Old 27th December 2019, 16:25   #3661  |  Link
stax76
stax76's Avatar
I wish Visual Studio project files were included in the source, so I can use 'Go to document' and 'Go to definition' in order to understand the code. Right now I'm looking at vsvfw.cpp and want to know which header declares IUnknown. Maybe I have to try creating a project file.
Old 27th December 2019, 16:33   #3662  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
They are included: msvc_project/vapoursynth.sln
IUnknown is obviously from a system COM header.
Myrsloik is offline   Reply With Quote
Old 27th December 2019, 16:41   #3663  |  Link
stax76
stax76's Avatar
Sorry, I overlooked it. I'm not very good in C++ right now, first C++ project after over ten years.
Old 28th December 2019, 21:49   #3664  |  Link
Myrsloik
Myrsloik's Avatar
Audio support is almost done
Old 28th December 2019, 22:10   #3665  |  Link
yoon
Originally Posted by _Al_ View Post
Not sure if I understand, do you want to encode each cropped clip separately?
You can use vspipe --outputindex to specify what output to process
import vapoursynth as vs
from vapoursynth import core
clip = core.lsmas.LWLibavSource(source=r'clip.mkv')
clip = core.std.Trim(clip, 0, 59)
clip = core.resize.Bicubic(clip, 600,340)
new_resolution = (clip.width/2, clip.height/2)
clip1 = core.std.CropAbs(clip, *new_resolution, top=0, left=0,          )             #Top Left
clip2 = core.std.CropAbs(clip, *new_resolution, top=0, left=clip.width/2)             #Top Right
clip3 = core.std.CropAbs(clip, *new_resolution, top=clip.height/2, left=0)            #Bottom Left
clip4 = core.std.CropAbs(clip, *new_resolution, top=clip.height/2, left=clip.width/2) #Bottom Right
clip1.set_output(1)
clip2.set_output(2)
clip3.set_output(3)
clip4.set_output(4)
clip = clip1 + clip2 + clip3 + clip4
clip.set_output() #if not stated , default is zero: clip.set_output(0)
and when using command line:
vspipe --y4m your_script.vpy - | ffmpeg -f yuv4mpegpipe .. ....default is output zero
vspipe --outputindex 1 --y4m your_script.vpy - | ffmpeg -f yuv4mpegpipe ....... for clip1
vspipe --outputindex 2 --y4m your_script.vpy - | ffmpeg -f yuv4mpegpipe ....... etc for each output
odd video dimensions cannot be used here, it has to be at least even, (mod 2). In Vapoursynth it depends on video subsampling.
Thank you for your answer, I didn't know that outputindex option existed. That's great. Will try it this way.
yoon is offline   Reply With Quote
Old 29th December 2019, 10:57   #3666  |  Link
jmartinr
jmartinr's Avatar
Roelofs Coaching
jmartinr is offline   Reply With Quote
Old 29th December 2019, 13:10   #3667  |  Link
Selur
Selur's Avatar
Nice, hoping to view the wave front of an input file to find the audio delay of some files.
Thanks!
Cu Selur
Old 29th December 2019, 13:53   #3668  |  Link
Myrsloik
Myrsloik's Avatar
Thanks!
Cu Selur
Only trim, splice and raw pcm output from vspipe is planned for the first test version. There's however one little problem...
All existing audio sources suck so I'll probably have to improve FFMS2 first.
Feel free to start implementing audio plugins using the doodle1 branch. The API is conceptually stable (but tweaks will definitely be made).
Old 29th December 2019, 14:37   #3669  |  Link
Jukus
@Myrsloik
What about variable fps?
Jukus is offline   Reply With Quote
Old 29th December 2019, 15:04   #3670  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by Jukus View Post
@Myrsloik
What about you asking a complete question?
Old 30th December 2019, 05:19   #3671  |  Link
Jukus
VS does not support variable FPS for output, will it be implemented?
Old 30th December 2019, 08:22   #3672  |  Link
Lypheo
It does, though? Just have vspipe write the timestamp file with --timecodes and mux it in (or pass it to x264 or whatever).
Can we expect a test build soon or not until you’re done fixing ffms2?
Lypheo is offline   Reply With Quote
Old 30th December 2019, 09:50   #3673  |  Link
Myrsloik
Myrsloik's Avatar
There needs to be at least one decent source filter for audio or there won't be much to test really...
Old 1st January 2020, 01:30   #3674  |  Link
Cary Knoop
Cary Knoop
Cary Knoop's Avatar
I can't figure this out on Windows 10.
1. I installed Python using Anaconda (e:\anaconda3)
2. Installed Vapoursynth (all users) (e:\vapoursynth)
python myscript.vpy works fine!
print(core.version())
clip = core.std.BlankClip(format=vs.RGB24, color=[0, 0, 0])
clip.set_output()
vspipe and vsedit don't work.
