Old 26th June 2020, 01:19   #59761  |  Link
B1gD4ddy
is the described bug already on that list?
is it "Madtpg will not kick into HDR mode"?
or does that refer to something else?
- LG 65C9 - Denon AVR X4500H - Elac FS 208 Anniversary - DynAudio Contour 1.1 -
B1gD4ddy is offline   Reply With Quote
Old 26th June 2020, 01:49   #59762  |  Link
VBB
VBB's Avatar
That's something unrelated.
Henry
LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2
NVIDIA GeForce GTX 960 | LAV Filters | madVR | MPC-HC | Plex | X-Rite i1Display Pro | DisplayCAL | HCFR
VBB is offline   Reply With Quote
Old 26th June 2020, 02:34   #59763  |  Link
B1gD4ddy
ok, would be nice if that gets on the bug list.
Old 26th June 2020, 05:25   #59764  |  Link
dbcooper
Any issues reported with Windows 10 2004 update?
dbcooper is offline   Reply With Quote
Old 26th June 2020, 07:30   #59765  |  Link
VBB
VBB's Avatar
Been using it with madVR. No problems so far.
Henry
Old 26th June 2020, 07:49   #59766  |  Link
Ænz
Hi. Im having some trouble with the custom resolutions needed for playback without dropped frames on nvidia cards.
I have a custom resolution in madvr that works well, 1 dropped or repeated frame every 11+ hours. But it only works in mpc-hc. If I play a movie in mpc-be or kodi dsplayer, I get the dropped frame every 4,5 min. or so. I can not find the source of this problem. I have verified that madvr is used in the other players. I have tried different versions of dsplayer, witch I probably would prefer.
Ænz is offline   Reply With Quote
Old 26th June 2020, 10:15   #59767  |  Link
make sure the same audio renderer and audio output is used.
Old 26th June 2020, 14:20   #59768  |  Link
Ænz
Thanks. I just checked it. I use DirectSound bitstream to my Denon AVR. Have that set as output, passthrough device and audio renderer. Still the same, repeated frame every 4.5 min. But runs smooth in mpc-hc
Old 27th June 2020, 05:14   #59769  |  Link
B1gD4ddy
i added the hdr passthrough thing to the bug tracker and madshi actually assigned it... http://bugs.madshi.net/view_all_bug_page.php ...now wait.
Old 27th June 2020, 10:23   #59770  |  Link
SigHunter
thank you very much! I hope madshi can fix this soon, I hate to be stuck to old graphics driver versions and this effectively breaks madvr for the future. 446.14 is the last one that works with our old madvr
SigHunter is offline   Reply With Quote
Old 27th June 2020, 13:24   #59771  |  Link
mogli
Btw which scaler is Krigbilateral exactly?
mogli is offline   Reply With Quote
Old 27th June 2020, 14:07   #59772  |  Link
Alexkral
You mean in madVR? You have some similar bilateral options for chroma resampling. KrigBilateral is a shader created by Shiandow for MPDN and also adapted by igv for mpv. It's used for chroma resampling though it could also be used for 2x chroma upscaling.
Alexkral is offline   Reply With Quote
Old 27th June 2020, 15:51   #59773  |  Link
the bilateral in madVR should be from shiandow too. i can't recommend it. this scaler lives from the luma channel but the luma channel is not always available when chroma scaling is critical.
Old 28th June 2020, 16:49   #59774  |  Link
deado
Fullscreen exclusive mode has stopped working for me (player is mpc-hc 1.9.6).
deado is offline   Reply With Quote
Old 28th June 2020, 17:38   #59775  |  Link
Klaus1189
@deado: What is exactly the issue?
Old 29th June 2020, 02:19   #59776  |  Link
deado
Strange.. I changed nothing, woke up today, and it's now working again. Couldn't get it to work last few days no matter what I tried (since upgrading to win10 2004).
Oh well good to know it's not an 'issue' generally.
Old 29th June 2020, 16:56   #59777  |  Link
RXP
Had a really frustrating problem now - and only realised what it was at the end of the movie. Display Identification got messed up so none of my profiles applied.
I've got all my profiles nicely setup in MadVR - everything "just works" recently, very happy with it. Then sat down for a re-watch of the Dark Knight with my wife and I noticed the colours were over-saturated. I didn't want to pause the movie and faf around with settings because I thought it was the tone mapping algo having a few issues and it's really frustrating to do that when you're watching with someone else.
Turns out for some reason MadVR had a different display device active, no EDID info just "generic PnP monitor" with a string of Windows info. So none of my profiles for the other EDID's were selected. I assume MadVR defaults to Rec709 so the tone mapping was trying to tone map to Rec709 and I'd flipped to the Rec2020 mode on my PJ. Hence over-saturation.
No idea why Windows/Nvidia/whatever decided to show my display as another display. 0 updates, 0 changes - I dual boot for this exact reason so I keep one boot perfectly stable. But I guess even that doesn't work. Sigh....
RXP is offline   Reply With Quote
Old 29th June 2020, 20:08   #59778  |  Link
Martin51
Hello, I am following the tutorial for custom modes. Once optimization data is available, I see the "Test mode" button instead of "Apply". I tried changing the refresh rate, and restart with no luck. Any ideas?
Martin51 is offline   Reply With Quote
Old 30th June 2020, 19:01   #59779  |  Link
mclingo
shouldnt be that hard but it doesnt always work but when it doesnt it can be a reall faff to get this work, sometimes, even though you've done it all correct it still does nothing, I have this issue with my wireless Arctis pro headphones, no matter what I do or set I get a frame drop every 20 mins, which isnt a disaster but I get several hours or days with my AMD HDMI audio without and special configs at all.
Quick quide.
Delete any you've already put in and reboot
click add - select your resolution and refresh rate and click apply.
Play a move for 20 mins.
Go back in and open the optimize tab and select one of the options that look good and apply.
Reboot and see what you get.
What are you currenting timings, post a screen shot of your control J screen after 5 mins playback in case you've set something up wrong, for instance you only need timings for NVIDIA cards usually, AMD card have impeccable timing and require not custom modes (usually).
OLED 4k HDR EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 1909 444 RGB -MD RX 5700 8GB 20.1.3 KODI DS - MAD/LAV 92.17+ 113 beta - 0.74.1 - 3D MVC / FSE:off / MADVR 10bit
Old 30th June 2020, 20:13   #59780  |  Link
x7007
hey guys, nvidia changed its hdr code in the 45x.xx drivers. because of that madvr hdr passtrough does not work anymore.
quote from guru3d forum: "HDR works fine, it's just madvr that doesn't know what to do with how Nvidia changed the HDR code in the drivers. If it's like the 451.22, NVHDR activates the Windows HDR option instead of running its own code."
from me: can confirm. mpc be madvr hdr passtrough does not work anymore. it just activates windows hdr but movie is still sdr. only help for now is to go back to 446.14.
so please update madvr and make hdr passtrough usable again. thx.
Yes works with potplayer x64 also.. Thanks
x7007 is offline   Reply With Quote
