8th December 2003, 02:45 | #741 | Link |
I have just tried AutoGK with xvid 1.0 beta 2 and with everything set to default (xvid, bfames, cm, trellis, mpeg). The first pass seems OK but then AutoGK reports a divide by zero error when going to the 2nd pass. I ran the test again with koepi's XviD-24062003-1 version and it seemed to work OK. Is AutoGK compatible with the latest xvid or is there something I have missed?
Gazza |
8th December 2003, 04:11 | #743 | Link |
Hello...
I was wondering whether xvid, vobsub, and/or avisynth were required for autogk to work for a 1 cd divx with mp3 audio and subtitles. How about for a 2 cd divx with ac3 and subtitles? Thanks... JJ |
8th December 2003, 08:31 | #744 | Link |
clueless n00b
vobsub is required for subs (doesn't the name already tell you that?) avisynth is required for everything and the codecs are required as you use them. xvid output without an xvid codec installed will obviously fail, and the same goes for divx output without the divx codec installed.
8th December 2003, 10:45 | #745 | Link |
0.67 multi-disk Divx splitting problem
The bug appears to be in vdubmod 1.5.10.1. Both it and 1.5.4.1 show the length of Movie.avi as 144012 frames when I just load movie.avi. But when running lastjob.vcf and spliting off CD1, CD2 or CD3 it shows the total number of frames to be processed as 184,371 each time, 28% bigger. Each CD.avi is turning out 132% or so bigger that the original unsplit movie.avi, instead of 33% as you would expect.
irtualDub.Open("L:\\Movie.avi",0,0); VirtualDub.RemoveInputStreams(); VirtualDub.stream[0].SetSource(0x73647561,0,0); VirtualDub.stream[0].SetMode(0); VirtualDub.stream[0].SetInterleave(1,500,2,0,0); VirtualDub.video.SetDepth(24,24); VirtualDub.video.SetMode(0); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.subset.AddRange(100948,42359); VirtualDub.SaveAVI("L:\\Movie.CD3.avi"); |
8th December 2003, 12:00 | #746 | Link | |
I'm afraid we've to stop
Re: 0.67 multi-disk Divx splitting problem
I'm off to VdubMod forum *Edit* look at this: http://forum.doom9.org/showthread.php?s=&threadid=66249 problem should be solved by: ============================= Just check "Include selection and edit list" when "Save processing settings". Avery Lee added this checkbox since VirtualDub 1.5.5. ============================ I'll add those values in the registry in the next version (coming today).
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 8th December 2003 at 12:03. |
8th December 2003, 13:00 | #747 | Link |
version 0.68 beta is out
Should automatically check registry settings for correct new VDubMod usage now.
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
8th December 2003, 13:12 | #748 | Link | |
Re: Re: Re: Re: Re: Re: confusion about auto size
8th December 2003, 17:40 | #749 | Link | |
9th December 2003, 02:23 | #750 | Link |
thanks as always. I had used GK for 10 movies, and GKfast4u for 2 movies, last night I tried AutoGK 0.66 for Fight Club.
as 0.4x, I used 2cd for one movie, and it created 3 files avi (one 1.4gb avi, then 2 x 1cd files, it had some problem of disk space for me, and I also need split subs for the 2 cd files, I had difficulties sync. the time for cd2.... so, this time, I used Custom size of "1400mb" option below rather than the 2cd option, hoping it will save some space and when I do the split, I can manually control the sub's time...well, this morning I still saw 3 files, 1 1.36gb avi 1st came out, then 2 1.83gb files each, named cd1, cd2, I browsed these 2 files, found them still the whole movie, and sounds like latter part of these two files having no sound... strange?I wonder why it still had 2 cd1/cd2 files after the correct 1.36gb file, and these two files are of in-correct content(same full length move)/length(1.83gb each)/sound(partly no sound)...will this be fixed? thank you again. Last edited by lilian2k3; 9th December 2003 at 02:31. |
9th December 2003, 02:24 | #751 | Link |
here is partly the log file...
