29th March 2011, 21:11 | #1162 | Link | |
I suggest turning on Frame Time Correction (which is a hacky solution in a even hackier renderer), or get a good renderer like madVR.
29th March 2011, 21:34 | #1163 | Link | |
Also if it's not too much can you look at VC-1 settings cause I cant play any VC-1 (i) with nero decoder (which it's playing fine with MPC-HC's internal mpeg splitter) no matter what setting I choose in LAVSplitter = black screen or freeze video while sound it's playing.
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 29th March 2011 at 21:47. |
30th March 2011, 06:51 | #1164 | Link | |
30th March 2011, 08:46 | #1165 | Link |
As I've mention above I've tried all 3 settings including "disable" Also for VC-1 Progressive it seem to work although sometime it shows a green screen then normal image then again green and so on...
Intel UHD Graphics 750; Win 10 22H2 |
30th March 2011, 09:05 | #1166 | Link |
Then the nero decoder is not supported.
With that option disabled, it outputs exactly the same as the MPC-HC splitter.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 30th March 2011 at 09:25. |
30th March 2011, 09:34 | #1167 | Link | |
Anyway thanks for trying
30th March 2011, 12:20 | #1168 | Link |
I have rather a strange issue. All of my files are remuxes from original BD -> .TS with HD audio and PGS subtitles (via EAC3TO/TSMUXER).
Previously, was using an ancient version of Haali splitter in combination with AC3FILTER to bitstream TrueHD and DTS-HD cores to my receiver via Coax. Now using the LAV splitter, and LAV decoders for both audio and video (CUDA). Obviously the LAV audio decoder doesn't currently bitstream audio, but it's currently decoding fine. I tried to use FFSHOW audio decoder to bitstream the audio (assuming that it would be able to pass the core and bitstream that to the receiver). Unfortunately, with DTS-HD, FFDSHOW claims that it's receiving a 96hz DTS 7.1 channel track (when in reality its a 48hz DTS 5.1 channel track), this then borks MPC-HC and it doesn't play at all. Assume that splitting the core audio from HD-audio in the current version isn't implemented? Is that something that could be implemented in the future? If not, it's not a big issue, as the LAV decoder is working and I'm not generally doing much playback on the PC. Thanks very much for your work on the filters etc, it's allowed me to clean up the system and finally remove the Haali splitter :-) Cheers, -jj- |
30th March 2011, 12:23 | #1169 | Link |
The splitter will always send the full DTS-HD to the decoder. Why ffdshow gets confused by that, i cannot say. It should manage itself to split the core out of it and bitstream that, although i did read recently that they broke DTS Core bitstreaming out of DTS-HD some time back.
I will offer bitstreaming myself sooner or later, so if decoding works for you and you can be patient ..
30th March 2011, 12:53 | #1170 | Link |
Thanks for your feedback - patience is no problem, like mentioned, I'm not using the PC for much playback anyway (PCH C-200 media player here) and the decoding is working 100% anyway.
Let us know if you decide to accept some form of donations (the CUDA stuff is really great!) in the future. Cheers, -jj- |
30th March 2011, 13:17 | #1171 | Link |
hello , i have test some japan ts file have Memory leak(use all the memory),than hang .
and the other ts with dvbsub subtitle is not work well. dvb with sub http://www.mediafire.com/?hvs7d05u3voxzpn but it not have mpc-hc black screen problem Last edited by god_md5; 30th March 2011 at 13:24. |
30th March 2011, 13:33 | #1172 | Link | |
30th March 2011, 22:13 | #1173 | Link | |
31st March 2011, 09:16 | #1176 | Link | ||
or increase the merit or remove (if exist) Haali's
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 31st March 2011 at 09:21. |
31st March 2011, 19:41 | #1177 | Link |
Is the Audio decoder using for every format supported libavcodec and has it 32 bit support like ffdshow and mpc-hc internal filter ?
also using libavformat for the mp4/mov part will it by default support everything it would in mplayer or did you removed fourccs by purpose ? like for example mjpg a/b or PNG support inside .mov ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 31st March 2011 at 19:47. |
31st March 2011, 21:47 | #1178 | Link |
If you use LAV Splitter and LAV Audio together, it can decode everything that libavcodec supports. I also added 32-bit float support for AAC, AC3, DTS and MP3. Additionally it should also be possible to add it to Vorbis when i feel like doing it.
The demuxer, in theory, supports everything libavformat supports. If some specific file does not play properly or does not connect to some decoder, it probably needs its DirectShow media type fixed. My sample collection is not infinite, there will always be files that need fixes.
1st April 2011, 00:43 | #1179 | Link |
Should the LAVF Splitter already be able to open raw flac files ? It works fine together with ffdshow as flac decoder when I am opening mastroska files containing flac audio tracks. But when I am trying to open a raw flac file I get "cannot render the file" within MPC-HC.
