Old 18th December 2018, 20:19   #4341  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Thank you very much indeed for the Christmas present!
FranceBB is offline
Old 18th December 2018, 20:24   #4342  |  Link
magiblot
Eurobeat Fan
Originally Posted by pinterf View Post
# Avisynth+ r2768 (20181218)
https://forum.doom9.org/showthread.php?t=168856
- New: Expr: allow input clips to have more planes than an implicitely specified output format
  Expr(aYV12Clip, "x 255.0 /", format="Y32") # target is Y only which needs only Y plane from YV12 -> no error
- New: Expr: Y-plane-only clip(s) can be used as source planes when a non-subsampled (rgb or 444) output format implicitely specified
  Expr(Y, "x", "x 2.0 /", "x 3.0 /", format="RGBPS") # r, g and b expression uses Y plane
  Expr(Grey_r, Grey_g, Grey_b, "x", "y 2.0 /", "z 3.0 /", format="RGBPS") # r, g and b expression uses Y plane
- Fix: ConvertToYUY2() error message for non-8 bit sources.
- Fix: Y32 source to 32 bit 420,422,444 (introduced in the zero-chroma-center transition project)
- Speedup: ConvertToY12/16... for RGB or YUY2 sources where 4:4:4 or YV16 intermediate clip was used internally
  (~1.5-2x speed, was a regression in Avs+, use intermediate cache again)
- ImageReader/ImageSource: use cache before FreezeFrame when result is a multiframe clip (fast again, regression since an early AVS+ version)
magiblot is offline
Old 18th December 2018, 21:02   #4343  |  Link
pinterf
Thank you for the precious (my precious - just have finished re-reading the lotr books) bug reports and the patience and the thanks giving.
pinterf is offline
Old 18th December 2018, 22:20   #4344  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Thanks for all the work you do!
wonkey_monkey is offline
Old 19th December 2018, 00:29   #4345  |  Link
+1 on that. Yes, thank you my perfectly precious Pinterf.
I just watched all three Hobbits
(standard versions only, not sure if there are extended versions,
I only got extended in LOTR, me loves the Faceless & Accursed one [always brings to mind TheFluff for some reason]).
StainlessS is offline
Old 19th December 2018, 02:44   #4346  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
And just like that, it started to snow.
The who's in whoville started to sing!
Thanks for the update!
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Sparktank is offline
Old 19th December 2018, 09:00   #4347  |  Link
LigH
LigH's Avatar
Are you a Whovian?
New German Gleitz board
LigH is offline
Old 19th December 2018, 09:24   #4348  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Originally Posted by LigH View Post
Are you a Whovian?
I LOVE Doctor Who!
Still need to catch up to current season and then check out the older series before the 2005 revamp.
Back on topic, loving all these updates.
It's even nicer seeing older plugins get updated for AVS+.
With all this, I can delay learning python language for VS a bit longer.
Old 20th December 2018, 14:37   #4349  |  Link
pinterf
New build, Expr fixes. I hope.
Download Avisynth+ r2772-MT
20181220 r2772
- Fix: Expr: possible Expr x64 crash under specific memory circumstances
- Fix: Expr: safer code for internal variables "Store and pop from stack" (see: Internal variables at http://avisynth.nl/index.php/Expr)
In the x64 stack frame generation, address calculation was truncated to 32 bits when AVX2 registers were to be saved. Caused C0000005 Access Violation.
The second fix is a precaution, (generating code for the A^ syntax for 'store and pop' operation of internal variables), did not caused any troubles yet, I fixed it anyway.
pinterf is offline
Old 23rd December 2018, 12:04   #4350  |  Link
Dogway
Does someone know if there's an alternative to SoundOut() for avs+ x64? It's a basic tool I use very oftenly (currently) to do edits/filtering to audio without having to create intermediary WAV files. I tried BatchEncoder and similar and they don't work fine.
Dogway is offline
Old 23rd December 2018, 12:36   #4351  |  Link
LigH
LigH's Avatar
IIRC, avs2pipemod has a switch to deliver the audio part instead of the video part of the AviSynth output, to feed audio encoders (e.g. QAAC) instead of video encoders.