[2003-12-8 15:13:12] Input dir: C:\FIGHT_1\VIDEO_TS [2003-12-8 15:13:12] Output file: C:\FIGHT_1\VIDEO_TS\fightclub.avi [2003-12-8 15:13:12] Audio: English [2003-12-8 15:13:12] Subtitles: none [2003-12-8 15:13:12] Target size: 1400Mb [2003-12-8 15:13:12] Custom audio settings: AC3 [2003-12-8 15:13:12] Started encoding. [2003-12-8 15:13:12] Demuxing and indexing. [2003-12-8 15:26:53] Source seems to be pure FILM. [2003-12-8 15:26:55] Found 200209 frames [2003-12-8 15:26:55] Audio size: 467618816 [2003-12-8 15:26:55] Overhead: 2377472 [2003-12-8 15:26:55] Video Size: 998010112 [2003-12-8 15:26:55] Running compressibility test. [2003-12-8 15:26:55] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\fightclub_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\filters\mpeg2dec3dg.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\undot.dll") function getOrder(clip c) { order = GetParity(c) ? 1 : 0 return order } movie = mpeg2source("C:\FIGHT_1\VIDEO_TS\tmp\fightclub.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=40) c_width = width(cropclip) c_height = round(height(cropclip) / 1.21518987341772) input_par = float(c_width)/float(c_height) fixed_aspect = input_par > 1.4 ? 1.21518987341772 : 1.18518518518519 c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) out_width = 704 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 8) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=40) Undot() LanczosResize(out_width,out_height) SelectRangeEvery(300,15) =========================================================== [2003-12-8 15:26:55] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\FIGHT_1\\VIDEO_TS\\tmp\\fightclub_comptest.avs",0,0); VirtualDub.video.SetMode(1); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetRange(0,0); VirtualDub.video.SetCompression(0x64697678,0,10000,0); VirtualDub.video.SetCompData(1208,"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"); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.SaveAVI("C:\\FIGHT_1\\VIDEO_TS\\tmp\\fightclub_comptest.avi"); =========================================================== [2003-12-8 15:47:37] Duration was: 20 minutes 42 seconds [2003-12-8 15:47:38] Speed was: 8.06 fps. [2003-12-8 15:47:41] Compressibility percentage is: 71.13 [2003-12-8 15:47:41] Chosen width is: 704 [2003-12-8 15:47:41] Predicted comptest value is: 71.13 [2003-12-8 15:47:41] Running first pass. [2003-12-8 15:47:41] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\fightclub_movie.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\filters\mpeg2dec3dg.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\undot.dll") function getOrder(clip c) { order = GetParity(c) ? 1 : 0 return order } movie = mpeg2source("C:\FIGHT_1\VIDEO_TS\tmp\fightclub.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=40) c_width = width(cropclip) c_height = round(height(cropclip) / 1.21518987341772) input_par = float(c_width)/float(c_height) fixed_aspect = input_par > 1.4 ? 1.21518987341772 : 1.18518518518519 c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) out_width = 704 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 8) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=40) Undot() LanczosResize(out_width,out_height) =========================================================== [2003-12-8 15:47:42] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\FIGHT_1\\VIDEO_TS\\tmp\\fightclub_movie.avs",0,0); VirtualDub.video.SetMode(1); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetRange(0,0); VirtualDub.video.SetCompression(0x64697678,0,10000,0); VirtualDub.video.SetCompData(1208,"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"); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.SaveAVI("C:\\FIGHT_1\\VIDEO_TS\\fightclub.avi"); =========================================================== [2003-12-8 21:27:55] Duration was: 5 hours 40 minutes 12 seconds [2003-12-8 21:27:55] Speed was: 9.81 fps. [2003-12-8 21:27:56] Expected quality of first pass size: 75.29 [2003-12-8 21:27:56] Running second pass. [2003-12-8 21:27:57] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\FIGHT_1\\VIDEO_TS\\tmp\\fightclub_movie.avs",0,0); VirtualDub.video.SetMode(1); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetRange(0,0); VirtualDub.video.SetCompression(0x64697678,0,10000,0); VirtualDub.video.SetCompData(1208,"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"); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.RemoveInputStreams(); VirtualDub.stream[0].SetSource("C:\\FIGHT_1\\VIDEO_TS\\tmp\\FIGHTCLUB