4th December 2004, 13:23 | #43 | Link | |
Bored...
Bye |
4th December 2004, 13:31 | #45 | Link | |
Lost in a Byte
I can't find a way to recode a "file", DVD only (why?) I can recode a DVD to a DVD only!!! (what?!?) I can't download italian language packs (and in the previuos Nero Vision language pack only a little part of software was localizated) (why?) PS: I've tested only the "update" download Last edited by LostMP4; 4th December 2004 at 13:38. |
4th December 2004, 13:32 | #46 | Link | |
A/V moderator @ hydrogenaudio.org My weird old sh*t: http://www.nic.fi/~lhahne/ http://last.fm/user/Latexxx/ |
4th December 2004, 13:33 | #47 | Link | |
Lost in a Byte
4th December 2004, 13:43 | #48 | Link | |
I'm Shpongled
LostMP4: maybe You have some sort of OEM, You can try remove current SN and see if demo version works |
4th December 2004, 14:05 | #50 | Link |
Mr. Sandman
I'm impressed. Need to "recode" all my DVDs...
4th December 2004, 14:31 | #51 | Link | |
Life's clearer in 4K UHD
I'm using the slowest/highest quality 2pass AVC settings and I've just broken thru' 13hour 13min barrier... with another 247 mins to go I reckon It's still faster than WMV9's slowest/highest quality 2pass setting.... Cheers
4th December 2004, 14:48 | #53 | Link | |
Mr. Sandman
4th December 2004, 15:11 | #56 | Link |
Mr. Sandman
Blah... i can no longer encode...
every source i try it says "Burning process failed"... Logfile: Code:
Project type: Nero Digital Target size: Custom (358400) 14:56:00 File LangStreamPatcher.cpp, Line 56 Command table patching started... 14:56:00 File LangStreamPatcher.cpp, Line 133 All tables successfully patched! Burn settings: Target: Hard disk folder Number of copies: 1 Target folder: C:\Documents and Settings\Ebola\Desktop (2217295872 bytes free) NeroDigital profile: Maximum Definition - AVC Shutdown when finished: false Advanced Analysis: false Compress Adaptive: false 14:56:06 File burn_ndigital.cpp, Line 158 NeroDigital: init 14:56:06 File burn_ndigital.cpp, Line 269 NeroDigital: burning 3805 sectors (3805 required) 14:56:06 File burn_ndigital.cpp, Line 343 NeroDigital: beginning 1st-pass operation 14:56:06 File burn_ndigital.cpp, Line 697 NeroDigital: encode sp2tr Source: Size (720,384) Display Aspect Ratio (720,384) Deinterlace disabled Cropping enabled (0, 0, 0, 0) Resizing enabled (560,304) Pixel ratio (1,1) Bitrate: 501400 bps 14:56:06 File burn_ndigital.cpp, Line 722 Nth-pass file = C:\DOCUME~1\Ebola\IMPOST~1\Temp\\sp2tra03640.bin ERROR in file:E:\Sources\Current\Recode 2.2\Nero Recode II\directshow\utils.cpp, line:566, error:Il tipo di supporto di questo file non è riconosciuto.(0x80040240) ERROR in file:E:\Sources\Current\Recode 2.2\Nero Recode II\directshow\utils.cpp, line:566, error:Impossibile caricare il filtro di origine per il file.(0x80040241) ERROR in file:E:\Sources\Current\Recode 2.2\Nero Recode II\burning\../directshow/DSError.h, line:120, error:Interfaccia non registrata. (0x80040154) 14:56:07 File burn_ndigital.cpp, Line 200 NeroDigital: exit Help?
4th December 2004, 15:45 | #58 | Link |
First tests and I am amazed. Easily the best codec out there (for my needs at least).
At low bitrates using adaptive deblocking gives a more detailed picture at the cost of some blocks here and there. Also I got a video with a lot of snow and vibrant blue-red colors at times, where nero gives a very blocky image. I thought blocks where because of bframes or psychovisual options but disabling them didnt help. Sorry for the noob question, how can I take some pictures of frames of the videos produced? Vdub cant open the videos, and as always prtscrean doesnt work. |
4th December 2004, 15:59 | #59 | Link |
you can just disable hardware acceleration on your grphics card then you ahould be able to take screen grabs using print screen.
HQ XviD Music Video Forum When I'm good I'm very, very good but when I'm bad I'm better. |
