31st December 2010, 15:37 | #10702 | Link | |
Brilliant! Thank you so much for helping with this annoying issue. One last thing: will there ever be the fine level of control over "blanking" sections of a Blu Ray like there is in DVD-Rebuilder? Right now I'm making myself learn multiAVCHD in order to keep SOME of the extras on my disc, but blank out the previews... unless someone has a better way of doing this. I can see the option to "Blank this item", but it's grayed out in Full Movie mode, and if I switch to Movie Only mode not everything is available in order to blank things. DVD-RB's Segment Viewer/Editor is by far my favorite feature of that program... |
31st December 2010, 20:30 | #10703 | Link | |
Aging Video Hobbyist
Regarding STES API:
Thanks and HAPPY NEW YEAR jdobbs! |
31st December 2010, 21:47 | #10704 | Link | |
31st December 2010, 23:08 | #10706 | Link |
Happy new year!
I know this is the wrong thread but I've been following this thread for a while and used your software a few times to backup a BD so it's time to donate to keep this going. Hope you have a good new year and keep up the good work. Roger Heald |
1st January 2011, 01:40 | #10709 | Link |
Happy New Year!
I'm having trouble while reducing the size of a BD50 with in-movie-experience. That means, a DTS-Express-audio-part is in there. Will there be any way in future versions to have that cool feature also in the backup? Or is there already one and I have ben blind ? |
1st January 2011, 03:09 | #10710 | Link |
Here's any interesting disc problem. I'm just backing up a BBC disc of a UK series called 'Being Human' - Series 2 (I'm just doing the first disc to bd-9 Full). Everything went well with no warnings. When I play back the bd-9 (on all devices and pcs) I get the menu but no overlay, which prevents me from playing the disc - both the original disc and the iso on the HDD play fine with the overlay. The M2TS file with the menu is 152. If I read the original into TsMuxer, it reports an unsupported stream type and ignores it - on the bd-9 it doesn't, but shows the three streams that the original showed after the warning - a video, audio and subtitle track (although in BD-RB the subtitle track shows as being empty). If I read the original stream into TsRemux, it shows a fourth stream called 'Interactive Graphics Stream #0'. I'm guessing that if I replace the new 60 Mb m2ts file with the original 250 Mb one that it will probably work, but any idea why it fooled bd-rb?
1st January 2011, 03:48 | #10711 | Link |
BD-RB, with tsMuxeR, does not support IGS menu and DTS Express secondary audio.
If you replace the reencoded menu's with the original ones, the buttons may show as expected, but if the bitrate of the original is above the AVCHD limit, you may get stuttering video and audio for the menu playback! ( happened to me anyway). This will be corrected once jdobbs implements his own remux alternative. |
1st January 2011, 09:56 | #10713 | Link |
Jdobbs , I need clarification regarding option “PASS_TWO_STATS_UPDATE=n” When this option is enabled does it do three pass or two pass only. I ask because in gui you only see max of 2 pass even if this option is selected, where in hidden option it says if set to "1", BD-RB uses "--pass 3" for second pass . Kind of confused here.
Also there is hidden option which allow user to set output quality to be Ultra High by setting option “ENCODE_QUALITY=4” which assign preset to be slower in “lastcmd” file. I was curious x.264 also allow preset of very slow and placebo. Do you think it be beneficial have them. Ps: Happy new year. |
1st January 2011, 10:43 | #10714 | Link | |
RGR |
1st January 2011, 11:21 | #10715 | Link | |
In the meantime is there a way to show a disc which have this problematic stream? |
1st January 2011, 14:06 | #10718 | Link | |
No, I don't think it would of benefit to add the additional presets. They are massive overkill and give little benefit in this application at the expense of huge time costs. All they would do is give folks the impression I think they are needed -- and they are not. In truth I think the existing "Highest" mode is rarely if ever needed, in fact I can't remember the last time I used it. Just as a little tip... there is also a hidden "ENCODE_QUALITY=5" setting. I put it there for testing. It uses the fastest X264 settings available, but on most encodes you'll probably not want to do a permanent backkup with it, as you lose quality in order to gain speed. Last edited by jdobbs; 1st January 2011 at 14:12. |
1st January 2011, 14:15 | #10719 | Link | |
Honestly, though, there is little benefit from running two or more instances unless you are finding that there is a lot of unused CPU time. I would guess that to be rare except possibly with huge processor counts. X264 uses almost all (if not all) of the available processor time (I've seen ~100% usage reported on pass two with systems having 8 processors) -- and two concurrent instances will probably run slower than two sequential batch jobs. Last edited by jdobbs; 1st January 2011 at 14:21. |
1st January 2011, 17:07 | #10720 | Link |
Would this condition work if the desired output is BD5/9?
My experience was, I believe anyway, that the bitrate was too high for the BD5/9, and the backup had audio stuttering when keeping the original IGS menu. However, the BD-25 backup worked perfectly keeping the original menu.( using the MIN_M2TS=xxx) |