AC3 T01 3_2ch 448Kbps DELAY 0ms.ac3",0x00000203,0); VirtualDub.stream[0].SetMode(0); VirtualDub.stream[0].SetInterleave(1,500,2,0,0); VirtualDub.stream[0].SetClipMode(1,1); VirtualDub.stream[0].SetConversion(0,0,0,0,0); VirtualDub.stream[0].SetVolume(); VirtualDub.stream[0].SetCompression(); VirtualDub.SaveAVI("C:\\FIGHT_1\\VIDEO_TS\\fightclub.avi"); =========================================================== [2003-12-9 4:09:03] Duration was: 6 hours 41 minutes 5 seconds [2003-12-9 4:09:04] Speed was: 8.32 fps. [2003-12-9 4:09:06] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\FIGHT_1\\VIDEO_TS\\fightclub.avi",0,0); VirtualDub.RemoveInputStreams(); VirtualDub.stream[0].SetSource(0x73647561,0,0); VirtualDub.stream[0].SetMode(0); VirtualDub.stream[0].SetInterleave(1,500,2,0,0); VirtualDub.video.SetDepth(24,24); VirtualDub.video.SetMode(0); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.subset.AddRange(0,102148); VirtualDub.SaveAVI("C:\\FIGHT_1\\VIDEO_TS\\fightclub.CD1.avi"); =========================================================== [2003-12-9 4:09:06] Splitting video into: C:\FIGHT_1\VIDEO_TS\fightclub.CD1.avi [2003-12-9 4:29:48] Writing the following script to C:\FIGHT_1\VIDEO_TS\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\FIGHT_1\\VIDEO_TS\\fightclub.avi",0,0); VirtualDub.RemoveInputStreams(); VirtualDub.stream[0].SetSource(0x73647561,0,0); VirtualDub.stream[0].SetMode(0); VirtualDub.stream[0].SetInterleave(1,500,2,0,0); VirtualDub.video.SetDepth(24,24); VirtualDub.video.SetMode(0); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.subset.AddRange(102148,97628); VirtualDub.SaveAVI("C:\\FIGHT_1\\VIDEO_TS\\fightclub.CD2.avi"); =========================================================== [2003-12-9 4:29:48] Splitting video into: C:\FIGHT_1\VIDEO_TS\fightclub.CD2.avi [2003-12-9 4:44:43] Job finished. |
9th December 2003, 02:46 | #752 | Link |
ohoh, intersting findings:
I checked again these 2 big cd1/cd2 files, this cd1 file, contains the whole movie with sound, and till end of the feature, it continues with a no-sound 1st part of the feature, then the cd2 file, contains again the whole movie with sound, and till end of the feature, it continue the latter part of the movie again, but no sound. looks like cd1= movie + 1/2 movie, cd2=movie+ 2/2 movie.... |
9th December 2003, 02:47 | #753 | Link | |
The 1.83 GB bug is actually a "feature" problem should be solved by: ============================= Just check "Include selection and edit list" when "Save processing settings". Avery Lee added this checkbox since VirtualDub 1.5.5. ============================ Tick this option to fix it or D/L 0.68 which already has it ticked. |
9th December 2003, 11:01 | #755 | Link |
Short one:
What if I select a Minimum Width (say 704) in Advanced Seetings dialog and leave Audio to Auto. Will AGK choose automatically between AC3 and MP3 to ensure good quality based on the analysis ? I am not to lazy to test, will do tonight, just don't have the project here on this computer. Btw. is there a reason why the max. file size is limited to 3000 MB (apart from the unlimited switch with no settings influence). I am currently dealing with Lotr 2 (3:45h joined parts) which gives me hard time obtaining good Video quality while keeping AC3 5.1. A max. settings of 4480 MB(DVD-R Size) would be preferable. mike Last edited by mikeathome; 9th December 2003 at 11:07. |
9th December 2003, 12:49 | #756 | Link |
I just had a quick question, I'm not sure if anyone has asked it before. Would it be possible to have an option to encode only the movie section and cut out the credits? I personally never encode the credits so that I can have a higher bitrate for the movie itself. I'm not sure if others do the same and how hard it would be to detect when the credits start but it's just a suggestion. Thanks for a great program!
Angelus |
9th December 2003, 13:05 | #757 | Link |
This end-credit point has been raised a few times now. How about using dvd2avi to specify the start and end point of the required encode.
