3rd April 2012, 19:59 | #361 | Link |
I'm getting a CUDA error and "Failed to create video decoder (100)" running dgdecnv with this latest build you have posted today.. I'm guessing it needs to be recompiled too. Or is there something else which can be done to my script?
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
3rd April 2012, 20:15 | #362 | Link |
I'm even more puzzled: dgdecnv (latest) works without problems for me and changes in build environment were quite minor.
You don't need any recompilation. Try to pinpoint what exactly causes crash: plugin? OS? or it crashes even without plugins with plain AviSource? |
3rd April 2012, 20:31 | #363 | Link | |
CUDA is working with other cuda test programs etc on my pc. I'm running win7 64-bit. I'm using the latest dgdecnv too. My source file is an MTS file which I just indexed with dgindexnv, so I can't use AviSource on it. Instead I used AviSource on another avi, and this works without problems. I'm using Virtualdub 1.9.11. Tried reinstalling my dgdecnv and I get the same result ..
3rd April 2012, 20:36 | #364 | Link |
I just checked.. it works with the stock 2.6 release.
3rd April 2012, 20:40 | #365 | Link |
but not with your avisynth.dll.. at least for me and my 64-bit win7.
3rd April 2012, 21:17 | #367 | Link |
Just in case I wasn't too clear, as far as I'm aware it's not crashing. It's dgdecnv which gives the message and obviously there's no actual video, but the video itself is replaced with the message 'CUDA error' generated by dgdecnv...
6th April 2012, 12:13 | #368 | Link |
Avisynth 2.6 MT installer (2012.04.03) -> http://www.mediafire.com/?7l0cbjpcd4av1wb
Installer source files -> http://www.mediafire.com/?zu8m4b5zbjmt08e
6th April 2012, 12:27 | #369 | Link | |
User of free A/V tools
I was thinking to prepare some installer myself but had no time to get to it. |
7th April 2012, 11:36 | #372 | Link |
i didn't know that.
23rd April 2012, 09:39 | #373 | Link |
I solved the CUDA problem when using DGDecNV. Here's how.
As a reminder, 1. A dialog box comes up (DGSource) saying 'Failed to create video decoder (100)'. 2. 'CUDA error' is displayed instead of the video. avisynth.dll is in c:\windows\syswow64 The stable avisynth and the 64 bit avisynth builds worked with dgdecnv without problems for me. Script is a simple call to dgsource. It turn out I had an old nvcuvid.dll in the avisynth plugins directory. Deleting this file solved the problem. I'm not aware how this build triggered the problem (the stable build didn't) but I'm glad I found the solution.
24th April 2012, 08:20 | #374 | Link |
RedDwarf Fan
This new version won't work with AvsPmod 2.2.1 or 2.2.0 on my system, whereas the earlier version that I was using worked without problems. I get a CPP runtime library error. This application has requested the Runtime to terminate it in an unusual way.
That is with the plugins folder renamed so no usable plugins and a new copy of AvsPmod, so no scripts or old settings. 2012-03-31 is working okay which I wasn't using previously because I was still on an older version. |
26th April 2012, 19:04 | #375 | Link |
cweb, oh, I have an idea now.
Another change I forgot to mention is how plugin DLLs are loaded. Now if they have dependencies – dependencies are searched first in the same folder as loaded plugin DLL. Hopefully it will reduce amount of DLLs you have to place in system32, but as it's different to earlier behavior it can cause unexpected situations like yours. RedDwarf1, AvsPmod 2.2.1 works ok for me. Need more information to debug things. "This application has requested the Runtime to terminate it in an unusual way." means there is uncaught C++ exception somewhere. |
1st May 2012, 15:40 | #376 | Link |
With the last build i got the same error as titlis and RedDwarf1.
I'm on Windows XP SP3 32bit, AvsPmod 2.2.1 keeps crashing with a simple script with just an mpeg2source call. The same happens wit MeGUI as soon as i try and load the same script. |
1st May 2012, 19:33 | #377 | Link | ||
RedDwarf Fan
I'm using XP SP3 as well. I can try it on another windows install when I get a chance and reboot. Last edited by RedDwarf1; 1st May 2012 at 19:37. |
6th May 2012, 14:31 | #379 | Link |
To debug this I need a way to reproduce the error. Or at least location of unhandled exception thrown and stack trace, so someone with debugging skills is needed for second approach.
To pinpoint what is causing your problems start with clean system (you can use VM – it lakes few minutes to set up but very useful for many experiments) and gradually add what you have. I suspect stray DLL in unexpected location that is now loaded instead of expected DLL. |
