10th May 2017, 15:22 | #43682 | Link |
I'm using SVP as well, for 90% of my content. I can't imagine disabling FFSHOW RAW, unless SVP finds another way to work together with madvr
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card |
11th May 2017, 05:06 | #43687 | Link |
Just copy the latest Madvr to JRiver Media Center's madvr folder:
"C:\Users\%yourusername%\AppData\Roaming\J River\Media Center 21\Plugins\madvr" all settings are the same as those you set before as they were stored in regist |
11th May 2017, 05:35 | #43688 | Link |
Gtx 1080 x Gtx 1080 ti Aorus
Guys, I changed my GTX 1080 G1 for a GTX 1080 TI Aorus X ... I'm surprised! It is amazing the difference ... no noise and at maximum power the temperature is very low. The render times were down 30 or 40%. Now if Madvr I can use Madvr to maximum potential.
"To infinity, and beyond!" |
11th May 2017, 06:46 | #43689 | Link | |
Visual Novel Dev.
You;re one lucky fellow! I was actually curious how big is the difference between 1080 and 1080ti with madVR, seems that it is big enough to be worth the upgrade! Guess that I wish I had a PC instead of laptop now... Anyway, I hope you have lots of fun with your setup in there!
Visual Novels! https://www.facebook.com/seventh.heart.studios/ https://audiophile-heaven.blogspot.com/ https://www.youtube.com/watch?v=27VWU3ydRY8 |
11th May 2017, 06:56 | #43690 | Link | |
11th May 2017, 08:30 | #43691 | Link | |
K Edit - and until MS and Nvidia sort themselves out with who is going to own what in the render chain, I'll stick with 378.92, which, to me, has the best colour fidelity. Last edited by oldpainlesskodi; 11th May 2017 at 09:30. |
11th May 2017, 09:07 | #43693 | Link |
hey guys, I'm wondering if anyone by any chance is using smooth motion with a new Kaby Lake XPS 15 9560 (GTX 1050) with the 4K screen. Both 1080p upscaled, and native 4K? Right now I can only use smooth motion on my Kaby Lake Razer Blade Stealth if I change the resolution to 1080p first. It's not really a big problem since I don't have a lot of 4K content, but I'm curious anyway. The new XPS 15 seems almost perfect for my kind of usage.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
11th May 2017, 16:15 | #43695 | Link | |
Visual Novel Dev.
I went with a laptop that has a desktop CPU to have better workflow, didn't consider the problem imposed by GPU at that moment...
11th May 2017, 21:52 | #43697 | Link |
Well you actually do need a 1080 Ti or better for maximum madVR, maximum being the highest settings possible. You need a very powerful GPU to do 1080p -> 2160p with NGU veryHigh.
Whether or not using NGU veryHigh instead of high or medium is worth $400+ is debatable, of course, but "maximum madVR" does require a 1080 Ti or better. Actually, I still have to use profiles with lower settings for harder content and I have an overclocked and water cooled Titan X (Pascal). Even the current top end cards cannot run truly maximum madVR, though they get pretty close.
madVR options explained |
12th May 2017, 00:20 | #43700 | Link |
you have multiply buffer upload, the frame before and after chroma scaling and way way more and 8 bit is not really used by madVR.
it is 16 or more except for presenation. on top of it PC GPU don't use RGB they use RGBA make it 33% bigger with no gain. or in short get at least 3 GB Vram for madVR when using a UHD screen. and i personally wouldn't get a card with less than 4GB. |
