23rd August 2009, 11:06 | #183 | Link | ||
BluRay Maniac
23rd August 2009, 13:02 | #184 | Link | |
Creating mass of content that not all of the current Device Generation is able to playback, though essentially it's not a bad thing it brings manufactures under pressure to deliver the performance from their Hardware user expect to play their "Home Made" Content on In the Standalone area we already hit that mostly next will be the low power Mobile area which still struggles with what the consumers expect (and imho not all the complexity user put in their encodes is really always necessary but they are used to it already and the industry needs to comply). It will be really interesting to see how this might could push again lower complexity (Old Generation Codecs) once more as their complexity is pretty much playable on every Device that's gonna come out so the need of trans-coding is virtually gone for those, H.264 didn't reach that yet and most probably will take another Year end of 2010 till that goal will be reached. So you can say we reached a Transcoding free consumer world for ASP and VC-1 now (but not everywhere used like in Sat Broadcast), though H.264 will take another year in that
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd August 2009 at 13:10. |
24th August 2009, 22:32 | #185 | Link | |
Unfortunately, I'm still not having much luck - now using a 23.976fps file to rule out possible interlace compatibilities.
My MeGui configuration line looks like this: Quote:
I'm assuming I'm missing something fundamentally basic here - I even knocked 1Mbps off the Max Bitrate hoping to give an extra room for error, but I'm still getting the same Buffer Underflow error in Scenarist. Any suggestions? |
24th August 2009, 23:32 | #186 | Link |
BluRay Maniac
You can try to reduce vbv-buffer to 29000 or even to 24000 or less. Aslo can you cut 50 mb sample and post here to see where is problem. Aslo you can use tools like Elecard Buffer Analyser to see where underflow occur.
25th August 2009, 07:52 | #189 | Link |
...and as promised for testing this scenario, here's 7zip Lagarith YV12 segments of Match Point.
A rather more typcial trailer than the insanely fast cutting, high grain, and constantly moving camera of "The Island." But it's chock full of fades. http://cid-bee3c9ac9541c85b.skydrive.../Match%20Point |
25th August 2009, 11:26 | #190 | Link |
Can someone please provide a checksum.
I'm having problems extracting again.
http://www.7-zip.org/ |
25th August 2009, 13:30 | #191 | Link | |
Software Developer
Unfortunately the overview page that shows all files doesn't exhibit proper download URL's, so DTA and friends can't help here... Can't you ask Xiph to put it on their http://media.xiph.org/ server or at least put it on a service like Rapidshare ???
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th August 2009 at 17:16. |
25th August 2009, 17:15 | #192 | Link |
Can anyone here share the secrets for encoding compliant Secondary Video streams?
All I have so far is that the frame rate has to match the primary video, and since we're using AVC, the secondary video must be AVC also. And the max bit rate can't go above 8mbps, but this is talking heads stuff in SD resolution, so 2mbps should do it fine... Can anyone fill me in on the VBV buffer size? Number of B frames? Keyframe interval? |
25th August 2009, 19:32 | #193 | Link | ||
OK, I'm in the process of uploading two clips to my skydrive account.
1 is The Island trailer that Ben posted, encoded with x264 build 1222. This muxes well in Scenarist 5.1.3. Download x264 encode her --> http://cid-4574e83941533037.skydrive...0x264%20-%20BD 2 is a short clip from a German H.264 broadcast that I have parsed into AVISynth using DGAVCIndex, created a Lagarith YV12 avi file with VirtuaDub and the parsed that into MeGUI using an AVISynth script. This does not mux in Scenarist 5.1.3, giving me a buffer underflow error. This has been the file I have been trying to encode with at all manner of settings. At this time I can't understand why one AVS source file should work, and another should not - both encode without errors. The MeGUI config line for The Island is: Quote:
I'm assuming that for an x264 setting, the above is pretty 'basic' as I'm seeing compression artifacts over the green opening slate - I'll try automated 3 pass to see if that makes any difference, otherwise what do people suggest? Stoopid n00b question, but whenever I've done a 3 pass with MeGui before it always asks me to overwrite the 2nd pass with the 3rd pass - is this correct? Is there a way to out the 2 passes seperately? Would I ever need to do that? Many Thanks DVD-BOY Last edited by dvdboy; 26th August 2009 at 01:07. |
25th August 2009, 19:58 | #194 | Link | ||
25th August 2009, 20:19 | #196 | Link | |
Software Developer
With my 128 kbit/s connection (upstream) it would take far too long to upload a file of that size BTW: I downloaded the first three parts - just for test. And both, 7-Zip and WinRAR, refuse to open the archive with "unspecified error". At least with RAR you can open multi-volume archives, even if you don't have all volumes (yet). So is anything wrong with my download or is that normal?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 25th August 2009 at 20:25. |
25th August 2009, 23:52 | #200 | Link | ||
http://forum.doom9.org/showpost.php?...&postcount=106 ...tbc |
authoring, blu-ray, compliant, verified, x264 |
