27th August 2010, 04:28 | #10501 | Link | |
28th August 2010, 14:17 | #10502 | Link |
Short notice:
There are some kind of MLP files which libav cannot handle: Those with mixed sampling rates (i.e. 96khz for Lf-Rf-C and 48khz for LFE-Ls-Rs). Seems Nero is the only option there. Unfortunately getting the Nero decoder working is ... It now works after removing Nero and installing the latest Nero Lite 7 version. Maybe eac3to should check for the mixed sampling rates and select the decoder approriately. An example for this type of file can be found on the DVD Audio "Nena feat. Nena Live". If you have any questions about this please write a PM as I'm not reading this thread all the time. |
29th August 2010, 02:51 | #10503 | Link |
One thing I just noticed when extracting audio of an avc hd disc to stereo flac (for mp3 encoding) is that even if eac3to notices that a second pass is needed it just continues writing the compressed flac file till the end. After that it gets overwritten with the second pass flac file.
Wouldn't it be faster to abort the encoding and file writing after it discovers that it needs a second pass (especially if the source and target disc are the same)? |
29th August 2010, 09:24 | #10504 | Link | |
29th August 2010, 09:25 | #10505 | Link |
We need continue until the end to know all gaps/ovelaps/overflows before begin the second pass
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 29th August 2010 at 10:05. Reason: typo |
29th August 2010, 09:37 | #10506 | Link | |
I admit that I initially read the post exactly the same way as you did I'd typed out a similar reply to yours before the penny dropped and I realised what Rumbah meant. |
30th August 2010, 00:12 | #10508 | Link |
1st pass could specify -o NUL , and only write the info to a log file which it needs for the 2nd pass.
2nd pass uses the info from the log file generated from the 1st pass, and this time writes the actual outfile which we want. It would save some diskdrive wear, be a bit faster, & use less CPU power and generated heat, than writing an output file on the 1st pass for nothing.
Thankyou!, I am grateful for any help |
30th August 2010, 02:14 | #10509 | Link |
Any one else seeing this with the Cars Blu-Ray? eac3to 3.24
v02 0:01:15 The source file seems to be damaged (discontinuity). a04 0:01:15 The source file seems to be damaged (discontinuity). a03 0:01:15 The source file seems to be damaged (discontinuity). v02 0:01:15 Detected PTS break, increasing PTS by 41.7ms... a03 0:01:15 Detected PTS break, increasing PTS by 8ms... a03 libav Lossless check failed - expected b, calculated 3c a04 0:01:15 Detected PTS break, increasing PTS by 32.0ms... a03 0:01:50 The source file seems to be damaged (sync byte missing). a04 0:01:50 The source file seems to be damaged (sync byte missing). v02 0:01:51 The source file seems to be damaged (sync byte missing). v02 0:01:56 The source file seems to be damaged (discontinuity). a03 0:01:56 The source file seems to be damaged (discontinuity). a04 0:01:56 The source file seems to be damaged (discontinuity). a03 libav Lossless check failed - expected ef, calculated d0 v02 0:01:29 The source file seems to be damaged (discontinuity). a04 0:01:30 The source file seems to be damaged (discontinuity). a03 0:01:30 The source file seems to be damaged (discontinuity). |
30th August 2010, 04:02 | #10510 | Link |
is it OK if that line "swapping endian..." appears twice?
eac3to v3.24 command line: eac3to movie 1) 3: movie.pcm ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:40:40, 24p /1.001 1: Chapters, 17 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: RAW/PCM, English, 1.0 channels, 24 bits, 48kHz 4: AC3, English, 1.0 channels, 192kbps, 48kHz 5: Subtitle (PGS), English [a03] Extracting audio track number 3... [a03] Reading RAW/PCM... [a03] Swapping endian... [a03] Swapping endian... [a03] Creating file "movie.pcm"... [a03] The original audio track has a constant bit depth of 24 bits. Video track 2 contains 144816 frames. eac3to processing took 17 minutes, 51 seconds. Done. Last edited by Thunderbolt8; 30th August 2010 at 13:43. |
3rd September 2010, 22:36 | #10511 | Link |
I love eac3to, thanks for all the work put into it.
I have one issue which I have never been able to solve, despite numerous attempts and searches. Two DTS-MA 6.1 soundtracks will not decode properly in eac3to no matter what I have tried (Top Gun and X-Men the Last Stand). I am using eac3to v3.24, Arcsoft DTS decoder v1.1.0.7. It doesn't matter whether I decode straight from the disc, or from the disc to a .dtsma file, then decode. The resultant FLAC file always sounds like a garbled mess (though you can hear the underlying dialog). I have tried doubling the back channel, to no avail. I though the Arcsoft decoder was supposed to work great with 6.1 and 7.1, as stated in the original post of this thread. What gives? Am i using the wrong version, or do I need to use a different decoder? Thanks, and I hope I can find some guidance on this issue. P.S. I have also tried decoding to mono WAVs, and I end up with seven files that all sound identical and garbled (even the LFE, which contains plenty of non-low frequency sound in this case). Last edited by SC05; 3rd September 2010 at 22:53. |
4th September 2010, 11:18 | #10515 | Link |
madshi,
Recently I noticed that when demuxing all files to the same disk the video file is created with hundreds of fragments, even though the disk has been defragged and lots of empty space available. Since I have 3 hard disks, and I only extract a few streams (original audio, video, chapters and 1 or 2 subs), I thought that I might be able to speed up the processing by writing the demuxed files to separate disks. I've created a 256 MB ram disk for putting the smaller files, and sent the video and audio for different hard disks. It didn't seem to have resulted, because the processing time increased by 50% (different BR), but on the other hand the fragmentation was smaller. Instead of 137 fragments I only got 29. The first case was a demuxed mpeg2 stream, and the second was a H264 stream to mkv file. The curious thing is that only the video file is fragmented, so would it be possible for you to avoid the fragmentation? For example, by first allocating the full size of the file, or any other method? I think this would be a nice feature because besides the speedup it would also help reducing the stress on the hard disks... |
4th September 2010, 15:40 | #10516 | Link |
Aging Video Hobbyist
Do you (or anyone) know:
1. Was 1.1.0.0 the version with v2.0 of TMT? I have v2 but am using 3.0 now. 2. Is it as simple as overwriting the 1.1.0.7 dll (mine's in my eac3to dir) 3. Was there a "known bug" in 1.1.0.0 that we exchange for when we revert from .7 to .0 TIA |
4th September 2010, 18:08 | #10517 | Link |
1) ArcSoft.TotalMedia.Theatre.v2.1.6.129
2) If you have the full TMT 3.0 installed maybe you can't use v1.0.0.0. If you have only some files in eac3to folder: - unregister ASAudioHD.ax from v1.1.0.7 (maybe not needed but is a good method) - replace the files - register the ASAudioHD.ax from v1.1.0.0 3) I don't know bugs of v1.1.0.0 working with eac3to
4th September 2010, 18:16 | #10518 | Link | |
5th September 2010, 11:21 | #10519 | Link | |||
Posts: n/a
7ek |
eac3to |