I know you are going to go on about the 'newbies' but hear me out. You can leave things as they are so newbies can just use the program as usual. Users that want to cut off trailers/credits do this-> Right click on the task bar icon for dvd2avi, select restore. Hit esc. This stops the indexing. Hit F5 to check the movie. Hit esc again. Move the slider to the endpoint of the film (before the credits) and click ']'. Hit F4 ( save as ) and over write the file called <film_name>.d2v. So we drop the credits using dvd2avi as an edit console. No 'credit detection' filter required. shoot me down |
9th December 2003, 13:53 | #758 | Link | |
9th December 2003, 14:19 | #759 | Link | |
There is no way to provide a simple, easy-to-use tool, with "unlimited" functionality. I too would love to see some of GK:s features such as choice of Deinterlace method, noise filter, external subtitles and a job-queue, but then why don't I just go ahead and use GK instead? It's providing all those features. Perhaps AutoGK is a little bit too simple and GK a little bit too complex? Anyway, len0x is giving us access to one of the most "fun-to-use" apps around. Let's cut him some slack and implement what he think gives most value to AutoGK. Rock on! /C |
9th December 2003, 14:23 | #760 | Link |
0.68 bombing out on vdub
upgraded from 0.65 which works well. attempting to encode a movie. dvd2avi runs ok. program starts the 'analyzing source' section and vdub fall over.
see screen dump HERE I've probably got the wrong version of divx installed or something but i am attempting to perform a xvid encode. Previous version have all worked ok. autogk log ----------- [09/12/2003 12:37:06] Input dir: C:\PIRATESOFTHECARIBBEAN\VIDEO_TS [09/12/2003 12:37:06] Output file: C:\PIRATESOFTHECARIBBEAN\test.avi [09/12/2003 12:37:06] Audio: English [09/12/2003 12:37:06] Subtitles: none [09/12/2003 12:37:06] Target size: 1400Mb [09/12/2003 12:37:06] Started encoding. [09/12/2003 12:37:06] Demuxing and indexing. [09/12/2003 12:45:11] Analyzing source. [09/12/2003 12:45:11] Writing the following script to C:\PIRATESOFTHECARIBBEAN\tmp\lastjob.vcf =========================================================== VirtualDub.Open("C:\\PIRATESOFTHECARIBBEAN\\tmp\\_.avs",0,0); VirtualDub.RemoveInputStreams(); VirtualDub.video.SetDepth(24,24); VirtualDub.video.SetMode(0); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetCompression(); VirtualDub.video.filters.Clear(); VirtualDub.subset.Delete(); VirtualDub.SaveAVI("C:\\PIRATESOFTHECARIBBEAN\\tmp\\_.avi"); =========================================================== ************************************* EXCEPTION: Invalid floating point operation ************************************* [09/12/2003 12:53:41] Job finished. crashinfo.txt file from vdubmod -------------------------------- VirtualDub crash report -- build 2366 (release) -------------------------------------- Disassembly: 02e87ca0: 0f73d120 psrlq mm1, 20 02e87ca4: 0f73d420 psrlq mm4, 20 02e87ca8: 0fdbcd pand mm1, mm5 02e87cab: 0fdbe5 pand mm4, mm5 02e87cae: 0f73f118 psllq mm1, 18 02e87cb2: 0f73f418 psllq mm4, 18 02e87cb6: 0febc1 por mm0, mm1 02e87cb9: 0febe2 por mm4, mm2 02e87cbc: 0f6fcc movq mm1, mm4 02e87cbf: 0f73f130 psllq mm1, 30 02e87cc3: 0febc1 por mm0, mm1 02e87cc6: 0f7f00 movq [eax], mm0 02e87cc9: 