed too. You need to make sure to be using either Clang 4.x or GCC 4.7.x or higher.
Edit to add: Your version of Qt also needs to be compiled with C++11 support since this code uses initializer lists for Qt containers. Last edited by paradoxical; 27th January 2013 at 21:20. |
27th January 2013, 21:34 | #130 | Link |
Thank you paradoxical.
Probably I decided to try a task too big for me. I don't almost compile anything by myself. I install programs and tools from repositories. Please tell me how can I check my Clang and GCC versions. In terminal Clang -h tells me that Clang is not installed (probably that's a problem to begin with). And gcc -h throws an error about missing files (this might not be the way to check gcc version ) My compiling code in terminal is just qmake BDSup2Sub++.pro, and after the warning message make. I also did not compile Qt myself, it is as it was in the repositories, don't know if it was compiled with C++11 support. Also don't know how to check it... Do you think I will manage to compile it in my system?. I looked for a Linux (Debian) binary with no success... |
27th January 2013, 21:37 | #131 | Link |
Posts: n/a
To find your version type "g++ --version". If you didn't compile Qt yourself it probably isn't compiled with C++11 support. I guess I'll change the pro file so it verifies you have C++11 support and then just errors out so compiling never happens.
27th January 2013, 22:34 | #132 | Link |
Aaarrrggghhhh,
GCC version 4.6.6 I'm afraid I won't be able to compile BDSup2Sub++ on my system. And I don't have the time/skill to build in a virtual machine a Linux version just for compiling purposes. Is it possible anybody compiled it and can provide binaries for Linux 64bit?. |
28th January 2013, 02:10 | #135 | Link |
I suppose it's not possible to make compilation compatible with other configuration, specifically with previous GCC versions, no C++11 compatibility and so, isn't it?
I don't know if common 'buntu users will have this specifications here in Linux world. |
28th January 2013, 03:58 | #136 | Link | |
Posts: n/a
GCC 4.7.2 is the default g++ in Ubuntu 12.10. So it will get more common. There are also ppas for GCC 4.7.x for both Lucid and Precise here: https://launchpad.net/~ubuntu-toolchain-r/+archive/test so the toolchain can be pulled down. I don't really run Linux outside of doing some Valgrind testing on it in a VM, so I'm not really all that interested in doing ppas for Ubuntu myself. Windows and OS X are my main systems. Like I said, I suggest you ask someone who runs your repos if they can make a package for you. Last edited by paradoxical; 28th January 2013 at 04:02. |
28th January 2013, 15:54 | #137 | Link |
Posts: n/a
So I'm refreshing the builds bumping the version number to 1.0.1 since I believe all my changes warrant so and I've created a tag to match the current builds. Selur *link removed* the OS X binary. Posting the new Windows binary with bumped version number shortly.
Edited to add: Here is the new Windows binary. Edited to add again: I'm going to fix the OS X binary I posted. The Qt it is statically linked with apparently was using my system's libjpeg instead of the built-in Qt libjpeg. If anyone already downloaded the previous binary and wants to use it, you will need to know you need to install libjpeg.8.dylib into /opt/local/lib/. Otherwise, just wait until I fix it in about 4 hours. Last edited by paradoxical; 28th January 2013 at 21:46. |