vspipe --info myscript.vpy -
Setting PythonPath in registry to "e:\anaconda3" gives:
Failed to initialize VapourSynth environment
Setting PythonPath to "" gives:
Fatal Python error: initfsencoding: unable to load the file system codec
ModuleNotFoundError: No module named 'encodings'
Current thread 0x00008fdc (most recent call first):
Registry entries:
Key Name:          HKEY_LOCAL_MACHINE\SOFTWARE\VapourSynth
Class Name:        <NO CLASS>
Last Write Time:   12/31/2019 - 4:26 PM
Value 0
  Type:            REG_SZ
  Data:            48
Value 1
  Type:            REG_SZ
  Data:            e:\vapoursynth
Value 2
  Type:            REG_SZ
  Data:            e:\vapoursynth\core\plugins
Value 3
  Type:            REG_SZ
  Data:            e:\vapoursynth\plugins
Value 4
  Type:            REG_SZ
  Data:            e:\vapoursynth\core\vapoursynth.dll
Value 5
  Type:            REG_SZ
  Data:            e:\vapoursynth\core\vsscript.dll
Value 6
  Type:            REG_SZ
  Data:            e:\vapoursynth\core\vspipe.exe
Value 7
  Type:            REG_SZ
  Data:            e:\vapoursynth\vsrepo\vsrepo.py
Value 8
  Type:            REG_SZ
  Data:            e:\anaconda3
Created a batch file clearing all environment variables except for path, systemdrive and systemroot.
No change, same problem.
Cary Knoop is offline   Reply With Quote
Old 5th January 2020, 19:54   #3675  |  Link
feisty2
I'm Siri
feisty2's Avatar
I wrote some syntactic sugar stuff for the C++ API here: https://github.com/IFeelBloated/vapo...ster/sugar.hpp
C++2a support is required (I'm 100% sure C++17 aint cuttin' it), it compiles with "-std=c++2a" for GCC10
you can use
auto MakePlane(auto Pointer, auto Width, auto Height, auto PaddingPolicy)
to access the plane in a 2-dimensional style, out-of-bound access (automatic padding) is allowed for the source plane, but not allowed for the destination plane.
I'll give you a concrete example, to write a 3x3 box blur, you would do the following:
auto srcp = reinterpret_cast<const float *>(srcp8);
auto dstp = reinterpret_cast<float *>(dstp8);
auto padded_src = reinterpret_cast<float *>(malloc((width+2) * (height+2) * sizeof(float)));
for (auto y : Range{ height })
     std::memcpy(padded_src + (y+1) * (width+2) + 1, srcp + y * width, width * sizeof(float));
// lots of code here to deal with padding for "padded_src"
auto gc_addr = padded_src;
padded_src += (width + 2) + 1;
     for (auto x : Range{ width }) {
             auto above = padded_src - (width + 2);
             auto below = padded_src + (width + 2);
             dstp[x] = (above[x-1] + above[x] + above[x+1] + padded_src[x-1] + padded_src[x] + padded_src[x+1] + below[x-1] + below[x] + below[x+1]) / 9;
             dstp += width;
             padded_src += width + 2;
free(gc_addr);
with "sugar.hpp", that huge pile of nuisance is equivalent to simply
auto srcp = MakePlane<const float>(srcp8, width, height, Repeat);
auto dstp = MakePlane<float>(dstp8, width, height, Zero);
             dstp[y][x] = (srcp[y-1][x-1] + srcp[y-1][x] + srcp[y-1][x+1] + srcp[y][x-1] + srcp[y][x] + srcp[y][x+1] + srcp[y+1][x-1] + srcp[y+1][x] + srcp[y+1][x+1]) / 9;
             // possible out-of-bound access like "srcp[y-1][x-1]" is automatically handled here with the given padding policy, you got nothing to worry about
The header includes 3 pre-defined padding policies
Zero
Repeat (or simply called "pad" on this forum)
Reflect
however, you can also define your own padding policy by completing the following function and pass it to "MakePlane()"
auto PaddingFunction = [](auto Canvas, auto Width, auto Height, auto y, auto x) {
note that the "PaddingPolicy" argument has no effect on "dstp" as no padding is applied here.
you are welcome to leave a comment if you have any suggestions or ideas to further improve this.
feisty2 is offline   Reply With Quote
Old 5th January 2020, 20:05   #3676  |  Link
feisty2
I'm Siri
feisty2's Avatar
simple live demonstration: https://godbolt.org/z/MHebt8
Old 8th January 2020, 15:50   #3677  |  Link
Jukus
How to properly process the video where 3 progressive frames, 2 interlaced and it turns out that every 5 frame is a duplicate?
Old 8th January 2020, 18:50   #3678  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Standard IVTC? VFM to match fields followed by VDecimate to drop the dupes.
Old 11th January 2020, 17:18   #3679  |  Link
PlazzTT
PlazzTT's Avatar
I'm getting this error when compiling Vapoursynth on Linux (Mint 19.3)
I installed cython through pip.
"which cython" gives "/home/me/.local/bin/cython"
CXXLD libremovegrain.la
CC src/filters/vinverse/libvinverse_la-vinverse.lo
CCLD libvinverse.la
CC src/filters/vivtc/libvivtc_la-vivtc.lo
CCLD libvivtc.la
CYTHON src/cython/vapoursynth.c
/bin/bash: cython: command not found
Makefile:2217: recipe for target 'src/cython/vapoursynth.c' failed
make: *** [src/cython/vapoursynth.c] Error 127
Any ideas how to fix this?
PlazzTT is offline   Reply With Quote
Old 11th January 2020, 20:53   #3680  |  Link
Jukus
By the way, to the page:
http://www.vapoursynth.com/doc/insta...-from-packages
May be added that there is a ready-made solution for Debian:
https://www.deb-multimedia.org/
And, apparently, remove the link to packages for Ubuntu.
speed, vaporware, vapoursynth