0f73d410 psrlq mm4, 10 02e87ccd: 0fefc0 pxor mm0, mm0 02e87cd0: 0f6fce movq mm1, mm6 02e87cd3: 0f68c8 punpckhbw mm1, mm0 02e87cd6: 0f6fc3 movq mm0, mm3 02e87cd9: 0f68c7 punpckhbw mm0, mm7 02e87cdc: 0f6fd0 movq mm2, mm0 02e87cdf: 0f60c1 punpcklbw mm0, mm1 02e87ce2: 0f68d1 punpckhbw mm2, mm1 02e87ce5: 0f6fc8 movq mm1, mm0 02e87ce8: 0f73d120 psrlq mm1, 20 02e87cec: 0f73f118 psllq mm1, 18 02e87cf0: 0fdbc5 pand mm0, mm5 02e87cf3: 0febc1 por mm0, mm1 02e87cf6: 0f6fc8 movq mm1, mm0 02e87cf9: 0f73f120 psllq mm1, 20 02e87cfd: 0febcc por mm1, mm4 02e87d00: 0f7f4808 movq [eax+08], mm1 02e87d04: 0f73d020 psrlq mm0, 20 02e87d08: 0f6fda movq mm3, mm2 02e87d0b: 0f73d320 psrlq mm3, 20 02e87d0f: 0f73f318 psllq mm3, 18 02e87d13: 0fdbd5 pand mm2, mm5 02e87d16: 0febd3 por mm2, mm3 02e87d19: 0f73f210 psllq mm2, 10 02e87d1d: 0febd0 por mm2, mm0 02e87d20: 0f7f5010 movq [eax+10], mm2 <-- FAULT 02e87d24: 81c308000000 add ebx, 00000008 02e87d2a: 81c104000000 add ecx, 00000004 02e87d30: 81c204000000 add edx, 00000004 02e87d36: 0518000000 add eax, 00000018 02e87d3b: 47 inc edi 02e87d3c: 0f8519feffff jnz 02e87b5b 02e87d42: 5b pop ebx 02e87d43: 8b45d0 mov eax, [ebp-30] 02e87d46: 8b55dc mov edx, [ebp-24] 02e87d49: 0145c4 add [ebp-3c], eax 02e87d4c: f6c201 test dl, 01 02e87d4f: 7409 jz 02e87d5a 02e87d51: 8b45cc mov eax, [ebp-34] 02e87d54: 0145c0 add [ebp-40], eax 02e87d57: 0145bc add [ebp-44], eax 02e87d5a: 8b431c mov eax, [ebx+1c] 02e87d5d: 8b55e0 mov edx, [ebp-20] 02e87d60: 8d0c10 lea ecx, [eax+edx] 02e87d63: 894b1c mov [ebx+1c], ecx 02e87d66: 8b75dc mov esi, [ebp-24] 02e87d69: 46 inc esi 02e87d6a: 8975dc mov [ebp-24], esi 02e87d6d: 8b7dec mov edi, [ebp-14] 02e87d70: 39fe cmp esi, edi 02e87d72: 0f8cd0fdffff jl 02e87b48 02e87d78: 0f77 emms 02e87d7a: 8b75e4 mov esi, [ebp-1c] 02e87d7d: 8b7de8 mov edi, [ebp-18] 02e87d80: 89ec mov esp, ebp 02e87d82: 5d pop ebp 02e87d83: 89dc mov esp, ebx 02e87d85: 5b pop ebx 02e87d86: c3 ret 02e87d87: 90 nop 02e87d88: 53 push ebx 02e87d89: 89e3 mov ebx, esp 02e87d8b: 81e4f0ffffff and esp, fffffff0 02e87d91: 81ec08000000 sub esp, 00000008 02e87d97: 55 push ebp 02e87d98: 55 push ebp 02e87d99: 8b6b04 mov ebp, [ebx+04] 02e87d9c: 896c2404 mov [esp+04], ebp Windows 5.1 (Windows XP build 2600) [Service Pack 1] EAX = 01380ff0 EBX = 010da93c ECX = 010da69e EDX = 010da69a EBP = 0012f4b0 DS:ESI = 0023:02f029c0 ES:EDI = 0023:000000aa SS:ESP = 0023:0012f42c CS:EIP = 001b:02e87d20 FS = 003b GS = 0000 EFLAGS = 00010206 FPUCW = ffff027f FPUTW = ffffaaaa MM0 = 000000000000009b MM1 = 00009b00009b0000 MM2 = 009b00009b00009b MM3 = 0000009b00000000 MM4 = 00000000009b0000 MM5 = 0000000000ffffff MM6 = 9b9b9b9b9b9b9b9b MM7 = 0000000000000000 Crash reason: Access Violation Crash context: An out-of-bounds memory access (access violation) occurred in module 'divx'... ...while decompressing video frame 0 with "DivX Pro 5.0.5 Codec" [biCompression=32315659] (VideoSource.cpp:1823). Thread traces: Thread 00000ad4 (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(344) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(387) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Init.cpp(407) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(646) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(676) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1819) Thread call