9th November 2018, 20:16 | #1201 | Link | |
Member
Microsoft release AV1 Video codec for Windows 10
https://mspoweruser.com/microsoft-re...or-windows-10/
10th November 2018, 13:51 | #1203 | Link |
Where can I download ffmpeg with libdav1d library?
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
10th November 2018, 15:04 | #1205 | Link | |
I am maddo saientisto!
Win64 GCC 8.2 static build: ffmpeg-4.2-92396-g55e021f39b: https://mega.nz/#!IgAAVayA!jpzHzBaE6...FnbjR-ruOD8lCI - libaom 1.0.0-902-g03d8ebedc - libdav1d 58fc516 Last edited by SmilingWolf; 10th November 2018 at 15:06. |
10th November 2018, 18:58 | #1206 | Link |
In order to GET the new MS AV1 codec from MS Store, you need to install the forbidden (banned) Windows October 2018 Update.
Test: MS Windows October x64 Core i3 4170 DXVA Checker (new beta version) Sample: Chimera AV1 1080p 8bit (Netflix free sample) LAV x64 0.73.1 vs MS MFT AV1 LAV x64 19/34/144 (min/avg/max fps) CPU Usage: 57/70/83 (%) MS MFT AV1 15/26/156 CPU Usage: 50/68/81 It seems that AOM AV1 codec is ~30% faster than MS MFT AV1 on average fps
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
10th November 2018, 19:16 | #1207 | Link |
@SmilingWolf
Thank. But my results are different from those that were announced here. I ran the following tests: Code:
ffmpeg -hide_banner -t 10 -c:v libaom-av1 -i Stream2_AV1_4K_22.7mbps.webm -benchmark -f null - ffmpeg -hide_banner -t 10 -c:v libdav1d -i Stream2_AV1_4K_22.7mbps.webm -benchmark -f null - ffmpeg -hide_banner -t 10 -c:v libdav1d -threads 4 -tilethreads 4 -i Stream2_AV1_4K_22.7mbps.webm -benchmark -f null - libaom-av1 - max 14 fps libdav1d - max 7.4 fps libdav1d -threads 4 -tilethreads 4 - max 9.7 fps Added: Intel i5-3570k, Windows 7 Sp1 x64.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 13th November 2018 at 19:22. |
11th November 2018, 04:36 | #1209 | Link | |
Helenium(Easter)
What is the CPU you use for testing? It might be related to the AVX2 code used in dav1d.
Monochrome Anomaly |
11th November 2018, 05:12 | #1210 | Link |
sse2, sse4.1?
11th November 2018, 07:37 | #1211 | Link |
Very "good" optimisation dav1d - much slower on my system...
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 11th November 2018 at 08:59. |
11th November 2018, 09:04 | #1212 | Link | ||
And of course, it's those very same AVX-lacking Celerons and Pentiums and such that would stand to gain the biggest benefit from any such software decoder optimizations because those processors simply lack the raw "moar cores!" computational grunt that their i7 and Ryzen brethren have for brute-forcing their way through. So needless to say, it'd be pretty disappointing to me if dav1d pretty much required having an AVX-capable CPU in order to have any benefit. Quote:
11th November 2018, 13:14 | #1213 | Link |
Beyond Kawaii
I wish aomenc/vpxenc had GOP-level parallelism. When each thread is encoding one GOP, and then they are stitched together. That would make use of all CPU power without compromising quality/compression.
...desu! |
11th November 2018, 13:25 | #1214 | Link | |
11th November 2018, 13:49 | #1215 | Link |
ffmpeg -hide_banner -t 10 -c:v libaom-av1 -i 1.mp4 -benchmark -f null - (43 fps)
ffmpeg -hide_banner -t 10 -c:v libdav1d -i 1.mp4 -benchmark -f null - (52 fps) ffmpeg -hide_banner -t 10 -c:v libdav1d -threads 1 -tilethreads 2 -i 1.mp4 -benchmark -f null - (61 fps) ffmpeg -hide_banner -t 10 -c:v libdav1d -threads 2 -tilethreads 2 -i 1.mp4 -benchmark -f null - (65 fps) |
11th November 2018, 15:12 | #1217 | Link | |
Still, MMX is hardly relevant nowadays. SSE4.1 as the lowest bar doesn't sound too unreasonable Also relevant: https://code.videolan.org/videolan/d.../15#note_22262 Last edited by SmilingWolf; 11th November 2018 at 18:34. |
11th November 2018, 19:06 | #1218 | Link | ||
SSEx should be the base as it is 128bit with very fast implementation on all CPUs of the last 10 years. Especially SSE2 is mandatory for x64 architecture. From the last link it's obvious that dav1d developers targeted AVX2 for 256bit acceleration using ASM, but not exclusively. They are going to optimise for SSEx later. So no worries, I think.
12th November 2018, 00:30 | #1220 | Link |
You can also usually safely target SSE3 (no, not SSSE3) as well since it's supported on all DDR2-capable 64bit x86 CPUs and newer.
(the only 64bit x86 CPUs that don't support SSE3 are some socket 754 and 939 Athlon 64s which used DDR1) |
