29th March 2004, 20:24 | #441 | Link | |
Retired
Can you post the contents of the ECL file you are having problems with? |
29th March 2004, 20:32 | #442 | Link | |
Yes, I tried this. This was the first I set. (I gave the path of CCE for eclCCE first time and I set the path of eclCCE.exe for RB.) But I stucked. I don't know why, but CCE wants to work only with another kind of ECL (like CCE's or DVD2DVD-R's) not the RB's one... I'll drop my PC through the window. (just a joke) |
29th March 2004, 20:38 | #443 | Link | |
Here is the ECL,which was made by DVD2DVD-R: ; CCE SP Trial Version -- Encoder Control List [item] title=H:\test\B...........Y_D9_06.01.2004_09.08\Video_0xE0.AVS vid_out=1 vaf_out=1 aud_out=0 aud_mode=0 vid_file0=H:\test\B...........Y_D9_06.01.2004_09.08\Video_0xE0_NEW.M2V vid_file1=H:\test\B...........Y_D9_06.01.2004_09.08\Video_0xE0_NEW.M2V vaf_file=H:\test\B...........Y_D9_06.01.2004_09.08\Video_0xE0_NEW.VAF aud_file= file_focused=0 video_type=4 timecode=0x0 tc_ref_frm=0 drop_frame=0 cbr_brate=5250 opv_q_factor= opv_brate_min= opv_brate_max= vbr_brate_avg=5250 vbr_brate_min=1000 vbr_brate_max=6951 vbr_bias=20 vbr_pass=4 create_new_vaf=0 pulldown_detect=0 letter_box=0 panscan=0 aspect_ratio=3 credits_tweak=0 credits_start=0x12439 credits_brate=6951 h_filter=0 h_filter_idx=0 use_filter=0 filter_val=0 dither=0 dither_max=0 quality_prec=15 intra_dc_prec=2 alternate_scan=0 non_linear=0 progressive=1 gop_m=3 gop_nm=4 gop_hdr=12 seq_hdr=1 seq_endcode=1 dvd=1 all_closed_gop=0 fix_gop_length=0 fix_vbv_delay=0 offset_line=0 half_width=0 half_height=0 uscc=0 lum_level=0 packet_size=2048 frame_rate_idx=3 qmat_idx=0 mpeg1=0 mpeg1_cps=1 brate_idx=7 stereo=2 samples_per_sec=44100 crc=1 width=720 height=576 [file] name=H:\test\B...........Y_D9_06.01.2004_09.08\Video_0xE0.AVS type=0 frame_first=0 frame_last=145448 encode_first=0 encode_last=145448 Unfortunately I cannot insert the ECL of RB, because I deleted the movie in the meantime (I encoded the movie with DVD2DVD-R)... |
29th March 2004, 21:10 | #445 | Link | |
- DVDRB User -
Re: Quality precision
- CaN - |
29th March 2004, 21:18 | #446 | Link |
I hope someone will be able to help me.
I have a problem with Rebuilder 0.26, it wont encode. I am using CCE Trial with ECLCCE but when using METHOD TWO and press the "Encode" button CCE lauches with "ITEM.ECL" as the title, but nothing happens there are nothing in the CCE window and Rebuilder uses 100% CPU. I left it like this for 3 hours but nothing was created. Any ideas or advice? Thanks Tom |
29th March 2004, 23:05 | #448 | Link |
Encounterd the #0004 error during the rebuilding phase. Before version 0.26 the Runtime error '9' showed up at the same point. I played all files in a player and it does not come up with an error. The VTS itself holds 350 files of witch 300 files are the same sort(stills. but if played it's black screen) and size(45kb). But after 247 files rebuilded from VTS03 i get the error! I hoop it's helps you a bit and if you need more info please ask.
Disney's Dumbo / Version 0.26 CCE 2.0.67.23 Eclcce 1.7b Bug See above Last edited by Raymongo; 29th March 2004 at 23:08. |
29th March 2004, 23:22 | #449 | Link |
I also still get the Runtime '9' error in the PREPARE Phase as discribed here: Original post
De Schippers van de Kameleon / Version 0.26 CCE 2.0.67.23 Eclcce 1.7b Bug see above |
29th March 2004, 23:31 | #450 | Link |
Nice Program, I tried it on Apocalypse Now Redux, a very long movie (202 min) I encountered no errors, but the final result came in at exactly 5 gigs
win2000 DVD-RB 0.26 CCE 2.67.00.23 w/ECLCCE 1.8 Last edited by dave88; 29th March 2004 at 23:41. |
29th March 2004, 23:35 | #451 | Link |
DVD-RB Fan
Thanks jdobbs
First Post. Had to wait five days...and have been almost glued to the pc reviewing all three threads. Made donation five days ago also 'cause I knew this program would eventually work for all.
Anyway, I did a no no, and stripped out the movie with DVDShrink (no compression) to obtain full quality for the movie. While the coding looks great, I have the stuttering(?) at the chapter points. I'm redoing the dvd with the full compliment of files *not just movie only) to see if the stuttering goes away. I used: DVDrbv26, DVDShrink 3b5, CCE2.5, Avisynth 2.54, Ecl 1.7. The movie was LOTRings2. Has anyone been successful in using DVDShrink, then DVDRB? Last edited by Stive; 29th March 2004 at 23:49. |
29th March 2004, 23:36 | #452 | Link |
Version 0.26
CCE 2.50 Eclcce 2.67.0.23 (1.7b) Lion King 3, Love Actually Error #0003 and #0004 (exactly like Raymongo) That happens whether I use CCE or Rejig, at same point. Up to now (from V. 018) everything worked as it was expected, except with 'hickups' at chapter points. |
29th March 2004, 23:46 | #453 | Link | |
29th March 2004, 23:48 | #454 | Link | |
30th March 2004, 00:36 | #457 | Link |
AviSynth 2.54
CCE 2.67.00.23 ELCCE 1.8 DVD2AVI DG Version I'm still getting the skipping/stutter between chapters with DVD-RB 0.26. I ripped the VOB files for the Matrix Reloaded to my HD, then just pointed DVD-RB at em. The only thing I stripped out was the french audio. The prepare, encode, and rebuild procedures went just fine, no errors at all. I have a Sony standalone DVD Player and I noticed in-between chapters it seems to freeze for just a second. This occurs during normal playback of the DVD, not during ff/rw. Last edited by kadilak; 30th March 2004 at 00:56. |
30th March 2004, 00:42 | #458 | Link | |
Re: Thanks jdobbs
30th March 2004, 00:54 | #460 | Link | |
DVD-RB Fan
