21st May 2009, 01:53 | #2841 | Link |
I am getting a error with 604. When I click on a entry in the names editor, I get these two errors. It only happens with DVD folders.
http://www.apah20.dsl.pipex.com/dvd/avchderror.jpg Program then quits |
21st May 2009, 02:49 | #2842 | Link | |
21st May 2009, 08:09 | #2843 | Link | |
The best way for me in case of errors always was to do a full download of the last build and start clean. |
21st May 2009, 11:53 | #2845 | Link |
Programmer (or just 教务长)
Did you use DVD or BD disc? Because 'strict' option affects only AVCHD for DVD.
A quick note for 604+: * Fixed some minor bugs which may cause the error nwg reported * Added "COLOR" for xmb thumbnail border in XMB section of Author tab. * Extended support for DVR TRP files - most should work now * Fixed a problem with multiple AAC/MPEG audio tracks in the same mts/trp/etc.. file - sometimes get overwritten or didn't show. Dean |
21st May 2009, 12:41 | #2846 | Link | |
21st May 2009, 13:09 | #2848 | Link | |
I just used the update to get 604+ |
21st May 2009, 14:40 | #2849 | Link |
Hi Dean
Any way to have no chapters created at all? For example one has a set of titles in a compilation that all run 3-11 min each but you would not want to have a chapter at 5 min in any of the ones that run more than 5 min. I tried the settting of No Chapters but it still creates chapters for each title. Thanks |
21st May 2009, 17:03 | #2853 | Link |
@deank
Why did you modify my idea? Text must be centered. Why did you remove arrows? I gave ready to use script. It was supposed to be like this
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st May 2009 at 17:07. |
21st May 2009, 18:03 | #2854 | Link |
It was a beta screenshot...
Text is centered. Arrows - i can put them back, but they will not be high-lighted when moving left/right... not chapter marker... I can of course start from scratch and remove the carousel menu. Just be more patient... it is not as easy as creating an avisynth script. |
21st May 2009, 18:12 | #2855 | Link |
Hey guys, whats up ? I got a question about this software ... I'm still a n00b at this stuff, so please bear with me :P
When making a PS3 Compatible AVCHD Disc, is it possible to change the Title of the Disc with multiAVCHD ? I mean, when I insert an AVCHD Disc in my PS3, it just says 'AVCHD' next to the disc icon. Is it possible to change this to a more meaningful name? Thanx in advance |
21st May 2009, 19:15 | #2858 | Link | |
BTW. I see no text/time on left side. Question: Do we really need that info box in right top corner?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st May 2009 at 19:18. |
21st May 2009, 19:21 | #2859 | Link |
There is text on the left side now... Infobox is from tmt... once i'm done i'll change the screenshot.
I changed font size, because 60 was too big... + you can't expect it to be 100% as in your script and unmodifiable. I took your idea about it but if you insist that everything is kept 100% as you suggested, I'd rather do something different and not worry about complaints and stuff. Classic, THM and XMB are good enough for me. Last edited by deank; 21st May 2009 at 19:25. |
21st May 2009, 19:34 | #2860 | Link | |
BTW. Don't get me wrong. I appreciate your work. Maybe I'm too precise but like everything in order.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 21st May 2009 at 19:36. |