stack:02e87d20: divx!encore_backdoor [02e20000+16820+51500] 02edb77e: divx!decore_backdoor [02e20000+6d8d0+4deae] 02e8b19e: divx!encore_backdoor [02e20000+16820+5497e] 77f58a3a: ntdll!RtlAllocateHeap [77f50000+7bae+e8c] 77c2ac14: msvcrt!free [77c10000+1aa6b+1a9] 77c2ac19: msvcrt!free [77c10000+1aa6b+1ae] 02e27705: divx!00007705 00e5ee3c: avisynth!avs_create_script_environment [00e50000+e6e0+75c] 77f58a3a: ntdll!RtlAllocateHeap [77f50000+7bae+e8c] 77c2ac19: msvcrt!free [77c10000+1aa6b+1ae] 77c2ac2a: msvcrt!free [77c10000+1aa6b+1bf] 77c28930: msvcrt!??2@YAPAXI@Z [77c10000+18925+b] 77f58a3a: ntdll!RtlAllocateHeap [77f50000+7bae+e8c] 77c2ac14: msvcrt!free [77c10000+1aa6b+1a9] 77c2ac19: msvcrt!free [77c10000+1aa6b+1ae] 00e69ff3: avisynth!DllCanUnloadNow [00e50000+f4c0+ab33] 00e5b5bb: avisynth!0000b5bb 77c2ac19: msvcrt!free [77c10000+1aa6b+1ae] 77c2ac2a: msvcrt!free [77c10000+1aa6b+1bf] 77c28930: msvcrt!??2@YAPAXI@Z [77c10000+18925+b] 00e5f3a8: avisynth!avs_create_script_environment [00e50000+e6e0+cc8] 00e5ee3c: avisynth!avs_create_script_environment [00e50000+e6e0+75c] 00e5ee76: avisynth!avs_create_script_environment [00e50000+e6e0+796] 00e607a6: avisynth!DllCanUnloadNow [00e50000+f4c0+12e6] 00e607cc: avisynth!DllCanUnloadNow [00e50000+f4c0+130c] 00e60857: avisynth!DllCanUnloadNow [00e50000+f4c0+1397] 77c4a77d: msvcrt!_control87 [77c10000+3a756+27] 00e5ff1c: avisynth!DllCanUnloadNow [00e50000+f4c0+a5c] 73b555bf: AVIFIL32!AVIStreamRead [73b50000+55a1+1e] 02e28758: divx!DriverProc [02e20000+8148+610] 73bd181d: MSVFW32!ICSendMessage [73bd0000+17f4+29] 73bd47c6: MSVFW32!ICDecompress [73bd0000+478b+3b] 004bc941: VideoSourceAVI::getFrame() 0052b788: VDFastMemcpyAutodetect() 004836ab: CPUTest() 0048ceea: VDProject:isplayFrame() 77d43b4b: USER32!00003b4b 77d4546b: USER32!ReleaseDC [77d40000+5341+12a] 0048d7a7: VDProject::Open() 0048d7a7: VDProject::Open() 004992f9: func_VirtualDub_OpenOld() 004992f9: func_VirtualDub_OpenOld() 00527850: CScriptInterpreter::Token() 00526678: CScriptInterpreter::ParseExpression() 00526a8a: CScriptInterpreter::ParseExpression2() 77f58bcd: ntdll!RtlFreeHeap [77f50000+8a3e+18f] 77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9] 77e82441: kernel32!OpenMutexA [77e60000+22391+b0] 77f5d8e2: ntdll!RtlGetFullPathName_U [77f50000+d572+370] 77f59b7d: ntdll!RtlDosPathNameToNtPathName_U [77f50000+9b30+4d] 77f944cb: ntdll!RtlRemoteCall [77f50000+442ea+1e1] 77f58bcd: ntdll!RtlFreeHeap [77f50000+8a3e+18f] 77f59037: ntdll!RtlFreeHeap [77f50000+8a3e+5f9] 0052728e: CScriptInterpreter::LookupRootVariable() 00527850: CScriptInterpreter::Token() 00526678: CScriptInterpreter::ParseExpression() 005276b8: CScriptInterpreter::Token() 00526438: CScriptInterpreter::ExecuteLine() 00568f4b: fgetc() 004827de: ?$vector:ush_back() 00496d55: RunScript() 0047dfdd: ParseCommandLine() 77dd1859: ADVAPI32!RegCloseKey [77dd0000+17d8+81] 004883d3: QueryConfigDword() 004630a5: DetectDivX() 0047d366: Init() 00482e00: WinMain@16() 77f59bf9: ntdll!RtlReleasePebLock [77f50000+9bea+f] 77e61a57: kernel32!GetStartupInfoA [77e60000+177e+2d9] 77e619ef: kernel32!GetStartupInfoA [77e60000+177e+271] 00566f34: atexit() 00568b9e: WinMainCRTStartup() 77e814c7: kernel32!GetCurrentDirectoryW [77e60000+21483+44] -- End of report Last edited by wertert; 9th December 2003 at 14:31. |