Even several:
>avs2pipemod64.exe
avs2pipemod  ver 1.1.1
built on Aug 15 2016 00:32:12
Usage: avs2pipemod [option] input.avs
  e.g. avs2pipemod -wav=24bit input.avs > output.wav
       avs2pipemod -y4mt=10:11 input.avs | x264 - --demuxer y4m -o tff.mkv
       avs2pipemod -rawvideo -trim=1000,0 input.avs > output.yuv
   -wav[=8bit|16bit|24bit|32bit|float  default unset]
        output wav format audio(WAVEFORMATEX) to stdout.
        if optional arg is set, audio sample type of input will be converted
        to specified value.
   -extwav[=8bit|16bit|24bit|32bit|float  default unset]
        output wav extensible format audio(WAVEFORMATEXTENSIBLE) containing
        channel-mask to stdout.
        to specified value.
   -rawaudio[=8bit|16bit|24bit|32bit|float  default unset]
        output raw pcm audio(without any header) to stdout.
        to specified value.
LigH is offline
Old 23rd December 2018, 13:49   #4352  |  Link
tebasuna51
tebasuna51's Avatar
@Dogway
If you need some avs edits/filtering than can't be done with BatchEncoder or similar, and use avs+ 64 bits you can use avs2pipemod64 (like LigH say).
Also MeGUI (if you want a GUI instead command line) and ffmpeg (recommended to encode to AC3 directly) 64 bits can accept .avs inputs.
tebasuna51 is offline
Old 23rd December 2018, 14:21   #4353  |  Link
Dogway
Yes, I was already investigating that. I was getting CoreAudioToolBox errors for qaac so I had to do that crazy setup with the makeportable.cmd, now it complains about invalid input format so it must be a problem with my avs2pipemod64 line.
avs2pipemod[info]: writing 48915.400 seconds of 44100 Hz, 2 channel audio.
ERROR: Not available input file format
"%PIPER%" -rawaudio "%INPUT%"| "%ENCODER%" --tvbr %QUALITY% --ignorelength --no-optimize - -o "%OUTPUT%"
edit: worked if I added --raw and removed --ignorelength
"%PIPER%" -rawaudio "%INPUT%"| "%ENCODER%" --raw --tvbr %QUALITY% --no-optimize - -o "%OUTPUT%"
Dogway is offline
Old 23rd December 2018, 18:24   #4354  |  Link
wonkey_monkey
converttoy8 is broken when converting from bit depths other than 8:
version.convertbits(16).converttoy8
version.converttoyv12.convertbits(12).converttoy8
Old 23rd December 2018, 19:20   #4355  |  Link
pinterf
Thanks. Seems that it's not guarded by an error message to allow only 8 bit sources. Based on the upside down result, it simply runs on the 8 bit packed rgb case.
pinterf is offline
Old 23rd December 2018, 23:14   #4356  |  Link
wonkey_monkey
Me again...
colorbars returns a clip with alpha set to 255 with pixel_type="RGBAP8", but with pixel_type="RGB32", alpha is set to 0.
Old 24th December 2018, 00:57   #4357  |  Link
tebasuna51
tebasuna51's Avatar
@Dogway
Try:
"%PIPER%" -extwav=24bit "%INPUT%"| "%ENCODER%" --tvbr %QUALITY% --ignorelength --no-optimize -o "%OUTPUT%" -
All encoders need wav header to know samplerate, bit depth, number of channels and mask
Old 24th December 2018, 11:58   #4358  |  Link
nu774
qaac supports avisynth directly, so you don't have to pipe from avs2pipemod (use qaac64.exe for 64bit Avisynth+).
nu774 is offline
Old 25th December 2018, 11:27   #4359  |  Link
LigH
LigH's Avatar
It was just an example of an encoder that always worked, even before it supported AviSynth natively.
LigH is offline
Old 25th December 2018, 12:05   #4360  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by nu774 View Post
qaac supports avisynth directly...
Yep, seems it work ok.
But I can see nothing in qaac docs. Only a reference to Apple AudioFile services
